LegendElement
Resumen
The LegendElement class provides access to properties and methods for managing legend elements on a layout.
Debate
A LegendElement object is a specific type of MapSurroundElement layout element. It also has an association with a MapFrame object, but it has additional properties specific to legends, including access to LegendItem objects. The listElements method on the Layout object returns a Python list of page layout element objects. To return a list of LegendElement objects only, use the LEGEND_ELEMENT constant for the element_type parameter. A wildcard value can also be used to further refine the search based on the element's name value. Give each page layout element a unique name so it can be easily referenced.
You can create legends using the createMapSurroundElement method on the Layout object with map_surround_type set to LEGEND.You can specify an existing StyleItem value during creation to control how the element appears in the layout.
By default, layers added to a Map object are automatically added to a LegendElement object. This allows you to create a layout with an empty map and legend but have those items dynamically update when new layers are added to the map. There are several properties that start with 'sync' that allow you to control how items are added to a legend. You can also use the fittingStrategy and columnCount properties to control the appearance of the legend.
The elementPositionX and elementPositionY values are based on the element's anchor position, which is set on the Format tab. If you want a LegendElement object to grow downward when layers are added, set the anchor position to the upper left. You can change the position using the setAnchor method.
The items property will return a list of LegendItem classes that can be individually modified to further customize the contents of a legend. The LegendElement class also provides AddItem, MoveItem, and RemoveItem methods that allow you to manage the items in a legend. Both the LegendElement and the LegendItem classes only provide access to common properties. Finer-grained access can be accomplished using Python CIM access.
Propiedades
| Nombre | Explicación | Tipo de datos |
anchor (Solo lectura) |
Returns one of the following string values that represent the current anchor position. To change the value, use the
String |
columnCount (Lectura y escritura) |
The number of specified columns in a legend. This property only applies if the |
Long |
elementHeight (Lectura y escritura) |
The height of the element in page units. |
Double |
elementPositionX (Lectura y escritura) |
The x-location of the element's anchor position. The units assigned or reported are in page units. |
Double |
elementPositionY (Lectura y escritura) |
The y-location of the element's anchor position. The units assigned or reported are in page units. |
Double |
elementRotation (Lectura y escritura) |
Rotates the element relative to the anchor position. Positive values are counterclockwise and negative values are clockwise. |
Double |
elementWidth (Lectura y escritura) |
The width of the element in page units. |
Double |
fittingStrategy (Lectura y escritura) |
A string that represents a valid fitting strategy method. The valid values are as follows:
String |
items (Solo lectura) |
Returns a list of the associated LegendItem classes. You cannot directly set this property, but you can iterate through the legend items and modify their properties. |
List |
isOverflowing (Solo lectura) |
Returns |
Boolean |
locked (Lectura y escritura) |
When set to |
Boolean |
longName (Solo lectura) |
An element's full name including group information if it exists. For example, an element named ' |
String |
mapFrame (Lectura y escritura) |
A reference to the associated MapFrame. |
MapFrame |
name (Lectura y escritura) |
The name of the element. It is important that all elements have a unique name so they can be easily referenced. |
String |
parentGroupElement (Solo lectura) |
If the element is in a group, the value returned will be a |
GroupElement |
showTitle (Lectura y escritura) |
A Boolean that controls whether the title is displayed in the legend. |
Boolean |
syncLayerOrder (Lectura y escritura) |
A Boolean that controls whether the items in the legend are in the same order as the layers in the map. |
Boolean |
syncLayerVisibility (Lectura y escritura) |
A Boolean that controls whether an item should automatically appear in the legend if it is visible in the map. |
Boolean |
syncNewLayer (Lectura y escritura) |
A Boolean that controls whether an item should automatically be added to the legend when added to the map. |
Boolean |
syncReferenceScale (Lectura y escritura) |
A Boolean that controls whether the symbols in the legend should match the scaling of the symbols in a map if a reference scale is set. |
Boolean |
title (Lectura y escritura) |
The text string that represents the legend's title. |
String |
type (Solo lectura) |
Returns a value of |
String |
visible (Lectura y escritura) |
Returns |
Boolean |
Métodos
addItem(layer, {add_position})
Allows you to add a Layer to a legend using basic placement options.
The addItem method allows you to add a layer to a legend on a layout. The default add_position adds the layer to the top of the list of legend items, therefore appears first. For more precise legend item placement, refer to the moveItem method.
layer |
A reference to a Layer object representing the layer to be added to a legend as a LegendItem. |
Layer |
add_position (Opcional) |
A constant that determines the placement of the added layer within the legend.
The default value is TOP. |
String |
Valor de retorno
| Tipo de datos | Explicación |
LegendItem |
A LegendItem object. |
applyStyleItem(style_item)
Applies a StyleItem to a LegendElement.
When referencing a StyleItem using the listStyleItems method on the ArcGISProject class, the style_class parameter must be LEGEND. For more information and code samples, refer the to StyleItem help topic.
Nota:
Styles must be added to a project prior to using the applyStyleItem method. They can be added using the updateStyles method on the ArcGISProject class.
style_item |
A reference to a |
StyleItem |
getDefinition(cim_version)
Returns a legend element's CIM definition.
For more information about working with the CIM and samples, see Python CIM access.
cim_version |
A string that represents the major version of the CIM that will be used.
String |
Valor de retorno
Object |
Returns the CIM definition for a |
moveItem(reference_item, move_item, {move_position})
Allows you to move a legend item to a specific location within a legend.
The moveItem method moves a legend item in a legend. The move_item can be moved either AFTER or BEFORE the reference_item.
reference_item |
A LegendItem object representing an existing legend item that determines the relative location where the |
LegendItem |
move_item |
A reference to a LegendItem object representing the layer to be moved. |
Layer |
move_position (Opcional) |
A constant that determines the placement of the moved layer relative to the reference layer.
The default value is BEFORE. |
String |
removeItem(remove_item)
Allows you to remove a legend item from a legend.
The removeItem method removes a single legend item from a legend.
remove_item |
A reference to a LegendItem object representing the item to be removed. |
LegendItem |
setAnchor(anchor)
The setAnchor method controls the anchor position for a LegendElement.
Setting the anchor position is helpful because you can control how the element might expand when resized. For example, the default anchor position for a legend element is TOP_LEFT_CORNER. If you change the anchor location to BOTTOM_RIGHT_CORNER, changing elementHeight will expand the element downward, and changing elementWidth will expand the element to the left.
anchor |
A string that specifies the location of the anchor position.
String |
setDefinition(definition_object)
Sets a legend element's CIM definition.
definition_object |
A modified CIM definition object originally retrieved using |
Object |
Muestra de código
The following script adds a new legend to a layout and updates several properties. Before adding a layer file, it turns off layer synchronization so the terrain color map does not appear. After the layer is added, layer synchronization is turned back on.
import arcpy
p = arcpy.mp.ArcGISProject(r'C:\Projects\YosemiteNP\Yosemite_Trails.aprx')
#Create a new legend and set legend properties
lyt = p.listLayouts('Main Attractions')[0]
mf = lyt.listElements('MapFrame_Element', 'Yose*')[0]
legSi = p.listStyleItems('ArcGIS 2D', 'LEGEND', key='*Legend 3*' )[0]
leg = lyt.createMapSurroundElement(arcpy.Point(0.75,3.5), 'LEGEND', mf, legSi, 'New Legend Element')
leg.elementWidth = 7
leg.elementHeight = 3
leg.fittingStrategy = 'AdjustFontSize'
leg.columnCount = 5
leg.title = 'Yosemite National Park'
#Add a layer file but first turn of legend layer synchronization
leg.syncNewLayer = False
lyr = arcpy.mp.LayerFile(r'C:\Projects\YosemiteNP\LayerFiles\Terrain.lyrx')
m = p.listMaps('Yosemite National Park')[0]
m.addLayer(lyr, 'BOTTOM')
leg.syncNewLayer = True
p.saveACopy(r"C:\Projects\YosemiteNP\Yosemite_Trails_OUT.aprx")
The following script sets fittingStrategy to ManualColumns and sets columnCount to 4. Next, the script builds a dictionary that includes the legend item name and the columns it will be placed into. Finally, the script iterates through each legend item and places them in the appropriate column based on the dictionary values.
import arcpy, os, sys
relpath = os.path.dirname(sys.argv[0])
p = arcpy.mp.ArcGISProject(os.path.join(relpath, 'NewMexicoGeology', 'NewMexicoGeology.aprx'))
lyt = p.listLayouts('Layout')[0]
leg = lyt.listElements('LEGEND_ELEMENT')[0]
#Change Title and fitting strategy to (4) Manual Columns
leg.fittingStrategy = 'ManualColumns'
leg.columnCount = 4
#Dictionary of item name and column pairs
legDict = {'Cretaceous' : 1,
'Mississippian' : 1,
'Tertiary' : 2,
'Silurian' : 2,
'Ordovician' : 2,
'Quaternary' : 3,
'Jurassic' : 3,
'Devonian' : 3,
'Permian': 4,
'Proterozoic' : 4,
'Other' : 4 }
#Place each legend item into the appropriate column based on name
for legItm in leg.items:
legItm.column = legDict[legItm.name]
p.saveACopy(os.path.join(relpath, 'NewMexicoGeology', 'NewMexicoGeology_OUT.aprx'))
The following script uses Python CIM access to modify the legend's title symbology and patch width. It also uses the CIM to modify the patch shape for each class in a unique value renderer.
p = arcpy.mp.ArcGISProject('current')
#Use Legend poperties to display and modify title text
leg.showTitle = True
leg.title = "Legend CIM Changes"
#CIM modifications to Title font properties and patch width
lyt_cim = lyt.getDefinition('V3')
for elm in lyt_cim.elements:
if elm.name == "Legend":
leg_cim = lyt_cim.elements[1]
leg_cim.titleSymbol.symbol.height = 30
leg_cim.titleSymbol.symbol.horizontalAlignment = 'Center'
leg_cim.titleSymbol.symbol.fontStyleName = 'Bold'
leg_cim.titleSymbol.symbol.symbol.symbolLayers[0].color.values = [255,0,0,100]
for itm in reversed(elm.items): #Done in reversed order
itm.patchWidth = 50
lyt.setDefinition(lyt_cim)
#CIM modification to layer patch shape (it affects legend items)
m = p.listMaps('Overview Map')[0]
for itm in leg.items:
lyr = m.listLayers(itm.name)[0]
if lyr.symbology.renderer.type == 'UniqueValueRenderer':
lyr_cim = lyr.getDefinition('V3')
for grp in lyr_cim.renderer.groups: #Iterate through each group
for cls in grp.classes: #Iterate through each class
cls.patch = "AreaNaturalPoly" #Called Natural area in app
lyr.setDefinition(lyr_cim)
