System requirements
Available with Workflow Manager license.
ArcGIS Workflow Manager Server has the same hardware and operating system requirements as the ArcGIS Server software component in ArcGIS Enterprise.
Software
Workflow Manager Server requires an ArcGIS Enterprise deployment.
You can install Workflow Manager Server on its own machine, separate from the hosting server machine, or on the hosting server machine. For production deployments, install Workflow Manager Server on its own machine. In this scenario, you must install ArcGIS Server but do not need to license it as a GIS server.
Learn more about licensing Workflow Manager
Workflow items store and access data through associated hosted feature layers and views. If you are using ArcGIS Enterprise on Windows or Linux, the underlying data storage occurs in your ArcGIS Enterprise site's relational store. If you are using ArcGIS Enterprise on Kubernetes, data storage depends on your deployment's storage configuration.
Port availability
Workflow Manager Server requires access to specific ports where base deployment components are installed to communicate with ArcGIS Enterprise.
Learn more about ports used by Workflow Manager Server (PDF)
The following table contains the required port numbers:
Port number |
Protocol |
Component |
13443 |
HTTPS |
Used by Workflow Manager. This port must be opened before installing the software. If there is a firewall between ArcGIS Web Adaptor and Workflow Manager, port 13443 must be open between the machine hosting ArcGIS Web Adaptor and Workflow Manager. |
7443 |
HTTPS |
Used by Portal for ArcGIS. |
6443 |
HTTPS |
Used by ArcGIS Server and any hosted or federated server machines. |
11211 |
TCP |
Used for communication between the Java Database Connectivity (JDBC) client and an Apache Ignite database inside each Workflow Manager machine. External communication over this port is not required. |
13820 13830 13840 |
TCP |
Used by highly available Workflow Manager deployments. |
This component is only one part of an ArcGIS Enterprise deployment.
Supported web browsers
Workflow Manager requires one of the following web browsers:
Google Chrome
Mozilla Firefox
Microsoft Edge
It is recommended to use Chrome or Firefox for optimal performance.
SSL certificates
Workflow Manager Server is preconfigured with a self-signed certificate that allows you to verify that the installation was successful.
You must request a certificate from a trusted certificate authority (CA) and configure Workflow Manager Server to use it. This can be a domain certificate issued by your organization or a CA-signed certificate.
Portal for ArcGIS also includes a preconfigured self-signed certificate. Before you federate Workflow Manager Server with an ArcGIS Enterprise portal, request a certificate from a trusted CA and configure the portal to use it.
Learn more about security best practices
Cloud-native relational store
You can deploy Workflow Manager Server in public and private cloud environments.
To migrate your organization's hosted relational data store to a cloud-native relational store, upgrade your workflow item to the latest item version.
