TopoSink
Resumen
Defines a list of point feature classes that represent the locations and magnitude of known topographic depressions and the fields identifying their elevation values.
Debate
This object is used in the tool Topo To Raster.
The Topo To Raster tool will not attempt to remove from the analysis any points explicitly identified as sinks. The field used should be one that stores the elevation of the legitimate sinks. If NONE is selected, only the location of the sink is used.
Sintaxis
TopoSink(inFeatures)
Nombre Explicación Tipo de datos
inFeatures
The input point feature datasets.
Optionally, you can supply the name of a field that stores the elevation values to use for the input points. The field used should be one that stores the elevation of the legitimate sink. If NONE is selected, only the location of the sink is used.
List
Propiedades
inFeatures
(Lectura y escritura)
The input feature datasets and the fields to be used for the attributes.
List
Muestra de código
TopoSink example 1 (Python window)
Demonstrates how to create a TopoSink class and use it in the TopoToRaster tool within the Python window.
import arcpy
from arcpy import env
from arcpy.sa import *
env.workspace = "C:/sapyexamples/data"
myTopoPtElev = TopoPointElevation([["spots.shp", "spot_meter"], ["spots2.shp", "elev"]])
myTopoContour = TopoContour([["contours.shp", "spot_meter"]])
myTopoBoundary = TopoBoundary(["boundary.shp"])
myTopoLake = TopoLake(["lakes.shp"])
myTopoSink = TopoSink([["sink1.shp", "elevation"], ["sink2.shp", "NONE"]])
myTopoStream = TopoStream(["streams.shp"])
myTopoCliff = TopoCliff(["cliff.shp"])
myTopoCoast = TopoCoast(["coast.shp"])
myTopoExclusion = TopoExclusion(["ignore.shp"])
outTopoToRaster1 = TopoToRaster([myTopoPtElev, myTopoContour, myTopoBoundary, myTopoLake, myTopoSink, myTopoStream, myTopoCliff, myTopoCoast, myTopoExclusion])
outTopoToRaster1.save("C:/sapyexamples/output/ttraster1")
TopoSink example 2 (stand-alone script)
Interpolates a surface with TopoToRaster using the `TopoSink`` class as one of the input parameters.
# Name: TopoBoundary_Ex_02.py
# Description: Run TopoToRaster using all the supported objects.
# Requirements: Spatial Analyst extension
# Import system modules
import arcpy
# Set environment settings
# Create all the supported Objects
# Run TopoToRaster
outTopoToRaster = TopoToRaster([myTopoPtElev, myTopoContour, myTopoBoundary, myTopoLake, myTopoSink, myTopoStream])
# Save the output
outTopoToRaster.save("C:/sapyexamples/output/ttraster2")
