What's new in ArcGIS Workflow Manager
Available with Workflow Manager license.
The 12.2 release of ArcGIS Workflow Manager includes the following:
  • The Create Field Maps Task step allows you to create a task to help manage and track field work associated with your job using ArcGIS Field Maps.
    The Create Field Maps Task step is available for diagrams using centralized data references. Upgrade your existing diagrams to access this feature.
  • Running the Create Field Maps Task step places a webhook dependency on the subsequent step. Workflow Manager removes the dependency automatically when the release conditions are met. You can view and manage webhook dependencies in the Holds tab, in the Job Details panel.
  • You can create webhook connections and use them on steps to add webhook dependency holds.
  • ArcGIS Workflow Manager supports HTTP/2 by default.
  • You can adjust the timeout period for tasks that involve content publishing, such as creating workflow items and editing extended property tables.
Functionality matrix
For an overview of the features available with your version of Workflow Manager, review the ArcGIS Workflow Manager 12.2 Functionality Matrix (PDF).
