An overview of the Analysis toolset
Disponible con licencia de Business Analyst.
The Analysis toolset contains analytical tools that evaluate territory solutions.
Tool
Add Level Variables
Adds a new field at the specified level.
Add Territory Barriers
Allows the addition of polygon or line features to prevent or restrict the growth of territories.
Add Territory Seed Points
Creates a point feature that is used to determine the starting point for creating territories.
Set Balance Variables
Configures variables to be used in the balancing process.
Set Territory Attribute Constraints
Sets variables for adding constraints when solving the territory solution.
Set Territory Distance Parameters
Defines the type of distance calculation or distance constraints to use when creating territories.
Set Territory Level Options
Sets options for how territory levels are created.
Solve Territories
Solves the territory solution based on specified criteria such as attribute constraints or distance constraints.
Validate Territories
Validates a territory solution for invalid territories.
Tools in the Analysis toolset
