MapSeriesExportOptions
Resumen
The MapSeriesExportOptions object represents a collection of optional properties that can be used with the export method on the MapSeries and BookmarkMapSeries objects to configure how a map series is exported.
Debate
This object is only needed if you want to export a MapSeries or BookmarkMapSeries with properties different than the default values.
The CreateExportOptions function can be used to create a MapSeriesExportOptions object if the class_type parameter is set to MAPSERIES. The returned object contains all the properties needed to configure how map series are exported.
Nota:
Currently map series objects can only be exported to JPEGFormat, PNGFormat, PDFFormat and TIFFFormat.
Propiedades
Nombre Explicación Tipo de datos
customPages
(Lectura y escritura)
A string that identifies the map series pages to be exported if the exportPages property is set to CUSTOM. For example, the following string would export 5 pages: 1, 3, 5-7. The default value is an empty string.
String
exportFileOptions
(Solo lectura)
A string constant that represents how the pages will be exported. To change this value, use the setFileExportOptions method. The default value is PDF_SINGLE_FILE.
  • PDF_MULTIPLE_FILES_PAGE_NAME—Export each map series page to an individual file and append the page name to the file name. For example, Output.PDF will become Output_LakeErie.PDF.
  • PDF_MULTIPLE_FILES_PAGE_NUMBER—Export each map series page to an individual file and append the page number to the file name. For example, Output.PDF will become Output_1.PDF.
  • PDF_SINGLE_FILE—Export all pages into a multipage, single file document.
String
exportPages
(Solo lectura)
A string constant that represents the collection of map series pages to be exported. To change this value, use the setExportPages method. The default value is ALL.
  • ALL—Export all pages in the map series.
  • CURRENT—Export the currently active page. This option only applies when running a script inside the application.
  • CUSTOM—Export a custom set of pages that is defined using the customPages property.
  • SELECTED_INDEX_FEATURES—Only export map series pages that correspond to the selected index features associated with the map series.
String
showExportCount
If set to True, you will see the status of each page being exported displayed in the Python shell. The default value is False.
Boolean
Métodos
setExportFileOptions(export_file_options)
The default value is PDF_SINGLE_FILE when exporting to PDFFormat. If you are exporting to JPEGFormat, [PNGFormat], or TIFFFormat, and you don't explicitly set this parameter, it will default to MULTIPLE_FILES_PAGE_NAME instead since only PDFFormat supports exporting multiple pages to a single file.
export_file_options
  • MULTIPLE_FILES_PAGE_NAME—Export each map series page to an individual file and append the page name to the file name. For example, Output.PDF will become Output_LakeErie.PDF.
  • MULTIPLE_FILES_PAGE_NUMBER—Export each map series page to an individual file and append the page number to the file name. For example, Output.PDF will become Output_1.PDF.
String
setExportPages(export_pages)
export_pages
String
Muestra de código
MapSeriesExportOptions example
The following script exports a MapSeries object using default PDFFormat properties but configures the MapSeriesExportOptions to export a custom set of map series pages.
p = arcpy.mp.ArcGISProject('current')
l = p.listLayouts('Layout_MS')[0]
ms = l.mapSeries
pdf = arcpy.mp.CreateExportFormat('PDF', r'c:\temp\MS_PDF.pdf')
msExOpt = arcpy.mp.CreateExportOptions('MAPSERIES')
msExOpt.setExportPages('CUSTOM')
msExOpt.customPages = '1-3'
ms.export(pdf, msExOpt)
