Create jobs using an ArcGIS Survey123 webhook
Available with Workflow Manager license.
License:
This functionality requires a license for the ArcGIS Workflow Manager Server Advanced role.
You can configure a webhook on the ArcGIS Survey123 website to automatically create jobs in ArcGIS Workflow Manager when a survey is submitted.
Before you can submit surveys to create jobs in Workflow Manager, the survey must be hosted on the same ArcGIS Enterprise portal as Workflow Manager Server and shared the with the user submitting the survey. To create jobs in Workflow Manager with a publicly hosted Survey123 survey, configure a Webhook Job Creation automated action with the ArcGIS Webhook authentication method.
If ArcGIS Workflow Manager Server is federated with an ArcGIS Enterprise that uses Integrated Windows Authentication (IWA) or Public Key Infrastructure (PKI) authentication, the Survey123 webhook can't be used to create jobs in Workflow Manager.
To configure a Survey123 webhook, complete the following steps:
Access the Workflow Manager web app.
Click the Design tab.
The Design page appears.
If you don't have sufficient privileges, the Design tab is not available.
Click Job Templates
.The Job Templates panel appears.
Choose the job template that you want to use to create jobs when a survey is submitted in the Job Templates panel.
The job template appears in the panel.
Tip:
You can type a keyword in the Search Job Templates text box to filter the list to show job templates that contain the keyword.
Create an extended properties table for the job template.
This allows survey data to be associated with the job.
Take note of the ID for the workflow item and job template in your web browser's address bar.
For example:
https://gisserver.domain.com/webadaptorname/apps/workflowmanager/<workflow item id>/design/jobTemplate/<job template id>This information is required to configure the webhook for your survey.
Configure a webhook on the ArcGIS Survey123 website for the survey using the following parameters:
Caution:
When you create or modify a webhook for a survey, the survey must be updated in the Survey123 field app for the changes to take effect.
In the Payload URL field, provide the URL for Workflow Manager using the following example:
https://gisserver.domain.com/webadaptorname/workflow/<workflow item id>/webhooks/createJobFromSurveyResponse/<job template id>In the Trigger events section, check the New record submitted check box.
In the Event data section, check the following check boxes:
Survey info
Submitted record
Portal info
The webhook is ready to create jobs in Workflow Manager when a survey response is submitted.
