LayerFile
Resumen
Provides access to layers in a layer file (.lyr or .lyrx) and other basic layer management methods.
Debate
The LayerFile class provides methods and properties that provide access to individual layers and tables contained in a layer file. Layer files can contain one or more layers, tables, and group layers.
ArcGIS Pro can read both .lyr and .lyrx layer file types. Changes can only be saved to a .lyrx layer file type. If you are making changes to a .lyr file, you must call the saveACopy method.
Propiedades
| Nombre | Explicación | Tipo de datos |
filePath (Solo lectura) |
Returns a string value that reports the fully qualified layer file path and file name. |
String |
metadata (Lectura y escritura) |
Get or set the layer file's Metadata class information. Note, setting metadata is dependent on the |
Metadata |
version (Solo lectura) |
Returns a string of the version based on when the project was last saved. It uses semantic versioning format: Major.Minor.Patch. |
String |
Métodos
addLayer(add_layer_or_layerfile, {add_position})
Provides the ability to add a Layer or LayerFile to a layer file (.lyrx) using basic placement options.
The addLayer method provides a way to add a layer or collection of layers to a layer file. The default add_position adds the layers using the same auto-arrange logic that places layers in a map similarly to how the Add Data button works in the application; it places each layer based on layer weight rules and geometry type. The other placement choices are either at the top or the bottom of the layer stack. For more precise layer placement control, refer to the insertLayer method.
The layer that is added can reference an already existing layer in a project or a layer file (.lyr or .lyrx) on disk. A reference to a layer can be a single layer, a group layer with multiple sublayers, or a collection of root-level layers and group layers if referencing a .lyrx file.
The way a layer appears in the table of contents (TOC) after it is added depends on the source layer and how it appears. For example, some layers are completely collapsed and do not display their symbols in the TOC. This setting is built into the layer. If a layer is collapsed, saved to a layer file, and then added to a map, the layer will be collapsed in the new map when added through addLayer.
add_layer_or_layerfile |
A reference to a Layer or LayerFile object representing the layer or layers to be added. |
Layer |
add_position (Opcional) |
A constant that determines the placement of the added layer or layers in a layer file.
The default value is AUTO_ARRANGE. |
String |
Valor de retorno
| Tipo de datos | Explicación |
List |
A Python list of Layer objects. |
addLayerToGroup(target_group_layer, add_layer_or_layerfile, {add_position})
Provides the ability to add a Layer or the contents of a LayerFile to an existing group layer in a layer file (.lyrx) using basic placement options.
The addLayerToGroup method is the only way to add a layer or collection of layers to an existing, empty group layer in a layer file. The default add_position adds the layers using the same auto-arrange logic that places layers in a map similarly to how the Add Data button works in the application; it places each layer based on layer weight rules and geometry type. The other placement choices are either at the top or the bottom of the layer stack. For more precise layer placement control, refer to the insertLayer method.
The layer that is added can reference an already existing layer in a project or reference a layer file (.lyr or .lyrx) on disk. A reference to a layer can be a single layer, a group layer with multiple sublayers, or a collection of root-level layers and group layers if referencing a .lyrx file.
The way a layer appears in the table of contents (TOC) after it is added depends on the source layer and how it appears. For example, some layers are completely collapsed and do not display their symbols in the TOC. This setting is built into the layer. If a layer is collapsed, saved to a layer file, and then added to a map, the layer will be collapsed in the new map when added through addLayerToGroup.
target_group_layer |
A reference to an existing group Layer object. |
Layer |
Layer |
A constant that determines the placement of the added layer or layers in the
String |
insertLayer(reference_layer, insert_layer_or_layerfile, {insert_position})
Provides the ability to add a Layer or LayerFile into a layer file (.lyrx) by specifying a location.
The insertLayer method is a more precise way of positioning a layer into a layer file because a reference_layer is used to specify the exact location. The layer is either added before or after the reference_layer.
If the reference_layer references a layer at the root level of a layer file, the inserted layer will be added to the root level. If the reference_layer references a layer in a group layer, the inserted layer will be added to the group.
The layer that is inserted can reference an already existing layer in a project or a layer file (.lyr or .lyrx) on disk. A reference to a layer can be a single layer, a group layer with multiple sublayers, or a collection of root-level layers and group layers if referencing a .lyrx file.
The way a layer appears in the table of contents (TOC) after it is added depends on the source layer and how it appears. For example, some layers are completely collapsed and do not display their symbols in the TOC. This setting is built into the layer. If a layer is collapsed, saved to a layer file, and then added to a map, the layer will be collapsed in the new map when added through insertLayer.
reference_layer |
A Layer object representing an existing layer that determines the location where the new layer will be inserted. |
Layer |
insert_layer_or_layerfile |
Layer |
insert_position (Opcional) |
A constant that determines the placement of the added layer or layers relative to the
The default value is BEFORE. |
String |
listBrokenDataSources()
Returns a Python list of Layer objects in a layer file that have broken connections to their original source data.
The listBrokenDataSources method always returns a Python list object even if only one broken layer or table is returned.
Valor de retorno
List |
listLayers({wildcard})
Returns a Python list of Layers in a layer file.
A layer file can contain one or many layers. If you want to reference a specific layer in the layer file, then this method is needed. It works the same way as listLayers on a map.
wildcard (Opcional) |
A wildcard is based on the layer name and is not case sensitive. A combination of asterisks (*) and characters can be used to help limit the resulting list. The default value is None. |
String |
Valor de retorno
List |
A Python list of Layer objects in a layer file. |
listTables({wildcard})
Returns a Python list of Table objects that exist within a LayerFile.
ListTables always returns a list object even if only one table is returned.
It is possible that there may be tables in a group layer with the same name. If this is the case, other properties may need to be used to isolate a specific layer. Properties such as a tables's datasource or definitionQuery or URI can be used to do this. It is ideal that all tables be uniquely named.
A wildcard is based on the table name and is not case sensitive. A combination of asterisks (*) and characters can be used to limit the resulting list. The default value is None. |
String |
Valor de retorno
List |
A Python list of Table objects in a LayerFile. |
moveLayer(reference_layer, move_layer, {insert_position})
Provides the ability to move a layer or group layer in a layer file to a specific location in the layer stack.
The moveLayer method moves a layer in a layer file. move_layer and reference_layer must reside in the same layer file.
reference_layer |
A Layer object representing an existing layer that determines the location where the new layer will be moved. |
Layer |
move_layer |
A reference to a Layer object representing the layer to be moved. |
Layer |
A constant that determines the placement of the moved layer relative to the reference layer.
String |
removeLayer(remove_layer)
Provides the ability to remove a layer from a layer file.
The removeLayer method removes a single layer or group layer from a specific layer file. If there is more than one layer that meets the criteria, only the first layer is removed unless the script iterates through each layer in a returned list.
remove_layer |
A reference to a Layer object representing the layer to be removed. |
Layer |
save()
Saves an existing layer file reference to a .lyrx file, even if the file referenced was a .lyr file.
There is a subtle difference between a reference to a layer file (.lyr or .lyrx) and a standard map layer. The save method only works when a variable references a layer file and will not work with a map layer. When a layer is loaded from a layer file it will remember the file name and use that when the save method is called. If a map layer is being referenced, a file name is not initially set, so you will need to use the saveACopy method instead. If a .lyr file type is being referenced and save is called, it will be converted to a.lyrx file type.
saveACopy(file_name)
Saves a LayerFile to a new path or file name.
Provides an option to save a LayerFile to a different file name. Newly saved layer files will always be saved to .lyrx files.
file_name |
A string used to save a |
String |
updateConnectionProperties(current_connection_info, new_connection_info, {auto_update_joins_and_relates}, {validate}, {ignore_case})
The updateConnectionProperties method replaces connection properties using a dictionary or a path to a workspace.
For more detailed discussion, parameter information, scenarios, and code samples, see Updating and fixing data sources.
current_connection_info |
A string that represents the workspace path or a Python dictionary that contains connection properties to the source you want to update. If an empty string or |
String |
new_connection_info |
A string that represents the workspace path or a Python dictionary that contains connection properties with the new source information. |
String |
auto_update_joins_and_relates (Opcional) |
If set to The default value is True. |
Boolean |
validate (Opcional) |
Boolean |
ignore_case (Opcional) |
Determines whether searches will be case sensitive. By default, queries are case sensitive. To perform queries that are not case sensitive, set The default value is False. |
Boolean |
Muestra de código
The following script prints the names of the individual layers in a layer file that have broken data sources.
import arcpy
lyrFile = arcpy.mp.LayerFile(r"C:\Projects\YosemiteNP\Yosemite.lyrx")
for lyr in lyrFile.listLayers():
if lyr.supports("datasource"):
if lyr.isBroken:
print(lyr.name)
The following script will remove all layers from a map named Yosemite National Park and add the layers that are in the layer file named Yosemite.lyrx.
import arcpy
aprx = arcpy.mp.ArcGISProject(r"C:\Projects\YosemiteNP\Yosemite.aprx")
m = aprx.listMaps("Yosemite National Park")[0]
for lyr in m.listLayers():
m.removeLayer(lyr)
lf = arcpy.mp.LayerFile(r"C:\Projects\YosemiteNP\Yosemite.lyrx")
m.addLayer(lf)
aprx.save()
del aprx
