Users, groups, roles, and privileges
Available with Workflow Manager license.
The privileges assigned to a member's group control the member's ability to perform certain actions and access work. Roles are commonly used to limit the following types of actions to specific groups:
  • Job creation
  • Job reassignment
  • Editing workflow diagrams
  • Managing workflow item settings
Workflow item privileges are separate from ArcGIS Enterprise privileges and don't require Enterprise administrative privileges to manage roles and privileges for workflow items.
Users
User accounts and access to the Workflow Manager web app are managed in your ArcGIS organization.
Learn more about adding members to your portal
Groups
Groups are managed in your ArcGIS organization and allow workflow item administrators to assign roles with a set of privileges to a group of users for a workflow item.
Learn more about creating groups
Roles
A role contains a set of privileges. When you assign a role to a group, each user in the group receives the role's privileges for the workflow item. The following sections list the privileges assigned to the default workflow item roles.
Workflow Administrator
The Workflow Administrator role requires a Creator user type with a Publisher role and contains the following privileges:
Privilege
adminAdvanced
View the Design page, configure workflow diagrams, job templates, and workflow item settings such as group roles and privileges, and configure webhook connections.
jobAssignAny
Assign any job to any user or group at any time.
jobAssignGroup
Assign any job assigned to your group to any user in the group.
jobAssignIndividual
Assign any job that is assigned to your group to yourself, and assign any job that is assigned to yourself to your group.
jobClose
Close a job when the workflow is complete.
jobCreate
Create a job.
jobDelete
Delete a job.
jobForceStop
Cancel a step being run by a different user.
jobReopenClosed
Reopen a closed job.
jobUpdateAttachments
Add, update, and delete job attachments.
jobUpdateDate
Update the scheduled start or end date for jobs.
jobUpdateDescription
Update job descriptions.
jobUpdateExtendedProperties
Update extended properties for jobs.
jobUpdateHolds
Update job holds.
jobUpdateLocation
Set a job's location using ArcGIS REST API or ArcGIS API for Python.
This privilege is not required to run the Define Location step.
jobUpdateName
Update the job name.
jobUpdateNotes
Update job notes.
jobUpdateOwner
Update the job owner.
jobUpdateParentJob
Update a job's parent job.
jobUpdatePriority
Update job priority.
jobUpdateStatus
Update job status.
jobUpgrade
Upgrade a job's workflow diagram to the latest version.
viewCreatePanel
View the Create panel.
viewDetailsPanelAttachments
View job attachments in the Details panel.
viewDetailsPanelComments
View job comments in the Details panel.
viewDetailsPanelDiagram
View job workflow diagrams in the Details panel.
viewDetailsPanelHistory
View job history in the Details panel.
viewDetailsPanelHolds
View job holds in the Details panel.
viewDetailsPanelLocation
View job locations in the Details panel.
viewDetailsPanelNotes
View job notes in the Details panel.
viewDetailsPanelProperties
View job properties in the Details panel.
viewManagePage
View the Manage page.
viewWorkPage
View the Work page.
workflowSetStepCurrent
Set the current step in a job's workflow.
Workflow Designer
The Workflow Designer role requires a Creator user type with a Publisher role and contains the following privileges:
Privilege
adminBasic
View the Design page, configure workflow diagrams and job templates, and configure webhook connections.
jobAssignAny
jobAssignGroup
jobAssignIndividual
jobClose
jobCreate
Create a job.
jobDelete
Delete a job.
jobReopenClosed
Update job attachments.
jobUpdateDate
jobUpdateHolds
Update job holds.
jobUpdateLocation
jobUpdateName
jobUpdateOwner
jobUpdateParentJob
jobUpdatePriority
jobUpdateStatus
Update job status.
jobUpgrade
Manage Jobs - Advanced
The Manage Jobs - Advanced role requires a Contributor user type and contains the following privileges:
Privilege
jobAssignAny
jobCreate
Create a job.
jobDelete
Delete a job.
jobReopenClosed
jobUpdateDate
jobUpdateHolds
Update job holds.
jobUpdateLocation
jobUpdateName
jobUpdateNotes
Update job notes.
jobUpdateOwner
jobUpdateParentJob
jobUpdatePriority
jobUpdateStatus
Update job status.
viewCreatePanel
viewManagePage
viewWorkPage
View the Work page.
Manage Jobs - Basic
The Manage Jobs - Basic role requires a Contributor user type and contains the following privileges:
Privilege
jobAssignGroup
jobAssignIndividual
jobUpdateHolds
Update job holds.
jobUpdateNotes
Update job notes.
viewCreatePanel
viewWorkPage
View the Work page.
Privileges
Privileges allow groups to perform specific actions and access work in Workflow Manager. For example, some groups may be able to create jobs, while other groups can run jobs but not create them.
The following is a list of Workflow Manager privileges, the required user type, and their descriptions:
Privilege
User type
Role
adminAdvanced
Creator
Publisher
Access the Design page, configure workflow diagrams, job templates, and workflow item settings such as group roles and privileges, and configure webhook connections.
adminBasic
Creator
Publisher
Access the Design page, configure workflow diagrams and job templates, and configure webhook connections.
jobAssignAny
Contributor
N/A
jobAssignGroup
Contributor
N/A
jobAssignIndividual
Contributor
N/A
jobClose
Contributor
N/A
jobCreate
Contributor
N/A
Create a job.
jobDelete
Contributor
N/A
Delete a job.
jobForceStop
Contributor
N/A
jobReopenClosed
Contributor
N/A
Contributor
N/A
jobUpdateDate
Contributor
N/A
Contributor
N/A
Contributor
N/A
jobUpdateHolds
Contributor
N/A
Update job holds.
jobUpdateLocation
Contributor
N/A
jobUpdateName
Contributor
N/A
jobUpdateNotes
Contributor
N/A
Update job notes.
jobUpdateOwner
Contributor
N/A
jobUpdateParentJob
Contributor
N/A
jobUpdatePriority
Contributor
N/A
jobUpdateStatus
Contributor
N/A
Update job status.
jobUpgrade
Contributor
N/A
viewCreatePanel
Viewer
N/A
This privilege also requires the viewWorkPage or the viewManagePage privilege.
Viewer
N/A
Viewer
N/A
Viewer
N/A
Viewer
N/A
Viewer
N/A
Viewer
N/A
Viewer
N/A
Viewer
N/A
viewManagePage
Viewer
N/A
viewWorkPage
Viewer
N/A
View the Work page.
Contributor
N/A
