Generate Customer Segmentation Profile (Business Analyst Tools)
Resumen
Creates a segmentation profile with an existing customer layer.
Uso
  • The Customer Layer parameter value must be a point feature class.
  • A customer profile is a summary of segments that have been assigned to a point.
  • Each point is assigned to a standard geography that contains households or population counts for each segment, depending on the segmentation system you are using.
  • Each geography can contain households or population belonging to one or more segments. As a result, each point can be assigned to more than one segment.
  • The segment count for each point is based on the number of segments and count for each point. If there is a single segment, the count will be one for each point. If there are multiple segments, the count for each segment will be proportionally calculated.
Parámetros
Customer Layer
The input point feature class that represents existing customers.
Feature Layer
Segmentation Base
The segmentation base for the profile that will be created. Available options are provided by the segmentation dataset in use.
String
Output Profile
The name of the segmentation profile file that will be created.
File
Volume Info Field
(Opcional)
The field containing volume information from which the profile can be created. For example, you can create a profile using the sales for each customer.
Field
Entornos
Current Workspace, Data Source, Display Segment Names
Información de licenciamiento
  • Basic: Requires Business Analyst
  • Standard: Requires Business Analyst
  • Avanzado: Requires Business Analyst
