Export FAA 18B Shapefiles (Aviation Tools)
Resumen
Exports one or more FAA Advisory Circular 150/5300-18B compliant shapefiles from a geodatabase that contains the Esri Airports schema.
Uso
The input workspace must contain the Esri Airports data model.
Export shapefiles will contain the schema defined in Appendix D of AC 150/5300-18B.
Duplicate features are reported as warnings. More detailed information on which features are duplicates can be found in the Results window.
Parámetros
| Etiqueta | Explicación | Tipo de datos |
Input Airport Geodatabase |
The workspace that contains the airport data. |
Workspace |
Target Folder |
The folder where the shapefiles will be written. |
Folder |
Input Feature Class (Opcional) |
A list of feature classes that will be exported to shapefiles. If no value is provided, all feature classes in the input workspace will be exported to shapefiles. |
String |
Salida derivada
Output Folder |
The updated target folder. |
Folder |
Entornos
Información de licenciamiento
- Basic: No
- Standard: Requires Airports
- Avanzado: Requires Airports
