Import Survey Profiles (Business Analyst Tools)
Resumen
Imports segmentation profiles consisting of survey variable data.
Uso
  • Imported survey profiles contain count and percent values for the distribution of segments.
  • Multiple survey profiles can be selected to be imported simultaneously on the Add Data dialog box.
  • Survey profiles to be imported can only be selected from the active Business Analyst dataset. Manually constructed profiles cannot be imported with this tool.
  • When summed across all segments, survey profile values in the count column include all survey respondents in the country.
Parámetros
Profiles
The categories of survey variables that can be selected for importing as profiles.
String
Output Folder
The folder that will contain the imported profiles.
Folder
Salida derivada
Output Profiles
The output folder containing the segmentation profile project items.
File
Entornos
Current Workspace, Data Source, Display Segment Names
Información de licenciamiento
  • Basic: Requires Business Analyst
  • Standard: Requires Business Analyst
  • Avanzado: Requires Business Analyst
