Calculate Max Elevation Figures (Topographic Production Tools)
Resumen
Calculates the maximum elevation figures (MEF) for each polygon cell or quadrangle in a polygon layer. These values are used as labels for the MEF feature layer.
To derive the highest obstruction value, the tool uses terrain data from a digital elevation model (DEM) and vertical obstruction data from a point feature class. You can calculate MEF values for a Joint Operations Graphic (JOG), Operational Navigation Chart (ONC), Tactical Pilotage Chart (TPC) grid cells, NATO STANAG-3591 Edition 6, or any other polygon grid features.
Uso
  • This tool will modify existing features by updating selected fields.
  • To label the maximum elevation figures in the MEF feature layer by applying the label expression, complete the following steps:
    1. Run the Calculate Max Elevation Figures tool on the MEF feature layer.
    2. Right-click the MEF feature layer in the Contents pane, and click Labeling Properties .
      The Label Class pane appears.
    3. Ensure that the Label expression tab is active.
    4. For Language, choose Python.
    5. Load the expression below into the Expression window. Change all [MEF_VALUE] occurrences to the name of the mef_field.
      def FindLabel([MEF_VALUE]):
          if len(str([MEF_VALUE]))< 3:
              label = '0<SUP>0</SUP>'
          elif len(str([MEF_VALUE])) < 4:
              label = '0<SUP>{0}</SUP>'.format(str([MEF_VALUE])[-3])
          elif len(str([MEF_VALUE])) == 4:
              label = '{0}<SUP>{1}</SUP>'.format(str([MEF_VALUE])[0], str([MEF_VALUE])[-3])
          else:
              label = '{0}<SUP>{1}</SUP>'.format(str([MEF_VALUE])[0:-3], str([MEF_VALUE])[-3])
          return label
    6. Click Verify to validate the label expression.
    7. Click Apply.
    8. With the MEF feature layer active, click the Labeling tab.
    9. In the Layer group, click Enable Labeling .
    The label appears on the maximum elevation figures in the MEF feature layer.
Parámetros
Target Max Elevation Figures Features
The input polygon features representing the quadrangle or cell that will be updated with MEF values.
Feature Layer
Input Terrain
The input terrain that will be used to determine elevation values in an MEF feature cell. If a point feature layer is used, elevation values are obtained from the field defined in the Terrain Elevation Field parameter.
Raster Layer; Mosaic Layer; Feature Layer
Vertical Obstruction Features
The layers that will be used to identify the highest human-made structure in a cell. This is a value table defining features, elevation fields, and elevation units.
Columnas de la tabla de valores:
  • Features—The layers that will be used to identify the highest human-made structure in a cell.
  • Elevation Field—The elevation field from a layer.
  • Elevation Unit—Specifies the units of the elevation field.
    • Centimeters—The units will be centimeters.
    • Decimeters—The units will be decimeters.
    • Feet—The units will be feet.
    • Inches—The units will be inches.
    • Kilometers—The units will be kilometers.
    • Meters—The units will be meters.
    • Miles—The units will be miles.
    • Millimeters—The units will be millimeters.
    • Nautical Miles—The units will be nautical miles.
    • Yards—The units will be yards.
Value Table
Max Elevation Figures Field
The existing field in the Target Max Elevation Figures Features parameter value where the maximum elevation figure value will be stored.
Field
Max Vertical Obstruction Field
The field in the Target Max Elevation Figures Features parameter value where the maximum vertical obstruction value will be stored.
Field
Max Terrain Field
The field in the Target Max Elevation Figures Features parameter value where the maximum elevation values from the terrain layer will be stored.
Field
Specification
Specifies the specification that will be used to calculate maximum elevation figures.
String
(Opcional)
A field in the Input Terrain parameter value that represents the elevation values for each feature. If a point feature layer is used for the Input Terrain value, this parameter is required. This parameter is inactive if a raster or mosaic layer is used as input for the Input Terrain parameter.
Field
Vertical Obstruction Allowance
(Opcional)
A vertical allowance value that will be added to each calculated MEF value. The value accounts for nonrepresented natural or manufactured features. The default is 150 feet.
Linear Unit
Vertical Obstruction Accuracy
(Opcional)
The accuracy of the vertical obstruction feature layer within a specified number of units. The default is 20 meters.
Linear Unit
Terrain Accuracy
(Opcional)
The accuracy of the terrain layer within a specified number of units. The default is 20 meters.
Linear Unit
Salida derivada
Updated Max Elevation Figures Features
The Target Max Elevation Figures Features parameter value with updated MEF values.
Feature Layer
Entornos
Current Workspace
Información de licenciamiento
  • Basic: No
  • Standard: Requires Topographic Mapping or Aviation Airports or Aviation Charting or Maritime or Bathymetry
  • Avanzado: Requires Topographic Mapping or Aviation Airports or Aviation Charting or Maritime or Bathymetry
