Export Segmentation Profile (Business Analyst Tools)
Resumen
Exports a segmentation profile to a table.
Uso
  • An existing segmentation profile that was built with a locally stored or installed dataset is required. This dataset must be set as the Business Analyst data source to complete the export process. If the source Business Analyst dataset is unavailable, you can export to a table by opening the profile from the Catalog pane and clicking the Export button.
  • The output table will only contain the Total Volume and Average Volumetric fields if the input profile was created with volumetric information.
  • You can export profiles to the following tabular formats:
    • Geodatabase
    • Database
    • Feature class attribute table
    • dBASE
    • Text, ASCII, and comma-separated values files (.csv)
      To use the exported table in Microsoft Excel, open the dBASE or text files in Excel and save them to the XLSX format. Alternatively, you can use the Table to Excel tool and set the exported profile as the input table.
  • Exported tables can be brought back into ArcGIS Pro for use in target marketing provided no additional columns were added. This process can be completed using the Import Segmentation Profile tool.
Parámetros
Input Profile
The segmentation file that will be exported.
File
Output Table
The name of the table that will be created.
Table
Entornos
Current Workspace, Data Source, Display Segment Names
Información de licenciamiento
  • Basic: Requires Business Analyst
  • Standard: Requires Business Analyst
  • Avanzado: Requires Business Analyst
