VfLinear
Resumen
Defines the relationship between the vertical cost factor and the vertical relative moving angle through a linear function.
Debate
This object is used in the Distance Accumulation and Distance Allocation Spatial Analyst tools, as well as the Path Distance, Path Distance Allocation, and Path Distance Back Link Legacy Distance tools.
The vertical factor (VF) object defines the relationship between the vertical cost factor and the vertical relative moving angle (VRMA).
VF defines the vertical difficulty encountered in moving from one cell to the next.
VRMA identifies the slope angle between the FROM or processing cell and the TO cell.
The VFs are determined by a straight line in the VRMA-VF coordinate system. The line intercepts the y-axis, equitable to the VF factor, at the value associated with the zeroFactor. The slope of the line can be specified using the slope argument.
Sintaxis
VfLinear({zeroFactor}, {lowCutAngle}, {highCutAngle}, {slope})
| Nombre | Explicación | Tipo de datos |
zeroFactor (Opcional) |
The The default value is 1.0. |
Double |
lowCutAngle (Opcional) |
The VRMA degree defining the lower threshold, below which (less than) the VFs are set to infinity. The default value is -90.0. |
Double |
highCutAngle (Opcional) |
The VRMA degree defining the upper threshold, beyond which (larger than) the VFs are set to infinity. The default value is 90.0. |
Double |
slope (Opcional) |
Identifies the slope of the straight line in the VRMA-VF coordinate system. Slope is specified as the rise/run. For example, a 30-degree slope is 1/30, specified as 0.03333 (rise/run: 1 VF on the y axis / 30 degrees on the x axis); a 90-degree slope as 0.011111. The default value is 0.011111. |
Double |
Propiedades
zeroFactor (Lectura y escritura) |
The |
Double |
lowCutAngle (Lectura y escritura) |
The VRMA degree defining the lower threshold, below which (less than) the VFs are set to infinity. |
Double |
highCutAngle (Lectura y escritura) |
The VRMA degree defining the upper threshold, beyond which (larger than) the VFs are set to infinity. |
Double |
slope (Lectura y escritura) |
Identifies the slope of the straight line in the VRMA-VF coordinate system. Slope is specified as the rise over the run. For example, a 30-degree slope is 1/30, specified as 0.03333 (rise/run: 1 VF on the y axis / 30 degrees on the x axis); a 90-degree slope as 0.011111. |
Double |
Muestra de código
Demonstrates how to create a VfLinear class and use it in the DistanceAccumulation tool within the Python window.
import arcpy
from arcpy import env
from arcpy.sa import *
env.workspace = "C:/sapyexamples/data"
myVerticalFactor = VfLinear(1.0, -90.0, 90.0, 0.01111)
outDistAccum = DistanceAccumulation("Source.shp", "", "elev.tif",
"cost.tif", "elev.tif",
myVerticalFactor)
outDistAccum.save("C:/sapyexamples/output/distAccumVfL.tif")
Performs a distance accumulation analysis using the VfLinear class.
# Name: VfLinear_Ex_02.py
# Description: Uses the VfLinear object to run the
# DistanceAccumulation tool
# Requirements: Spatial Analyst extension
# Import system modules
import arcpy
# Set environment settings
# Set local variables
inSourceData = "source.shp"
inCostRaster = "costraster.tif"
inElevation = "elev.tif"
# Create the VfLinear Object
zeroFactor = 1.0
lowCutAngle = -90
highCutAngle = 90
slope = 0.01111
myVerticalFactor = VfLinear(zeroFactor, lowCutAngle, highCutAngle, slope)
# Run PathDistance
outDistAccum = DistanceAccumulation(inSourceData, "", inElevation,
inCostRaster, inElevation,
myVerticalFactor)
# Save the output
outDistAccum.save("C:/sapyexamples/output/distaccumvfL2.tif")
