Layer
Resumen
Provides access to basic layer properties and methods.
Debate
Layers can be referenced from within a project using the listLayers method on the Map class or in a layer file (.lyr or .lyrx) stored on disk using the listLayers method on the LayerFile class.
The Layer object has a single, generic design to work with all layers. There are numerous types of layers, and not all of them support the same set of properties. For example, a feature layer supports a definition query, whereas a raster layer does not, but a raster catalog does. Rather than having to work with different, individual layer objects for all the possible layer types and property combinations, there are some useful properties that allow you to obtain information about a layer and its supported properties. There are many is properties that allow you to determine if a layer fits into a general category, for example, is3DLayer, isFeatureLayer, isGroupLayer, isRasterLayer, isWebLayer, and so on.
There are a few specialized layers and datasets that don't fall into one of these general categories: annotation subclasses, dimension features, terrain datasets, topology datasets, and so on. In these cases, you may need to test other properties to isolate a layer of interest before doing something to it. The supports method is available to help identify which specific layer supports which specific layer property. It gives you the ability to test whether the layer supports a property before trying to get or set its value, reducing the need for additional error trapping. For example, see the following code:
if lyr.supports("BRIGHTNESS"):
lyr.brightness = 10
The listLayers method on the Map class returns index values that are generated from top to bottom as they appear in the table of contents or as they appear in a layer file. The same applies if a group layer is within another group layer. For example, a map with a single group layer that contains three sublayers will return a list of four layer names, the group layer being the first and the three sublayers being the second, third, and fourth. There are two ways of determining if a layer is a group layer. First, you can check to see if the layer supports the isGroupLayer property. Second, you can evaluate the longName property. A layer's longName value will include the group name in addition to the layer name. For example, a layer named Layer1 in a group layer named Group1 will have a longName value of Group1\Layer1. If the name value is equal to the longName value, the layer is not inside a group layer. When working with the sublayers of composite layers, the longName property will contain both the sublayer and top-level layer name.
ArcGIS Pro can read legacy .lyr file types, but it can only save to .lyrx file types. If a .lyr file type is being referenced and the save method is called, it will be converted to a .lyrx file type but with the same file name.
A feature layer can support zero to many definition queries, but only one definition query can be active. It is also possible that one or many definition queries are present but none are active. There are a couple of ways to manage definition queries. First, you can use the definitionQuery property. If you set a unique SQL string on a layer that does not have a definition query or a layer that has multiple definition queries, the new definition query is added and it becomes the active query. If you set a SQL string on a layer that already has that same query, it sets that as the active definition query, if it is not already active. The second way to manage definition queries is to use the listDefinitionQueries and updateDefinitionQueries functions in combination. The listDefinitionQueries function returns a list of Python dictionaries that represent the properties associated with each query. The dictionary keys are name, sql, and isActive. Definition queries can be added, modified, or removed from the Python list using core Python. The dictionary isActive value can be set to True to set the active query. Again, only one query can be active. If you try setting more than one query to be active, an error will be returned. After changes are made, the updateDefinitionQueries function is used to set the new changes.
Changing a layer's data source is a common requirement. For a more detailed discussion, parameter information, scenarios, and code samples, refer to the Updating and fixing data sources help topic.
Propiedades
| Nombre | Explicación | Tipo de datos |
brightness (Lectura y escritura) |
A layer's brightness value. The default, normal brightness, is 0 percent. Enter any value between +100 percent and -100 percent. Type a plus or minus sign to the left of the value to specify whether it is above or below 0. |
Integer |
connectionProperties (Solo lectura) |
Returns a layer's data source connection information as a Python dictionary. |
Dictionary |
contrast (Lectura y escritura) |
A layer's contrast value. The default, neutral contrast, is 0 percent. Enter any value between +100 percent and -100 percent. Type a plus or minus sign to the left of the value to specify whether it is above or below 0. |
Integer |
dataSource (Solo lectura) |
Returns the complete path for the layer's data source. It includes the full workspace path and name of the dataset. For enterprise geodatabase layers, a string containing the layer's connection information is returned. Sugerencia:Enterprise geodatabase layers in an ArcGIS Pro project do not retain the path to the database connection file ( |
String |
definitionQuery (Lectura y escritura) |
A layer's definition query. If you set a unique SQL string on a layer that does not have a definition query or a layer that has multiple definition queries, the new definition query is added and it becomes the active query. If you set a SQL string on a layer that already has that same query, it simply sets that as the active definition query, if it is not already active. |
String |
elevation (Solo lectura) |
Returns a layer's |
Object |
groupType (Solo lectura) |
Returns the type of group layer. The layer must be a group layer so it is best to first check if
String |
is3DLayer (Solo lectura) |
Returns |
Boolean |
isBasemapLayer (Solo lectura) |
Returns |
Boolean |
isBroken (Solo lectura) |
Returns |
Boolean |
isFeatureLayer (Solo lectura) |
Returns |
Boolean |
isGraphicsLayer (Solo lectura) |
Returns |
Boolean |
isGroupLayer (Solo lectura) |
Returns |
Boolean |
isNetworkAnalystLayer (Solo lectura) |
Returns |
Boolean |
isNetworkDatasetLayer (Solo lectura) |
Returns |
Boolean |
isParcelFabricLayer (Solo lectura) |
Returns |
Boolean |
isRasterLayer (Solo lectura) |
Returns |
Boolean |
isSceneLayer (Solo lectura) |
Returns |
Boolean |
isTimeEnabled (Solo lectura) |
Indicates whether time is enabled on the layer. If |
Boolean |
isTopologyLayer (Solo lectura) |
Returns |
Boolean |
isWebLayer (Solo lectura) |
Returns |
Boolean |
longName (Solo lectura) |
A layer's full name including group layer and composite layer structure. |
String |
maxThreshold (Lectura y escritura) |
A layer's maximum scale threshold for maps and its maximum distance above ground for scenes. A layer will not display when zoomed in beyond the maximum scale. To clear the maximum scale, set the value to 0. Nota:Scene values represent height and are based on the elevation units defined by the source data coordinate system. |
Double |
metadata (Lectura y escritura) |
Get or set the layer's Metadata class information. Nota:Setting metadata is dependent on the |
Metadata |
minThreshold (Lectura y escritura) |
A layer's minimum scale threshold for maps and its maximum distance above ground for scenes. A layer will not display when zoomed out beyond the minimum scale. To clear the minimum scale, set the value to 0. Nota:Scene values represent height and are based on the elevation units defined by the source data coordinate system. |
Double |
name (Lectura y escritura) |
The name of a layer the way it would appear in the table of contents. Spaces can be included. It is ideal that all layers in a map have a unique name so they can be easily referenced by their names. If unique names are not possible, consider using the |
String |
pageQuery (Solo lectura) |
Returns a Python-named tuple of page query properties.
tuple |
showLabels (Lectura y escritura) |
Controls the display of labels for a layer. If set to |
Boolean |
symbology (Lectura y escritura) |
Provides access to a layer's symbology. |
Object |
time (Solo lectura) |
Returns a LayerTime object if time is enabled on the layer. |
LayerTime |
transparency (Lectura y escritura) |
A layer's transparency value. This enables you to see through a layer. Use values between |
Integer |
URI (Solo lectura) |
The Universal Resource Indicator for a layer. It is a unique identifier for a layer in a project and is sometimes required when using Python CIM access. Once a layer is added and the URI is established, the value does not change over time. For example, if you modify the layer's name, the |
String |
visible (Lectura y escritura) |
Controls the display of a layer. If set to |
Boolean |
Métodos
createLabelClass(name, expression, {sql_query}, {labelclass_language})
The createLabelClass method creates a LabelClass for a layer.
Newly added label classes may not display initially. There are two levels of settings to display labels. First, the Layer class has a property called showLabels and needs to be set to True. Second, each LabelClass has a visible property and it also needs to be set to True. Refer to the LabelClass help topic for more information and code samples.
name |
The name of the new label class. Names must be unique. |
String |
expression |
An expression to be applied. Its syntax must match the The default value is None. |
String |
sql_query (Opcional) |
An optional query that is used for restricting the features that are labeled. The default value is None. |
String |
labelclass_language (Opcional) |
The following are the supported scripting languages.
The default value is ARCADE. |
String |
Valor de retorno
| Tipo de datos | Explicación |
LabelClass |
Returns the newly created |
disableTime()
Disables time enabled properties on a Layer object.
The enableTime method can be used to re-enable time properties.
enableTime({startTimeField}, {endTimeField}, {autoCalculateTimeRange}, {timeDimension})
Enables time on a layer if it has time information.
All parameters on the enableTime method are optional. If startTimeField and endTimeField are not specified, the method will evaluate the data and attempt to come up with appropriate default values.
After running the enableTime method, the time property on the layer can be used to return a LayerTime object. If a MapFrame on a Layout contains time-enabled layers, the MapTime class can be used to access map time settings.
startTimeField (Opcional) |
The name of the field containing the start time values. If each feature has a single time field, specify that field name in the The default value is None. |
String |
endTimeField (Opcional) |
The name of the field containing the end time values. Not all layers use an end time field. If each feature has a single time field, specify that field name in the The default value is None. |
String |
autoCalculateTimeRange (Opcional) |
If set to The default value is True. |
Boolean |
timeDimension (Opcional) |
The name of the dimension containing time values when using netCDF data. The default value is None. |
String |
extrusion({extrusion_type}, {expression})
Extrudes 2D features in a layer to display 3D symbology.
Extrusion is the process of vertically stretching a flat 2D shape to create a 3D object. This provides a method to create three-dimensional symbology from two-dimensional features. Polygon and line features have all five extrusion_type options available; point features don't use MAX_HEIGHT or MIN_HEIGHT options.
extrusion_type (Opcional) |
A string that specifies the extrusion method. Setting the value to
The default value is NONE. |
String |
expression (Opcional) |
A string that defines the extrusion expression, which provides an absolute extrusion height for each feature. The default value is None. |
String |
getDefinition(cim_version)
Gets a layer's CIM definition.
CIM-level access to additional object properties was introduced at ArcGIS Pro 2.4. When you want to return an object's CIM definition, you must specify a cim_version. Esri follows the semantic versioning specification. This means that at major releases—for example, 3.0—breaking API changes are allowed. This allows Python script authors control over which version of the CIM is used during a script run if there is a possibility breaking changes may be introduced in the new version. If you are authoring scripts for ArcGIS Pro 2.x, specify the cim_version to be 'V2'. If you are authoring scripts for ArcGIS Pro 3.x, specify the cim_version to be 'V3'. Scripts authored using cim_version 'V2' will continue to work in ArcGIS Pro 3.x.
For more information about working with the CIM and samples, see Python CIM access.
cim_version |
A string that represents the major version of the CIM.
String |
Valor de retorno
Object |
Returns the CIM definition for a |
getSelectionSet()
Returns a layer's selection as a Python set of object IDs.
Valor de retorno
Set |
Returns a layer's selection as a Python set of object IDs. If no features are selected, a |
getSymbologyDefinition(cim_version)
Return a layer's CIM symbology definition.
This method can be helpful when trying to apply or modify a renderer or colorizer that is not supported in the arcpy.mp API. Refer to the Symbology help topic for more discussion and code samples. For more information about working with the CIM and samples, also see Python CIM access.
cim_version |
A string that represents the major version of the CIM that will be used.
String |
Valor de retorno
Object |
Returns the CIM symbology definition for a |
listCharts({wildcard})
Returns a Python list of chart objects in a layer.
wildcard (Opcional) |
A wildcard is based on the chart title and is not case sensitive. A combination of asterisks (*) and characters can be used to help limit the resulting list. The default value is None. |
String |
Valor de retorno
List |
Returns a Python list of chart objects in a layer. |
listDefinitionQueries({wildcard})
Returns a Python list of definition queries associated with a layer.
Definition queries can be added, modified, or removed from the Python list using standard practices. The dictionary isActive value can be set to True to set the active query. Again, only one query can be active. If you try setting more than one query to be active, an error will be returned. After changes are made, the updateDefinitionQueries function is used to set the new changes.
A wildcard is based on the query name and is not case sensitive. A combination of asterisks (*) and characters can be used to limit the resulting list. The default value is None. |
String |
Valor de retorno
List |
A Python list of dictionaries that represent the properties associated with each query. The dictionary keys are |
listLabelClasses({wildcard})
Returns a Python list of LabelClass objects in a layer.
A wildcard is based on the label class name and is not case sensitive. A combination of asterisks (*) and characters can be used to help limit the resulting list. The default value is None. |
String |
Valor de retorno
List |
Returns a Python list of LabelClass objects in a layer. |
listLayers({wildcard})
A method to search for layers within a group layer or composite layer.
The listLayers method returns a list object, even if only one layer is returned. If you want to return a reference to a Layer object, use a unique wildcard value and a list index value of 0. If the name is truly unique, it will always be the first item in a zero-based list. For example, see the following code:
lyr = grpLyr.listLayers('City Streets')[0]
It is possible that there may be layers in a group or composite layer with the same name. If this is the case, other properties may need to be used to isolate a specific layer. Properties such as a layer's datasource or definitionQuery or URI can be used to do this. It is ideal that all layers be uniquely named for easier reference.
A wildcard is based on the layer name and is not case sensitive. A combination of asterisks (*) and characters can be used to help limit the resulting list. The default value is None. |
String |
Valor de retorno
List |
Returns a Python list of |
listTables({wildcard})
A method to search for tables within a group layer.
The listTables method returns a list object, even if only one table is returned. If you want to return a reference to a Table object, use a unique wildcard value and a list index value of 0. If the name is truly unique, it will always be the first item in a zero-based list. For example, see the following code:
tab = grpLyr.listTables('2026 Census')[0]
It is possible that there may be tables in a group layer with the same name. If this is the case, other properties may need to be used to isolate a specific table. Properties such as a table's datasource or definitionQuery or URI can be used to do this. It is ideal that all tables be uniquely named for easier reference.
A wildcard is based on the table name and is not case sensitive. A combination of asterisks (*) and characters can be used to limit the resulting list. The default value is None. |
String |
Valor de retorno
List |
A Python list of Table objects in a layer. |
openTableView({show_selected})
The openTableView method opens and activates a layer's attribute table view in the application.
The table view will only open if the map view the layer is associated with is also opened in the application. If the table view is already opened but not activated, it will become activated.
Nota:
This method is designed to be run in the application using a script tool, notebook, or the Python window. It will have no effect if it is run outside of the application.
show_selected (Opcional) |
A Boolean that specifies whether all rows will be displayed in the view or only the selected rows. The default value is False. |
Boolean |
pasteProperties(source_layer, {layer_paste_properties[layer_paste_properties,...]})
The pasteProperties method pastes properties from a feature layer to another feature layer.
For more information about pasting feature layer properties, see the Copy and paste properties help topic.
source_layer |
A feature layer with the properties that will be pasted. |
Layer |
layer_paste_properties[layer_paste_properties,...] (Opcional) |
A single string or a list of strings that specify the property or properties that will be pasted. For example,
The default value is ALL. |
String |
saveACopy(file_name)
Saves a layer to a layer file (.lyrx).
If a group layer is being saved, all of the layers below it in the TOC will also be saved to the layer file (.lyrx).
file_name |
A string that includes the location and name of the output layer file ( |
String |
setDefinition(definition_object)
Sets a layer's CIM definition.
definition_object |
A modified CIM definition object originally retrieved using |
Object |
setGroupType(group_type)
The setGroupType method sets a layer's group type.
When creating group layers, the default group layer type is CHECKBOX. This style allows multiple layers in the same group to be visible at the same time. The RADIO style allows only one layer in the group to be visible at a time. The RADIO style is required when creating a thematic map series.
group_type |
A string that specifies the selection method that will be used.
String |
setPageQuery({field_name}, {match})
The setPageQuery method sets a page query filter for the layer.
Page query filters are only applied if a MapSeries is enabled on a Layout and the layer is used in the MapFrame that the map series is set to. If a field_name is not provided, the page query gets reset to None.
field_name (Opcional) |
The name of the field that contains values that match the map series page name field in the index layer. The default value is None. |
String |
match (Opcional) |
Boolean |
setSelectionSet({oidList}, {method})
Sets a layer's selection using a Python list of Object IDs.
This method provides an easy way to manage a layer's selection. To clear the selection, use the NEW selection method with an empty list or don't set any parameters.
Note: Python Lists are used for setting the oidList but Python Sets get returned from the getSelectionSet method on the Layer object.
oidList (Opcional) |
A Python list of Object IDs to use along with the appropriate selection method. The default value is None. |
List |
method (Opcional) |
A string that specifies which selection method to use.
The default value is NEW. |
String |
setSymbologyDefinition(definition_object)
Sets a layer's CIM symbology definition.
definition_object |
Object |
supports(layer_property)
Used to determine if a particular layer type supports a property on the layer object. Not all layers support the same set of properties; the supports property can be used to test if a layer supports that property before attempting to set it.
There are numerous types of layers and not all of them support the same properties. For example, a feature layer supports a definition query, whereas a raster layer does not, but a raster catalog does. Rather than creating individual layer objects for all possible layer types and property combinations, a supports method was created to help identify which layer types support which properties. The support method gives you the option of testing the property before trying to get or set its value on a layer type that doesn't support it. The supports property will return a True if a layer supports that property.
Boolean properties don't need to be tested using supports because if a layer property isn't supported for that layer type, a False value gets returned.
layer_property |
The name of a particular layer property that will be tested.
The default value is name. |
String |
Valor de retorno
Boolean |
Returns |
updateConnectionProperties(current_connection_info, new_connection_info, {auto_update_joins_and_relates}, {validate}, {ignore_case})
The updateConnectionProperties method replaces connection properties using a dictionary or a path to a workspace.
For more detailed discussion, parameter information, scenarios, and code samples, see Updating and fixing data sources.
current_connection_info |
A string that represents the workspace path or a Python dictionary that contains connection properties to the source you want to update. If an empty string or |
String |
new_connection_info |
A string that represents the workspace path or a Python dictionary that contains connection properties with the new source information. |
String |
auto_update_joins_and_relates (Opcional) |
Boolean |
validate (Opcional) |
Boolean |
ignore_case (Opcional) |
Determines whether searches will be case sensitive. By default, queries are case sensitive. To perform queries that are not case sensitive, set The default value is False. |
Boolean |
updateDefinitionQueries(definitionQueries[definitionQueries,...])
Updates a layer's collection of definition queries.
This function is typically used to apply the changes that have been made to the results returned by the listDefinitionQueries function.
definitionQueries[definitionQueries,...] |
Updates a list of dictionaries that represent the properties of each definition query. |
List |
updateLayerFromJSON(json_data)
Updates a Layer from a JSON string.
This function is intended to be used in a web tool that uses the ConvertWebMapToArcGISProject function in web map printing applications that support changing the renderer (or other properties) of dynamic web service layers. If your web tool replaces the service layers with staged vector layers after running ConvertWebMapToArcGISProject, updateLayerFromJSON will apply the renderer (or other layer properties) as specified in the webmap_json to the corresponding vector layers staged in the layout template. For more information and a code sample, see ConvertWebMapToArcGISProject.
json_data |
The layer definition in JavaScript Object Notation (JSON) format. See the |
String |
Muestra de código
The following script prints the name of each map in a project and lists the names of the layers in each map. The script also appends a (BROKEN) prefix to the layer name if it has a broken data source.
import arcpy
aprx = arcpy.mp.ArcGISProject(r"C:\Projects\YosemiteNP\Yosemite.aprx")
for m in aprx.listMaps():
print("Map: {0} Layers".format(m.name))
for lyr in m.listLayers():
if lyr.isBroken:
print("(BROKEN) " + lyr.name)
else:
print(" " + lyr.name)
del aprx
The following script clears all layer definition queries and turns off labels for all layers in a map named Yosemite National Park:
import arcpy
m = aprx.listMaps("Yosemite National Park")[0]
if lyr.supports("DEFINITIONQUERY"):
lyr.definitionQuery = ""
if lyr.supports("SHOWLABELS"):
lyr.showLabels = False
aprx.save()
del aprx
The following script adds a new definition query to a layer or sets the same query to be the active definition query if the SQL string already exists:
p = arcpy.mp.ArcGISProject('current')
m = p.listMaps()[0]
l = m.listLayers()[0]
if l.supports('DefinitionQuery'):
l.definitionQuery = "AREA > 3000000"
The following script creates a new definition query by appending a Python dictionary to the existing list queries. Because a query may already be active, it is important to first clear existing active queries before setting the new active query.
m = p.listMaps()[0]
#Get the list of definition queries
dql = l.listDefinitionQueries()
#Clear active definition queries otherwise the update will fail if there is already an active query
for dq in dql:
dq['isActive'] = False
#Create a new definition query and append it to the list
dql.append({'name': 'Appended Query', 'sql': "name = 'Lake Superior'", 'isActive': True})
#Update the definition queries with the newly modified list
l.updateDefinitionQueries(dql)
