LegendItem
Resumen
LegendItem provides access to legend item level information in a LegendElement.
Debate
The items property on the LegendElement class returns a list of LegendItem objects. For each legend item, you can change properties such as arrangement, patchHeight, and its visible status. The typical workflow is to iterate through the list of elements, determine the item of interest by its name property, then make the appropriate changes.
Nota:
The properties exposed to the LegendItem class do not apply to all renderer types. It is important to catch these exceptions when necessary.
Propiedades
Nombre Explicación Tipo de datos
arrangement
(Lectura y escritura)
A string that determines the legend item arrangement. The following is a valid list of values:
  • PatchLabelDescription—Patch, label, description
  • PatchDescriptionLabel—Patch, description, label
  • LabelPatchDescription—Label, patch, description
  • LabelDescriptionPatch—Label, description, patch
  • DescriptionPatchLabel—Description, patch, label
  • DescriptionLabelPatch—Description, label, patch
String
column
The column position for a legend item. The column property only applies to legends using the ManualColumns fitting strategy.
Long
name
(Solo lectura)
Returns the legend item name. The legend item name is set by modifying the layer name.
String
patchHeight
The height of a legend item patch. Units are in points.
Double
patchWidth
The width of a legend item patch. Units are in points.
Double
showFeatureCount
A Boolean that controls whether the feature count is placed next to the legend item text. The value displayed is dependent on the showVisibleFeatures setting.
Boolean
showVisibleFeatures
A Boolean that controls whether the legend item displays all values or only those values that appear in the visible extent.
Boolean
type
(Solo lectura)
Returns a value of LEGEND_ITEM.
String
visible
Returns True if the legend item is visible in the legend.
Boolean
Métodos
applyStyleItem(style_item)
Applies a StyleItem to a LegendItem.
When referencing a StyleItem using the listStyleItems method on the ArcGISProject class, the style_class parameter must be LEGEND_ITEM. For more information and code samples, refer the to StyleItem help topic.
Nota:
Styles must be added to a project prior to using the applyStyleItem method. Styles can be added using the updateStyles method on the ArcGISProject class.
style_item
A reference to a StyleItem in a project.
StyleItem
Muestra de código
LegendItem example
The following script iterates through all legend items in a legend. Its sets the patchHeight and patchWidth for all legend items, then sets showVisibleFeatures for a specific legend item.
p = arcpy.mp.ArcGISProject('current')
lyt = p.listLayouts('Layout')[0]
leg = lyt.listElements('LEGEND_ELEMENT')[0]
#Change the patch size for all legend items
#only display features in the visible map frame extent
for itm in leg.items:
  itm.patchHeight = 15
  itm.patchWidth = 30
  if itm.name == 'Geological Types':
    itm.showVisibleFeatures = True
