Apply Feature Level Metadata (Topographic Production Tools)
Resumen
Applies values from a metadata record in the FeatureLevelMetadata table to selected features that have matching attribute fields.
Uso
  • The Metadata Favorite parameter value is a record in the FeatureLevelMetadata table. The tool will apply a record's associated values to corresponding attributes for the specified features in the Input Features parameter.
  • The FeatureLevelMetadata table is included with the ArcGIS Topographic Mapping product data files.
  • The field types in the FeatureLevelMetadata table must match the field types in the feature layers being updated. If they don't, the tool will fail with an error message indicating that the field types must match before processing.
Parámetros
Input Features
The inputs to which the Metadata Favorite parameter value will be applied.
Feature Layer
Input Metadata Table
The path to the metadata table containing the records that will be used to populate attributes.
Table View
Metadata Favorite
The record that will be used to populate attributes. The available options depend on the records available in the metadata table.
String
Salida derivada
Updated Features
The Input Features layer with updated attributes.
Feature Layer; Feature Class
Entornos
Esta herramienta no utiliza ningún entorno de geoprocesamiento.
Información de licenciamiento
  • Basic: No
  • Standard: Requires Topographic Mapping
  • Avanzado: Requires Topographic Mapping
