Customize the Workflow Manager configuration file
Available with Workflow Manager license.
If you are using ArcGIS Enterprise on Kubernetes, you can configure workflow management services.
As an administrator, you can add and manage properties in the WorkflowManager.conf file to configure custom settings for ArcGIS Workflow Manager Server and the web app. After installing Workflow Manager, the configuration file is located at %ProgramData%\esri\workflowmanager\WorkflowManager.conf.
As an administrator, you can add and manage properties in the workflowManager.conf file to configure custom settings for ArcGIS Workflow Manager Server and the web app. After installing Workflow Manager, the configuration file is located at ~/.esri/WorkflowManager/<hostname>/workflowManager.conf.
If your ArcGIS Enterprise system contains more than one ArcGIS Server machine with Workflow Manager Server, you must repeat changes to the configuration file in each instance of ArcGIS Server.
Administrative parameters
The following table describes the parameters you can modify to customize Workflow Manager Server and the web app:
If you are upgrading Workflow Manager, some parameters may not exist and must be manually added to the configuration file.
Parameter
Example format
publishingTimeout
Controls the time allowed for operations that involve publishing content, including creating workflow items, upgrading workflow items, and modifying extended property tables. The default is 10 minutes.
publishingTimeout = 90 seconds
arcadeExpressionTimeout
Controls how long Arcade expressions attempt to evaluate.
arcadeExpressionTimeout = 10 seconds
featureBatchSize
Controls how many edits are done at a time for specific operations. For example, creating jobs from an array.
featureBatchSize = 100
webRequestTimeout
Controls how long the Send Web Request step and template attempt to send a web request before the request fails.
webRequestTimeout = 1 minute
webhookTokenExpiration
Controls how long the token used in the Send Web Request step or template is valid.
webhookTokenExpiration = 30 minutes
webhookMaxAttachmentSize
Controls the maximum size allowed for attached responses on a job.
webhookMaxAttachmentSize = 10m
LogRetentionPeriod
Controls how often the cleanup task deletes log messages in the web app. By default, this property is set to 7 days.
This property does not alter how often Workflow Manager Server deletes logs.
LogRetentionPeriod = 7 days
jobAutoExecutionLimit
Controls the number of jobs that automatically run when they are created at one time.
jobAutoExecutionLimit = 25
allowUnsecureWebhooks
Controls whether incoming webhooks require header security. Starting at 11.2, by default, this property is set to false.
Caution:
Setting this property to true allows anyone with the webhook URL to create jobs in the web app.
allowUnsecureWebhooks = false
webRequestAllowLocal
Controls whether the Send Web Request step permits requests to localhost.
webRequestAllowLocal = false
webRequestAllowedHosts
Controls which hosts are allowed to receive web requests during the Send Web Request step. This property is available starting at 12.2. By default, this list is empty.
webRequestAllowedHosts = ["esri.com", "doc.arcgis.com", "127.0.0.1/32", "2001:0db8:85a3:0000:0000:8a2e:0370:7334"]
webRequestAllowedPorts
Controls which ports are allowed to receive web requests during the Send Web Request step. This property is available starting at 12.2. By default, this list is empty.
webRequestAllowedPorts = ["80","443","6443","13443"]
"80", "443", and "6443" are allowed by default if using ArcGIS Enterprise on Kubernetes.
webRequestAllowedProtocols
Controls which protocol is permitted during the Send Web Request step.
webRequestAllowedProtocols = ["https"]
webRequestBlockHostsByDefault
Controls whether the Send Web Request step permits requests to hosts that are not defined in webRequestAllowedHosts. This property is available starting at 12.2. By default, this property is set to false.
webRequestBlockHostsByDefault = false
webRequestBlockPortsByDefault
Controls whether the Send Web Request step permits requests to ports that are not defined in webRequestAllowedPorts. This property is available starting at 12.2. By default, this property is set to false.
webRequestBlockPortsByDefault = false
webRequestBlockedHosts
Controls which hosts are blocked from receiving web requests during the Send Web Request step. All addresses to the blocked host must be listed, including IPv4, IPv6, and hostname.
webRequestBlockedHosts = ["169.254.169.254/32", "127.0.0.1/32", "1/128", "0.0.0.0", "169.254.169.254/32"]
"0.0.0.0" and "169.254.169.254/32" are blocked by default if using ArcGIS Enterprise on Kubernetes.
webRequestBlockedPorts
Controls which ports are blocked during the Send Web Request step.
webRequestBlockedPorts = ["80", "81"]
webRequestEnforceValidDomain
Controls whether valid domains are enforced during the Send Web Request step. By default, this property is set to false.
webRequestEnforceValidDomain = false
webRequestRestrictedHeaders
Controls which request headers are blocked during the Send Web Request step.
webRequestRestrictedHeaders = ["Content-Length", "Content-Location", "Forwarded", "From", "Host", "Referer", "Referer-Policy", "User-Agent", "Via", "X-Forwarded-For", "X-Forwarded-Host", "X-Forwarded-Proto", "Strict-Transport-Security", "X-Frame-Options", "X-XSS-Protection", "X-Content-Type-Options", "Access-Control-Allow-Origin", "Content-Security-Policy", "Origin"]
pekko.ssl-config.enabledCipherSuites
Controls the allowed cipher suites.
pekko.ssl-config.enabledCipherSuites = ["TLS_ECDHE_RSA_WITH_AES_128_GCM_SHA256", "TLS_ECDHE_RSA_WITH_AES_256_GCM_SHA384", "TLS_ECDHE_RSA_WITH_CHACHA20_POLY1305_SHA256", "TLS_ECDHE_ECDSA_WITH_AES_128_GCM_SHA256", "TLS_ECDHE_ECDSA_WITH_AES_256_GCM_SHA384", "TLS_ECDHE_ECDSA_WITH_CHACHA20_POLY1305_SHA256", "TLS_AES_128_GCM_SHA256", "TLS_AES_256_GCM_SHA384", "TLS_CHACHA20_POLY1305_SHA256"]
pekko.ssl-config.enabledProtocols
Controls the allowed TLS protocols.
pekko.ssl-config.enabledProtocols = ["TLSv1.2"]
play.filters.enabled += "play.filters.cors.CORSFilter"
Enables CORS.
N/A
play.filters.cors
Controls CORS settings.
play.filters.cors { pathPrefixes = ["/workflow"] allowedOrigins = ["https://www.example.com", ...] allowedHttpMethods = ["GET", "POST", "PUT", "DELETE", "HEAD", "OPTIONS"] allowedHttpHeaders = ["Accept", "Accept-Language", "Content-Language", "Content-Type"] preflightMaxAge = 1 day }
play.http.parser.maxDiskBuffer
Controls the maximum file size for attachments.
play.http.parser.maxDiskBuffer = 500m
play.http.parser.maxMemoryBuffer
Controls the maximum allowable POST body size.
play.http.parser.maxMemoryBuffer = 2m
play.server.pekko.http2.enabled
Controls whether HTTP/2 is used by Workflow Manager. By default, this property is set to true.
play.server.pekko.http2.enabled = false
concurrency.activeConnectionLimit
Controls the number of active concurrent connections allowed.
concurrency.activeConnectionLimit = 75
concurrency.queuedConnectionLimit
Controls the number of queued concurrent connections allowed.
concurrency.queuedConnectionLimit = 6000
Geoprocessing tool names that match Arcade expressions
If the name of a geoprocessing tool matches the name of an ArcGIS Arcade expression, such as Buffer or Clip, uncomment allowedList and add tool names that should not be evaluated as Arcade expressions. Alternatively, you can enclose the tool name in single or double quotation marks in the Run Pro GP Tool step's configuration.
Configure a high-availability deployment
For highly available Workflow Manager deployments, you must configure each machine to enable high availability.
When you federate the ArcGIS Server machines where Workflow Manager Server is installed with your ArcGIS Enterprise portal, set the Administration URL so that it can communicate with all servers in the site.
  1. Open the %ProgramData%\esri\workflowmanager\WorkflowManager.conf file in a text editor.
  2. Open the ~/.esri/WorkflowManager/<hostname>/workflowManager.conf file in a text editor.
  3. Uncomment the following lines:
    play.modules.disabled += "esri.workflow.utils.inject.LocalDataProvider"
    play.modules.enabled += "esri.workflow.utils.inject.DistributedDataProvider"
    If these lines don't exist in the WorkflowManager.conf file, add them to the bottom of the file.
    If these lines don't exist in the workflowManager.conf file, add them to the bottom of the file.
  4. Optionally, uncomment the following lines to allocate concurrent connections for Workflow Manager Server:
    concurrency.activeConnectionLimit = 85
    Workflow Manager Server limits active concurrent connections to 85 for single-machine deployments by default. In highly available deployments, you must allocate the concurrent connections equally between each Workflow Manager Server machine.
  5. Save the file.
  6. Restart the ArcGIS Workflow Manager Server service using the Windows Services console.
  7. Restart the ArcGIS Workflow Manager Server service.
  8. Repeat the steps for each Workflow Manager Server machine.
    Workflow Manager Server is now configured for high availability.
Sample configuration file
Use the following sample Workflow Manager configuration file as a template:
# Workflow Manager configuration settings
# Set any user-defined configuration options in this file
include "application.conf"
wmx {
  logRetentionPeriod = 7 days
  // Note: Using unsecured webhooks will allow anyone that can access the webhook URL to create jobs
//  webRequestAllowLocal = true
//  webRequestAllowedProtocols = ["http", "https"]
//  webRequestBlockedHosts = ["169.254.169.254/32"]
//  webRequestBlockedPorts = []
//  webRequestEnforceValidDomain = false
//  webRequestRestrictedHeaders = ["Content-Length", "Content-Location", "Forwarded", "From", "Host", "Referer", "Referer-Policy", "User-Agent", "Via", "X-Forwarded-For", "X-Forwarded-Host", "X-Forwarded-Proto", "Strict-Transport-Security", "X-Frame-Options", "X-XSS-Protection", "X-Content-Type-Options", "Access-Control-Allow-Origin", "Content-Security-Policy", "Origin"]
// Uncomment to modify the allowedList of GP Tool names that are also Arcade functions
// wmx.steps.proGP {
//   allowedList = []
// The following settings can be used to modify security settings
// Uncomment this to modify the allowed cipher suites. Can use same options as ArcGIS Server
//pekko.ssl-config.enabledCipherSuites = [
//  "TLS_ECDHE_RSA_WITH_AES_128_GCM_SHA256",
//  "TLS_ECDHE_RSA_WITH_AES_256_GCM_SHA384",
//  "TLS_ECDHE_RSA_WITH_CHACHA20_POLY1305_SHA256",
//  "TLS_ECDHE_ECDSA_WITH_AES_128_GCM_SHA256",
//  "TLS_ECDHE_ECDSA_WITH_AES_256_GCM_SHA384",
//  "TLS_ECDHE_ECDSA_WITH_CHACHA20_POLY1305_SHA256",
//  "TLS_AES_128_GCM_SHA256",
//  "TLS_AES_256_GCM_SHA384",
//  "TLS_CHACHA20_POLY1305_SHA256"
// Uncomment this to modify the allowed TLS protocols
//pekko.ssl-config.enabledProtocols = [
//  "TLSv1.2",
//  // "TLSv1.1", // Deprecated - only use if absolutely required
//  // "TLSv1" // Deprecated - only use if absolutely required
// Uncomment this to enable CORS
//play.filters.enabled += "play.filters.cors.CORSFilter"
//play.filters.cors {
//  pathPrefixes = ["/workflow"]
//  allowedOrigins = ["https://www.example.com", ...]
//  allowedHttpMethods = ["GET", "POST", "PUT", "DELETE", "HEAD", "OPTIONS"]
//  allowedHttpHeaders = ["Accept", "Accept-Language", "Content-Language", "Content-Type"]
//  preflightMaxAge = 1 day
// Uncomment the following lines to configure site to support multi-machine deployments
// play.modules.disabled += "esri.workflow.utils.inject.LocalDataProvider"
// play.modules.enabled += "esri.workflow.utils.inject.DistributedDataProvider"
// This can be used to change the maximum file size for attachments.
// If file sizes larger than 500MB are required, the hosted feature layer for the workflow item will also
// need to be updated in addition to this parameter. See the Workflow Manager documentation for more information.
// play.http.parser.maxDiskBuffer = 500m
// This can be used to change the max allowable POST body size
//play.http.parser.maxMemoryBuffer = 2m
// Note this line is added to modify the default value from 85 to 75 for active concurrent connection against the hosted feature server from Workflow Manager server.
// Note this line is added to modify the default value from 8000 to 6000 for queued concurrent connection against the hosted feature server from Workflow Manager server.
//concurrency.queuedConnectionLimit = 6000
