Apply Element Values (Topographic Production Tools)
Resumen
Applies surround element values to target features.
Uso
  • The input layout must be open and active in the ArcGIS Pro project.
  • This tool supports the Guide To Numbered Features element and the Index To Streets element. The elements must have valid source layers. These layers will be used as the output feature class when updating fields values.
  • All matching features in the target feature class will be updated even if the map surround element does not display all values due to size limitations.
  • Only the visible fields that are calculated automatically from the input map surround will be displayed as a source field option in the Field Map parameter. If no fields are defined on the element, the tool will not run.
    Nota:
    The following fields are calculated automatically:
    • ID Number
    • Grid Reference
  • The following output field types are supported: Long, Short, Big Integer, Float, Double, and Text.
Parámetros
Input Layout
The layout that contains the map surround element with the values that will be applied to the target feature class.
Layout
Map Surround
The name of the map surround element that contains the values used as a data source.
String
Field Map
The field map that maps the fields from the map surround element to the target feature class.
Columnas de la tabla de valores:
  • Element Field—The field in the element that contains the values that will be applied to the feature class.
  • Output Field—The field in the target feature class that will be updated with the value from the element.
Value Table
Salida derivada
Updated Feature Class
The existing dataset where the surround element values will be copied. The default is the Map Surround parameter value's source layer.
Feature Layer
Entornos
Esta herramienta no utiliza ningún entorno de geoprocesamiento.
Información de licenciamiento
  • Basic: No
  • Standard: Requires Topographic Mapping
  • Avanzado: Requires Topographic Mapping
