Analyze Market Area Gap (Business Analyst Tools)
Resumen
Generates a layer that displays the gap between total customers and expected customers.
Learn more about Analyze Market Area Gap outputs
Uso
  • Ensure that the input profiles were built with the same source Business Analyst dataset that is active when using this tool.
  • The input boundary layer defines the extent of the output layer and optional report.
  • The Target Profile parameter typically defines the segmentation distribution of your customers. Target profiles can be created with the Target Marketing wizard or the Generate Customer Segmentation Profile tool.
  • The Base Profile parameter defines the segmentation distribution of your overall market. The quantity in each segment represents a user-selected base, such as households or adult population. Base profiles can be created with the Target Marketing wizard or the Generate Market Area Segmentation Profile tool.
Parámetros
Customer Layer
A point layer representing customers.
Feature Layer
Target Profile
A segmentation profile representing the segments that will be analyzed. The target profile typically represents your customer segmentation profile.
File
Base Profile
A segmentation profile representing the base profile segments that will be used for comparison. The base profile typically represents your market area segmentation profile.
File
Geography Level
The geography level that will be used to define the market area gap analysis layer.
String
Output Feature Class
The output feature class containing the market area gap analysis.
Feature Class
Target Group
A collection of segments grouped into targets. Targets represent segments that are selected based on similar characteristics—for example, segments that have high index and percent composition.
File
Core Target
A group of segments that make up a large percentage of your customer base and have an above average index, indicating likelihood to be a customer.
String
Developmental Target
A group of segments that make up a significant percentage of your customers and of the market area but do not have an above average index.
String
Boundary Layer
(Opcional)
The boundary that determines the layer extent. If no value is provided, the entire country will be used.
Feature Layer
Create report
(Opcional)
Specifies whether a gap analysis report will be created.
  • Activado—A gap analysis report will be created.
  • Desactivado—A gap analysis report will not be created. This is the default.
Boolean
Report Title
(Opcional)
The title of the report.
String
Output Report Folder
(Opcional)
The output location where the report will be saved.
Folder
Report Output Formats
(Opcional)
Specifies the format of the output report.
  • PDF—The report will be in PDF format. This is the default.
  • XLSX—The report will be in XLSX format.
  • HTML—The report will be in HTML format.
  • CSV—The report will be in CSV format.
  • PAGX—The report will be in PAGX format.
String
Salida derivada
Output Report
The output report file.
File
Entornos
Current Workspace, Data Source, Display Segment Names, Extent
Información de licenciamiento
  • Basic: Requires Business Analyst
  • Standard: Requires Business Analyst
  • Avanzado: Requires Business Analyst
