HfTable
Resumen
Defines the relationship between the horizontal cost factor and the horizontal relative moving angle through a specified table file. The table file identifies the horizontal factor graph used to determine the horizontal factors.
Debate
This object is used in the Distance Accumulation and Distance Allocation Spatial Analyst tools, as well as the Path Distance, Path Distance Allocation, and Path Distance Back Link Legacy Distance tools.
Sintaxis
HfTable(inTable)
Nombre Explicación Tipo de datos
inTable
The inTable is an ASCII file with two columns on each line. The first column identifies the HRMA in degrees, and the second, the HF. Each line specifies a point. Two consecutive points produce a line segment in the HRMA-HF coordinate system. The angles must be input in ascending order. The HF factor for any HRMA angle less than the first (lowest) input value or larger than the last (largest) input value will be set to infinity. An infinite HF is represented by -1 in the ASCII file.
File
Propiedades
inTable
(Lectura y escritura)
The inTable is of an ASCII file with two columns on each line. The first column identifies the HRMA in degrees, and the second, the HF. Each line specifies a point. Two consecutive points produce a line segment in the HRMA-HF coordinate system. The angles must be input in ascending order. The HF factor for any HRMA angle less than the first (lowest) input value or larger than the last (largest) input value will be set to infinity. An infinite HF is represented by -1 in the ASCII file.
String
Muestra de código
HfTable example 1 (Python window)
Demonstrates how to create an HfTable class and use it in the DistanceAccumulation tool within the Python window.
import arcpy
from arcpy import env
from arcpy.sa import *
env.workspace = "C:/sapyexamples/data"
myHorizFactor = HfTable("hffile.txt")
outDistAccum = DistanceAccumulation("source.shp", "barrier.tif",
                                    "elev.tif", "", "", "",
                                    "horizontalRas.tif", myHorizFactor)
outDistAccum.save("C:/sapyexamples/output/distaccumhft")
HfTable example 2 (stand-alone script)
Performs a distance accumulation analysis using the HfTable class.
# Name: HfTable_Ex_02.py
# Description: Uses the HfTable object to run the
#              DistanceAccumulation tool.
# Requirements: Spatial Analyst extension
# Import system modules
import arcpy
# Set environment settings
# Set local variables
inSourceData = "sourcepts.shp"
inSurfaceRaster = "elevation.tif"
inHorizontalRaster = "horizontalRas.tif"
# Create the HfTable Object
inTable = "hffile.txt"
myHorizFactor = HfTable(inTable)
# Run PathDistance
outDistAccum = DistanceAccumulation(inSourceData,"", inSurfaceRaster,"","",
                                    "", inHorizontalRaster, myHorizFactor)
# Save the output
outDistAccum.save("C:/sapyexamples/output/distaccumhft2")
