Configure map settings
Available with Workflow Manager license.
You can configure a workflow item's map settings to set a custom basemap in dark or light mode for the web app. Map settings determine the map used by the Manage page and the Diagram & Map tab in the Details panel.
Map settings do not determine the map used by the Define Location step.
Configure a custom basemap
To configure a custom basemap for a workflow item, complete the following steps:
  1. Access the Workflow Manager web app.
  2. Click the Design tab.
    The Design page appears.
    If you don't have sufficient privileges, the Design tab is not available.
  3. Click Settings .
    If you don’t have sufficient privileges, Settings is not available.
  4. Click the Map Settings tab.
    The basemap appears in both light mode and dark mode.
  5. Click Edit at the top of the basemap you want to use.
    The Update Default Map dialog box appears.
  6. Choose the environment where the web map is located:
    • This Enterprise—Add a web map from the current portal.
    • ArcGIS Online—Add a web map from ArcGIS Online.
    • Other—Add a public web map from another portal.
    If you chose Other, provide the URL for the portal in the Portal URL text box as follows:
    https://webadaptorhost.domain.com/webadaptorname.
  7. Provide the item ID for the web map in the Item Id text box.
  8. Provide the name of the web map in the Reference Name text box.
    If the item ID is valid, the Reference Name text box automatically populates with the name of the web map.
  9. Click OK.
    The Preview pane updates with the new map.
  10. Click Save to save the changes or click Discard Changes to undo the changes.
    To revert to the default basemap, click Revert.
Define an organizational basemap
To specify a single basemap to be used across all workflow items in your organization, complete the following steps:
  1. Open the <Portal for ArcGIS installation location>\apps\workflowmanager\conf\appconfig.json file in a text editor.
  2. Add the  mapItemId key and the map item ID in the following format:  "mapItemId": "eae4b56daad2453e915cdc2638c74383".
  3. Save the file.
  4. Restart the Workflow Manager Server service.
