VehicleRoutingProblem output data types for schema version Two
The output data types containing the results from a vehicle routing problem analysis when using the VehicleRoutingProblemSchemaVersion.Two schema version are described.
Orders
The output Orders table includes a copy of the input Orders table with additional information about which route served each order, the arrival and departure times, and the order sequence.
The output Orders table also includes all fields present in the input Orders table. Fields that are updated or added to the output are described below.
Field |
Description |
Data type |
The object ID of the feature. |
ObjectID |
The name of the route to which the order is assigned. This field corresponds to the |
Text |
This indicates the sequence of the order on its assigned route. |
Long |
Specifies the violated constraints, which are set after a solve operation. Each field will contain one violation. If an order has more than one violation, the next
Learn more about troubleshooting network analyses Nota:The violated constraint field value of an unrouted order may or may not describe all its violations. If the violation is severe enough to immediately exclude the order from further consideration, the solver does so, which prevents any other violations from being discovered for that order. If a violation is encountered that doesn't automatically stop a solution from being generated, the violation is noted in the violated constraint fields, and the solver continues to consider the order. Any further violations such as these are added to the violated constraint fields until either the solver finds a violation that prematurely stops the solve process for that order or the solver finds an overall solution to the problem. |
Long |
The elapsed travel time from the previous stop to the current stop. The value is in the units specified by the |
Double |
The distance along the route from the previous stop to the current stop. The value is in the units specified by the |
Double |
The cumulative travel time for the route up to arrival at the order. The value is in the units specified by the |
Double |
The cumulative travel distance for the route up to arrival at the order. The value is in the units specified by the |
Double |
The cumulative route duration up to and including the order. The cumulative duration includes travel times as well as service and wait times at orders. The value is in the units specified by the |
Double |
The side of the vehicle the curb is on when arriving at the stop. A value of 1 means the right side of the vehicle; a value of 2 means the left side. |
Long |
The side of the vehicle the curb is on when departing from the stop. A value of 1 means the right side of the vehicle; a value of 2 means the left side. |
Long |
The time of day the route arrives at the stop. The time of day value for this field is in the time zone in which the stop is located. |
Date |
The time of day the route departs from the stop. The time of day value for this field is in the time zone in which the stop is located. |
Date |
The time of day the route arrives at the stop. This value is in coordinated universal time (UTC). |
Date |
The time of day the route departs from the stop. This value is in coordinated universal time (UTC). |
Date |
The wait time or layover at the stop. For example, a wait time is incurred when a route must wait at an order for a time window to open. The value is in the units specified by the |
Double |
The amount of time elapsed from the end of the stop's time window to the arrival of the route vehicle. The value is in the units specified by the |
Double |
The cumulative wait time from the beginning of the route up to and including the order. The value is in the units specified by the |
Double |
The cumulative violation time from the beginning of the route up to and including the order. The value is in the units specified by the |
Double |
Specifies the status of the point with respect to its location on the network and the outcome of the analysis. The possible values are the following:
Long |
Network location fields
Together, these properties describe the point on the network where the object is located. |
Depots
The output Depots table includes a copy of the input Depots table with additional information about how the depots were located on the network.
The output Depots table also includes all fields present in the input Depots table. Only fields that are added to the output are described below.
Field |
Description |
Data type |
ObjectID |
Long |
DepotVisits
When a route starts, renews (unloads or reloads), or ends at a depot, a depot visit is created. Depot visits provide information regarding why a route visited a depot and what happened there. The quantity of goods loaded on or unloaded from a vehicle at the depot is recorded in the properties of a depot visit. Additional information that is useful in interpreting a vehicle routing problem solution is also included.
The data type supports the following fields:
Field |
Description |
Data type |
ObjectID |
The name of the visited depot. This field is a foreign key to the If the route uses a virtual depot, which means the route starts or ends at an order instead of a depot, |
Text |
Specifies the reason the depot was visited. This field is constrained by a domain of values:
Long |
The name of the route containing the visit. This field is a foreign key to the |
Text |
The sequence of the visited depot on the route. The output sequence values for a route are shared across depot visits, orders, and breaks; start from 1 (at the starting depot); and are consecutive. |
Long |
The service time (such as loading or unloading) at the depot. The value is in the units specified by the |
Double |
The travel time from the preceding visit on the route to the depot. The value is in the units specified by the |
Double |
The travel distance from the preceding visit on the route to the depot. The value is in the units specified by the |
Double |
The cumulative travel time for the route up to the arrival at this depot. The value is in the units specified by the |
Double |
The cumulative travel distance for the route up to the arrival at this depot. The value is in the units specified by the |
Double |
The cumulative route duration up to and including the depot. The cumulative duration includes travel times as well as service and wait times at orders, depots, and breaks. The value is in the units specified by the |
Double |
The arrival time at the depot. The route may arrive at the depot before the beginning of the depot's time window, in which case there is wait time at the depot. When using traffic data that covers multiple time zones, the time zone for this time-of-day value is the same as the network element on which the depot is located. |
Date |
The departure time from the depot. When using traffic data that covers multiple time zones, the time zone for this time-of-day value is the same as the network element on which the depot is located. |
Date |
The date and time value indicating the arrival time in coordinated universal time (UTC) at the depot. |
Date |
The date and time value indicating the departure time in coordinated universal time (UTC) from the depot. |
Date |
The wait time at the depot. The value is in the units specified by the |
Double |
The cumulative wait time from the beginning of the route up to and including the depot. The value is in the units specified by the |
Double |
The cumulative violation time from the beginning of the route up to and including the depot. The value is in the units specified by the |
Double |
The amount (for example, volume, weight, or quantity) being loaded at the depot. If there are multiple capacities, the amounts in the |
Double |
The amount (for example, volume, weight, or quantity) being unloaded at the depot. If there are multiple capacities, the amounts in the |
Double |
Routes
This provides access to the drivers, vehicles, and route paths of a vehicle routing problem analysis.
The output Routes table includes all fields present in the input Routes table as well as additional fields describing how each route serviced the orders. Only fields that are added to the output are described below.
Field name |
Description |
Data type |
ObjectID |
Specifies the constraints violated by the route. The constraints are given as integers. The possible values are the following:
Long |
The number of orders assigned to the route. |
Long |
The total operating cost of the route, which is the sum of the following field values: |
Double |
The cost of regular work time, excluding any unpaid breaks. |
Double |
The cost of overtime work, excluding any unpaid breaks. |
Double |
The distance cost component obtained by multiplying the |
Double |
The total route duration. This includes travel times as well as service and wait times at orders, depots, and breaks. The
Double |
The total service time spent at all orders on the route. The value is in the units specified by the |
Double |
The total service time spent at all breaks on the route. The value is in the units specified by the |
Double |
The total travel time for the route. The value is in the units specified by the |
Double |
The total travel distance for the route. The value is in the units specified by the |
Double |
The starting time of the route. The route may start before the beginning of its start depot's time window, in which case there is a wait time at the starting depot. The time of day value for this attribute is in the time zone in which the starting depot is located. |
Date |
The ending time of the route. The route ends upon completion of service at the ending depot. The time of day value for this attribute is in the time zone in which the ending depot is located. |
Date |
The start time of the route in coordinated universal time (UTC). |
Date |
The end time of the route in coordinated universal time (UTC). |
Date |
The total wait time at all orders, depots, and breaks on the route. The value is in the units specified by the |
Double |
The total violation time at all orders and breaks on the route. The value is in the units specified by the |
Double |
For a route with renewals, this is equal to the number of visits to depots for the purpose of renewing a vehicle, that is, loading or unloading a vehicle. |
Long |
For a route with renewals, this is the total service time spent at all renewal visits on the route. The value is in the units specified by the |
Double |
Breaks
This describes the rest periods, or breaks, for the routes in the analysis. The output Breaks table includes the point locations where the breaks occur along the routes.
The output Breaks table includes all fields present in the input Breaks table as well as additional fields describing the location and time of the break. Only fields that are updated or added to the output are described below.
Field |
Description |
Data type |
ObjectID |
The sequence of the break on its route. |
Long |
The relative position of the break. Breaks are taken somewhere between two network locations (orders or depots). A value of 0.0 indicates that the break is taken right after service completion at the preceding network location; a value of 1.0 indicates the break is taken right before starting service at the subsequent network location; and a value between 0.0 and 1.0 indicates where along the path from the first to the second network location the break is taken. For example, 0.25 indicates that the break is taken a quarter of the way from the previous network location to the next network location. Regardless of the number of breaks between two network locations, the relative position is always reported relative to the network locations, not the other breaks. |
Double |
The travel time from the preceding order, depot, or break to this break. The value is in the units specified by the |
Double |
The travel distance from the preceding order, depot, or break to this break. The value is in the units specified by the |
Double |
The cumulative travel time for the route up to arrival at the break. The value is in the units specified by the |
Double |
The cumulative travel distance for the route up to arrival at the break. The value is in the units specified by the |
Double |
The cumulative route duration up to and including the break. The cumulative duration includes travel times as well as service and wait times at orders, depots, and breaks. The value is in the units specified by the |
Double |
The actual arrival time of the break. The route may arrive at the break before the beginning of the break's time window, in which case there is a wait time at the break. For a break with soft time windows, the route may also arrive at the break after the end of the time window, in which case there is a violation time at the break. If using a network dataset with multiple time zones, the time is reported in the time zone of the actual break location. |
Date |
The time the break is completed. If using a network dataset with multiple time zones, the time is reported in the time zone of the actual break location. |
Date |
The date and time value indicating the arrival time in coordinated universal time (UTC). |
Date |
The date and time value indicating the departure time in coordinated universal time (UTC). |
Date |
The wait time at the break. The value is in the units specified by the |
Double |
The violation time at the break. The value is in the units specified by the |
Double |
The cumulative wait time from the beginning of the route up to and including the break. The value is in the units specified by the |
Double |
The cumulative violation time from the beginning of the route up to and including the break. The value is in the units specified by the |
Double |
DirectionPoints
This is the output turn-by-turn directions for the routes calculated in the analysis, represented as point locations along the routes where specific direction events or maneuvers occur.
Field name |
Description |
Data type |
ObjectID |
The |
Long |
The sequence of the direction points for the route, starting with 1. |
Long |
Specifies the type of direction event or maneuver described by the point, designated by one of the values below.
Long |
The |
Long |
The |
Long |
The |
Long |
The directions text that will be displayed in the consuming application. |
Text |
The time the direction event occurs in coordinated universal time (UTC). |
Date |
The difference in minutes between the local time at the maneuver location and UTC time shown in the |
Double |
The name of the direction point. |
Text |
The highway exit name that appears in the directions instruction. |
Text |
The alternate source name that appears in the directions instruction. |
Text |
The name of the intersecting or cross street that appears in the directions instruction. |
Text |
The signpost branch name that appears in the directions instruction. |
Text |
The signpost toward destination name that appears in the directions instruction. |
Text |
The building level at which this direction event occurs. This value corresponds to the |
Long |
The short text that will be used as voice guidance text in the consuming application. |
Text |
The additional text, including expanded abbreviations and plurals, that will be used as voice guidance text in the consuming application. |
Text |
The bearing in degrees of the vehicle departing this point. Zero indicates north. |
Double |
DirectionLines
This is the output route lines calculated in the analysis sliced to represent each route segment between DirectionPoints events or maneuver locations.
Field name |
Description |
Data type |
ObjectID |
The |
Long |
The |
Long |
Specifies the type of direction situation described by this line, designated by one of the following values:
Long |
The length of the line segment measured in meters. |
Double |
The travel time along the line segment in minutes. |
Double |
The building level at which this direction event begins. This value corresponds to the Learn more about the directions configuration of a network dataset |
Long |
The building level at which this direction event ends. This value corresponds to the |
Long |
