TopoExclusion
Resumen
Defines a list of feature classes containing polygons that represent areas of data that will be excluded.
Debate
This object is used in the tool Topo To Raster.
This permits removal of elevation data from the interpolation process, typically used over dam walls and bridges, to enable interpolation of the underlying valley structure.
Data typically removed are those associated with features on the actual land surface that can interrupt accurate representation of shape and drainage structure of the true land surface.
Sintaxis
TopoExclusion(inFeatures)
| Nombre | Explicación | Tipo de datos |
inFeatures |
The input feature datasets. |
String |
Propiedades
inFeatures (Lectura y escritura) |
String |
Muestra de código
Demonstrates how to create a TopoExclusion class and use it in the TopoToRaster tool within the Python window.
import arcpy
from arcpy import env
from arcpy.sa import *
env.workspace = "C:/sapyexamples/data"
myTopoPtElev = TopoPointElevation([["spots.shp", "spot_meter"], ["spots2.shp", "elev"]])
myTopoContour = TopoContour([["contours.shp", "spot_meter"]])
myTopoBoundary = TopoBoundary(["boundary.shp"])
myTopoLake = TopoLake(["lakes.shp"])
myTopoSink = TopoSink([["sink1.shp", "elevation"], ["sink2.shp", "NONE"]])
myTopoStream = TopoStream(["streams.shp"])
myTopoCliff = TopoCliff(["cliff.shp"])
myTopoCoast = TopoCoast(["coast.shp"])
myTopoExclusion = TopoExclusion(["ignore.shp"])
outTopoToRaster1 = TopoToRaster([myTopoPtElev, myTopoContour, myTopoBoundary, myTopoLake, myTopoSink, myTopoStream, myTopoCliff, myTopoCoast, myTopoExclusion])
outTopoToRaster1.save("C:/sapyexamples/output/ttraster1")
Interpolates a surface with TopoToRaster using the TopoExclusion class as one of the input parameters.
# Name: TopoBoundary_Ex_02.py
# Description: Run TopoToRaster using all the supported objects.
# Requirements: Spatial Analyst extension
# Import system modules
import arcpy
# Set environment settings
# Create all the supported Objects
# Run TopoToRaster
outTopoToRaster = TopoToRaster([myTopoPtElev, myTopoContour, myTopoBoundary, myTopoLake, myTopoSink, myTopoStream])
# Save the output
outTopoToRaster.save("C:/sapyexamples/output/ttraster2")
