Manage priorities
Available with Workflow Manager license.
Priorities allow you to assign levels of importance to jobs. You can add custom priorities to match your existing business processes or to make them more appropriate for your locale.
Create priorities
To create priorities, do the following:
  1. Access the Workflow Manager web app.
  2. Click the Design tab.
    The Design page appears.
    If you don't have sufficient privileges, the Design tab is not available.
  3. Click Templates .
    If you don’t have sufficient privileges, Templates is not available.
  4. Click the Lookup Tables tab.
    The Lookup Tables panel appears.
  5. Click Priorities in the Lookup Tables panel.
    A list of priorities appears.
  6. Click Add Priority.
  7. Provide a name for the priority in the Name text box.
  8. Provide a rank for the priority in the Rank text box.
  9. Optionally, repeat steps 6 through 8 to add more priorities.
  10. Click Save to save the priorities.
Edit priorities
To edit priorities, do the following:
  6. Update the priority names in the Name text boxes as necessary.
  7. Update the priority ranks in the Rank text boxes as necessary.
  8. Click Save to save the changes.
Delete priorities
Deleting a priority is permanent and can’t be undone.
Caution:
Your workflow item must contain at least one priority.
To delete priorities, do the following:
  6. Click the Delete button next to the priority that you want to delete.
  7. Click Save to save the changes.
