MapFrame
Résumé
The MapFrame object is a layout element that is used to display the contents of a map. It also provides access to layout size, positioning on the layout, basic navigation methods, and export options.
Discussion
A MapFrame is a layout element that displays the geographic information added to a map. The listElements method on the Layout object returns a Python list of layout elements. To return a list of only map frames, use the MAPFRAME_ELEMENT constant for the element_type parameter. A wildcard can also be used to further refine the search based on the element's name.
The createMapFrame method on the Layout class will also return a map frame reference.
Once a MapFrame is referenced, the properties and methods allow you to do a variety of operations. First, There are basic properties that allow your to control the size, positioning, and visibility of the map frame on the layout. Second, there are several navigation methods such as panToExtent, zoomToAllLayers, and zoomToBookmark that allow you to modify the area of interest that is displayed in the map frame. Third, the map property allows you to change or get access to the associated map. From here, you can directly manage the layers, tables and basemaps in the map and also get access to the map's camera information, which allows you to modify the area of interest even more. You can switch maps of the same dimension or different dimensions. Finally, there is an export method that allow you to export the map frame into a variety of export formats.
Conseil :
Exporting a MapFrame on a layout will produce more consistent results than trying to export a MapView outside of the application. A limitation of exporting a MapView is that map views only work with Python scripts run inside of the application. This is because the size of the window and the area of interest is only known when the application and its view panes are open. MapFrame export has all of the sizing information persisted in the element so scripts run from inside the application or run as stand-alone scripts outside the application will produce the same export result.
Propriétés
Nom Explication Type de données
altText
(Lecture et écriture)
A description of the element that can be read by assistive technology when exported to PDFFormat.
String
anchor
(Lecture seule)
Returns one of the following string values that represent the current anchor position. To change the value, use the setAnchor method.
  • BOTTOM_LEFT_CORNER—Bottom left corner position
  • BOTTOM_MID_POINT—Bottom center position
  • BOTTOM_RIGHT_CORNER—Bottom right corner position
  • CENTER_POINT—Center position
  • LEFT_MID_POINT—Left center position
  • RIGHT_MID_POINT—Right center position
  • TOP_LEFT_CORNER—Top left corner position
  • TOP_MID_POINT—Top center position
  • TOP_RIGHT_CORNER—Top right corner position
String
camera
The Camera controls the location and viewing positions of the data being displayed within a map frame.
Camera
elementHeight
The height of the map frame on the page layout. The units assigned or reported are in page units.
Double
elementPositionX
The x-location of the map frame's anchor position. The units assigned or reported are in page units.
Double
elementPositionY
The y-location of the map frame's anchor position. The units assigned or reported are in page units.
Double
elementRotation
The map frame's rotation angle in degrees. Positive values rotate clockwise and negative values rotate counterclockwise. This is the angle of the map frame on the layout, not the rotation of the data. Use the heading property on the camera to rotate the data.
Double
elementWidth
The width of the map frame on the page layout. The units assigned or reported are in page units.
Double
locked
When set to True, the element cannot be graphically selected in the layout view.
Boolean
map
The Map being displayed in the map frame.
Map
name
The name of the element. It is important that all elements have a unique name so they can be uniquely referenced using the wildcard parameter with the listElements function on the Layout object.
String
time
(Lecture seule)
Returns a MapTime object if time-enabled layers are present in the map frame. A value of None is returned if the map frame contains no time-enabled layers.
Conseil :
The enableTime method on the Layer class allows you to enable time on a layer that has time information, making access to LayerTime and MapTime properties possible.
MapTime
type
(Lecture seule)
Returns a value of MAPFRAME_ELEMENT.
String
visible
Returns True if the map frame is visible on the layout. Rather than having to move unwanted objects off the page before printing or exporting, you can turn the element's visibility on and off.
Boolean
Méthodes
addGrid(style_item)
The addGrid method adds a grid or graticule to a MapFrame using a style item.
The addGrid method adds a grid or graticule to the topmost position if grids or graticules are already present. To change the order of how the grids and graticules appear in the Contents pane, first remove all the grids or graticules using the removeGrids method. Then, add them back starting with the bottommost grid using the addGrid method and work up to the topmost position.
style_item
The reference to a grid StyleItem object using the listStyleItems method on the ArcGISProject class.
StyleItem
convertGridToFeatures(grid_name, output_geodatabase, {new_grid_name})
Converts a MapFrame grid or graticule into geodatabase features.
It is possible to have multiple grids and graticules associated with a map frame. Each one can be converted into features as long as a unique new_grid_name value is used. If the same value is used, features will be overwritten.
grid_name
The name of the grid or graticule the way it appears in the Contents pane.
String
output_geodatabase
The full path to a file geodatabase (*.gdb) or an enterprise geodatabase (*.sde) including the geodatabase name and extension.
String
new_grid_name
(Facultatif)
The new name of the group layer added to the map frame's map that will contain all the resulting feature layers. This value will also be added to the GridName field in each feature class table.
String
createBookmark({name}, {description})
The createBookmark method creates a bookmark for the map associated with the map frame using the current camera settings.
This method returns a reference to a new bookmark class. See the code example in the Bookmark class help topic.
name
(Facultatif)
An string that represents the name of the new bookmark. If a name is not provided, the default name will follow the sequencing nomenclature, for example, Bookmark, Bookmark [1], Bookmark [2].
String
description
(Facultatif)
A string that represents the bookmark's description. If not specified, the value is an empty string.
String
Valeur de retour
Type de données Explication
Bookmark
A bookmark object.
export(export_format, {display_options})
The export method exports a MapFrame using a specified export_format.
Refer to the specific export format or the DisplayOptions help topics to learn more details and get code samples.
export_format
The supported export format objects are: AIXFormat, BMPFormat, EMFFormat, EPSFormat, GIFFormat, JPEGFormat, PDFFormat, PNGFormat, SVGFormat, TGAFormat and TIFFFormat.
Object
display_options
(Facultatif)
The DisplayOptions object includes antialiasing mode options.
Object
exportToAIX(out_aix, {resolution}, {image_quality}, {compress_vector_graphics}, {image_compression}, {jpeg_compression_quality}, {embed_fonts}, {embed_color_profile}, {convert_markers})
Exports the MapFrame to Adobe Illustrator Exchange (AIX) format. AIX files can be used with the ArcGIS Maps for Adobe Creative Cloud extension or Adobe Illustrator.
Héritage :
This method is superseded by export at ArcGIS Pro 3.4 and only remains for use in legacy scripts. All enhancements and future development will only occur on the export method.
AIX is an Adobe Illustrator Exchange file exported from ArcGIS to be used with the ArcGIS Maps for Adobe Creative Cloud plug-in. When used with the plug-in, vector and raster map content is converted into editable, layered artwork for an improved editing experience in Adobe Illustrator. Once opened in Illustrator, it can be used for high-end graphic design or map finishing workflows and migrated across the other Adobe Creative Cloud applications.
out_aix
A string that represents the path and file name for the output export file.
String
resolution
(Facultatif)
A number that defines the resolution of the export file in dots per inch (dpi).
The default value is 300.
Integer
image_quality
(Facultatif)
A string that specifies output image quality, the draw resolution of map layers that draw as rasters.
  • BEST—An output image quality resample ratio of 1
  • BETTER—An output image quality resample ratio of 2
  • NORMAL—An output image quality resample ratio of 3
  • FASTER—An output image quality resample ratio of 4
  • FASTEST—An output image quality resample ratio of 5
The default value is BEST.
String
(Facultatif)
A Boolean that controls compression of vector and text portions of the output file. Image compression is defined separately.
The default value is True.
Boolean
image_compression
(Facultatif)
A string that specifies the compression scheme used to compress image or raster data in the output file.
  • ADAPTIVE—Automatically selects the best compression type for each image on the page. JPEG will be used for large images with many unique colors. DEFLATE will be used for all other images.
  • DEFLATE—A lossless data compression.
  • JPEG—A lossy data compression.
  • JPEG2000—Offers higher quality compression with smaller file size than JPEG. This compression is lossless if jpeg_compression_quality is set to 100.
  • LZW—Lempel-Ziv-Welch, a lossless data compression.
  • NONE—Compression is not applied.
  • RLE—Run-length encoded compression.
The default value is ADAPTIVE.
String
(Facultatif)
A number that controls compression quality value when image_compression is set to ADAPTIVE or JPEG. The valid range is 1 through 100. A jpeg_compression_quality of 100 provides the best quality images but creates large export files. The recommended range is between 70 and 90.
The default value is 80.
Integer
embed_fonts
(Facultatif)
A Boolean that controls the embedding of fonts in the export file. Font embedding allows text and character markers to be displayed correctly when the document is viewed on a computer that does not have the necessary fonts installed.
Boolean
embed_color_profile
(Facultatif)
If set to True, color profile information is embedded in the image's metadata.
Boolean
convert_markers
(Facultatif)
A Boolean that controls the conversion of character-based marker symbols to polygons. This allows the symbols to appear correctly if the symbol font is not available or cannot be embedded. However, setting this parameter to True disables font embedding for all character-based marker symbols, which can result in a change in their appearance.
The default value is False.
Boolean
exportToBMP(out_bmp, {resolution}, {world_file}, {bmp_color_mode}, {bmp_image_compression}, {embed_color_profile})
Exports the MapFrame to a Microsoft Windows Bitmap (BMP) format file.
Héritage :
BMP files are native Windows raster images. BMP files can store pixel data at several bit depths. BMP images are typically much larger than other formats such as JPEG or PNG.
out_bmp
A string that represents the path and file name of the output export file.
String
resolution
(Facultatif)
The default value is 96.
Integer
world_file
(Facultatif)
If set to True, a georeferenced world file is created. The file contains pixel scale information and real-world coordinate information.
Boolean
bmp_color_mode
(Facultatif)
This value specifies the number of bits used to describe color.
  • 8-BIT_ADAPTIVE_PALETTE—8-bit adaptive palette
  • 8-BIT_GRAYSCALE—8-bit grayscale
  • 24-BIT_TRUE_COLOR—24-bit true color
The default value is 24-BIT_TRUE_COLOR.
String
(Facultatif)
A string that specifies the compression scheme used to compress image or raster data in the output file. This option only applies to 8-bit bmp_color_mode options.
The default value is NONE.
String
embed_color_profile
(Facultatif)
Boolean
exportToEMF(out_emf, {resolution}, {image_quality}, {output_as_image}, {convert_markers})
Exports the MapFrame to an Enhanced Metafile (EMF) format file.
Héritage :
EMF files are native Windows graphics files that can contain a combination of vector and raster data. They are useful for embedding in Windows documents because the vector portions of the EMF file can be resized without loss of quality. However, since an EMF file does not support font embedding and is exclusively a Windows format, it is not commonly used as an interchange format between users.
out_emf
A string that represents the system path and file name of the output export file.
String
resolution
(Facultatif)
Integer
image_quality
(Facultatif)
String
output_as_image
(Facultatif)
If set to True, vector content can be saved as an image. Selecting this option for maps or layouts that contain vector layers with a high density of vertices can reduce the output file size. When exporting to PDF and this option is set to True, you cannot view PDF layers in the output.
Boolean
convert_markers
(Facultatif)
Boolean
exportToEPS(out_eps, {resolution}, {image_compression}, {image_quality}, {embed_fonts}, {output_as_image}, {convert_markers})
Exports the MapFrame to an Encapsulated PostScript (EPS) format file.
Héritage :
EPS files use the PostScript page description language to describe vector and raster objects. PostScript is the publishing industry standard for high-end graphics files, cartography, and printing. EPS files can be edited in many drawing applications or placed as a graphic in most page layout applications. EPS files support embedding of fonts so users who do not have Esri fonts installed can still view the proper symbology.
out_eps
String
resolution
(Facultatif)
Integer
image_compression
(Facultatif)
The default value is DEFLATE.
String
image_quality
(Facultatif)
  • BEST—An output image quality resample ratio of 1.
  • BETTER—An output image quality resample ratio of 2.
  • NORMAL—An output image quality resample ratio of 3.
  • FASTER—An output image quality resample ratio of 4.
  • FASTEST—An output image quality resample ratio of 5.
String
embed_fonts
(Facultatif)
Boolean
output_as_image
(Facultatif)
Boolean
convert_markers
(Facultatif)
Boolean
exportToGIF(out_gif, {resolution}, {world_file}, {gif_color_mode})
Exports the MapFrame to a Graphic Interchange Format (GIF) file.
Héritage :
GIF files are a legacy raster format for use on the web. GIFs cannot contain more than 256 colors (8-bits per pixel), which along with optional lossless RLE or LZW compression, makes them smaller than other file formats. Like PNGs, GIF files can also define a transparent color. GIFs can be generated with an accompanying world file for use as georeferenced raster data.
out_gif
String
resolution
(Facultatif)
Integer
world_file
(Facultatif)
Boolean
gif_color_mode
(Facultatif)
The default value is 8-BIT_ADAPTIVE_PALETTE.
String
exportToJPEG(out_jpg, {resolution}, {world_file}, {jpeg_color_mode}, {jpeg_quality}, {embed_color_profile})
Exports the MapFrame to the Joint Photographic Experts Group (JPEG) format.
Héritage :
JPEG files are compressed image files. They support 24-bit color and are a popular choice for use on the web because a JPEG file size is often substantially smaller than many other image formats. However, the JPEG compression algorithm is lossy and is not recommended for many map images, as line drawings, and text or icon graphics become blurred by compression artifacts. Therefore, PNG is usually a superior format for map images. JPEG files can be generated with an accompanying world file for use as georeferenced raster data.
out_jpg
String
resolution
(Facultatif)
Integer
world_file
(Facultatif)
If set to True, a georeferenced world file is created. The file contains pixel scale information and real-world coordinate information. If you export a 3D map frame, this parameter will be ignored regardless of the setting because world files are not applicable to 3D views.
Boolean
jpeg_color_mode
(Facultatif)
String
jpeg_quality
(Facultatif)
This value (0–100) controls the amount of compression applied to the output image. For JPEG, image quality is adversely affected the more compression is applied. A higher quality (highest = 100) setting will produce sharper images and larger file sizes. A lower quality setting will produce more image artifacts and smaller files.
Integer
embed_color_profile
(Facultatif)
Boolean
exportToPDF(out_pdf, {resolution}, {image_quality}, {compress_vector_graphics}, {image_compression}, {embed_fonts}, {layers_attributes}, {georef_info}, {jpeg_compression_quality}, {output_as_image}, {embed_color_profile}, {convert_markers}, {simulate_overprint})
Exports the MapFrame to a Portable Document Format (PDF) file.
Héritage :
PDF files are designed to be consistently viewable and printable across different platforms. They are commonly used for distributing documents on the web, and the format is now an official ISO standard for document interchange. PDF files are editable in many graphics applications and retain map georeference information, annotation, labeling, and feature attribute data. PDF exports support embedding of fonts and can display symbology correctly even if the user does not have Esri fonts installed.
Review the PDFDocument class to learn more about how to manage PDF files, such as appending, inserting, and setting properties.
out_pdf
String
resolution
(Facultatif)
Integer
image_quality
(Facultatif)
A string that defines the output image quality and the draw resolution of map layers that draw as rasters.
String
(Facultatif)
A Boolean that controls the compression of vector and text portions of the output file. Image compression is defined separately.
Boolean
image_compression
(Facultatif)
A string that defines the compression scheme used to compress image or raster data in the output file.
String
embed_fonts
(Facultatif)
Boolean
layers_attributes
(Facultatif)
A string that controls the inclusion of PDF layers and PDF object data (attributes) in the export file.
  • LAYERS_ONLY—Export PDF layers only.
  • LAYERS_AND_ATTRIBUTES—Export PDF layers and feature attributes.
  • NONE—No setting is applied.
The default value is LAYERS_ONLY.
String
georef_info
(Facultatif)
A Boolean that enables the export of coordinate system information for each data frame into the output PDF file.
Boolean
(Facultatif)
A number that controls the compression quality value when image_compression is set to ADAPTIVE or JPEG. The valid range is 1 through 100. A jpeg_compression_quality of 100 provides the best quality images but creates large export files. The recommended range is 70 through 90.
Integer
output_as_image
(Facultatif)
Boolean
embed_color_profile
(Facultatif)
Boolean
convert_markers
(Facultatif)
Boolean
simulate_overprint
(Facultatif)
Sometimes called soft proofing, simulating overprinting shows a representation of how overlapping areas of ink will appear when printed on a page. You set up overprinting on symbol layers.
Boolean
exportToPNG(out_png, {resolution}, {world_file}, {color_mode}, {embed_color_profile})
Exports the MapFrame to Portable Network Graphics (PNG) format.
Héritage :
PNG is a versatile raster format that can display in web browsers and when inserted into other documents. It supports high-bit-depth color and uses a lossless compression. For maps, PNG is often the best raster format, since the lossless compression keeps text and line work legible by preventing the compression artifacts that can occur in JPEG format. PNG files can also define a transparent color. PNG files can be generated with an accompanying world file for use as georeferenced raster data.
out_png
String
resolution
(Facultatif)
Integer
world_file
(Facultatif)
Boolean
color_mode
(Facultatif)
  • 32-BIT_WITH_ALPHA—32-bit with alpha
The default value is 32-BIT_WITH_ALPHA.
String
embed_color_profile
(Facultatif)
Boolean
exportToSVG(out_svg, {resolution}, {compress_to_svgz}, {image_quality}, {embed_fonts}, {output_as_image}, {convert_markers})
Exports the MapFrame to a Scalable Vector Graphics (SVG) format file.
Héritage :
The SVG format is an XML-based file format that is specifically designed for viewing on the web. An SVG file can contain both vector and raster information. Some web browsers may require a plug-in to view SVG files. Older browsers may not be able to view SVG files at all. The SVG format supports the embedding of fonts so users who do not have Esri fonts installed can view SVG exports with proper symbology. You can also produce compressed SVG files. The file extension changes to .svgz when this option is enabled.
out_svg
String
resolution
(Facultatif)
Integer
compress_to_svgz
(Facultatif)
If set to True, the output is compressed.
Boolean
image_quality
(Facultatif)
String
embed_fonts
(Facultatif)
Boolean
output_as_image
(Facultatif)
Boolean
convert_markers
(Facultatif)
Boolean
exportToTGA(out_tga, {resolution}, {world_file}, {color_mode})
Exports the MapFrame to a Truevision Graphics Adapter (TGA) format file.
Héritage :
TGA files have historically been used for content that is meant to be used in other applications (for example, image sprites for animated games) and is read and written by many popular graphic arts applications. TGA format supports multiple bit depths including 32-bit with alpha (transparency) support.
out_tga
String
resolution
(Facultatif)
Integer
world_file
(Facultatif)
Boolean
color_mode
(Facultatif)
String
exportToTIFF(out_tif, {resolution}, {world_file}, {color_mode}, {tiff_compression}, {geoTIFF_tags}, {jpeg_compression_quality}, {embed_color_profile})
Exports the MapFrame to Tagged Image File Format (TIFF).
Héritage :
TIFF files are the best choice for importing into image editing applications and are also a common GIS raster data format. However, they cannot be natively viewed by a web browser. TIFF files also support georeferencing information in GeoTIFF tags or in a separate world file for use as raster data.
out_tif
String
resolution
(Facultatif)
Integer
world_file
(Facultatif)
Boolean
color_mode
(Facultatif)
This value specifies the number of bits used to describe color. The available options are dependent on the specified Color Model set in the layout's Color Management properties.
  • 8-BIT_ADAPTIVE_PALETTE—8-bit adaptive palette. Available to RGB and CMYK.
  • 8-BIT_GRAYSCALE—8-bit grayscale. Available to RGB and CMYK.
  • 24-BIT_TRUE_COLOR—24-bit true color. Available only to RGB.
  • 32-BIT_WITH_ALPHA—32-bit with alpha. Available only to RGB.
  • 32-BIT_CMYK_TRUE_COLOR—32-bit CMYK true color. Available only to CMYK.
  • 40-BIT_CMYK_WITH_ALPHA—40-bit CMYK with alpha. Available only to CMYK.
String
tiff_compression
(Facultatif)
This value represents a compression scheme.
  • JPEG—JPEG compression.
  • PACK_BITS—Pack bits compression.
The default value is LZW.
String
geoTIFF_tags
(Facultatif)
If set to True, georeferencing tags are included in the structure of the TIFF export file. The tags contain pixel scale information and real-world coordinate information. These tags can be read by applications that support GeoTIFF format.
Boolean
(Facultatif)
This value (0–100) controls the amount of compression applied to the output image. With a JPEG image, quality is adversely affected the more compression is applied. A higher quality (highest = 100) setting will produce sharper images and larger file sizes. A lower quality setting will produce more image artifacts and smaller files.
Integer
embed_color_profile
(Facultatif)
Boolean
getDefinition(cim_version)
Returns a map frame element's CIM definition.
For more information about working with the CIM and samples, see Python CIM access.
cim_version
A string that represents the major version of the CIM that will be used.
  • V2—The 2.x version of the CIM will be used.
  • V3—The 3.x version of the CIM will be used.
String
Valeur de retour
Object
Returns the CIM definition for a MapFrame value.
getLayerExtent(layer, {selection_only}, {symbolized_extent})
Returns a layer's extent for all features or only the selected features in a layer.
The getLayerExtent method will honor a layer's definition query, so if a subset of features are queried, it will return the extent for only those features. If there are no selected features, the extent for the layer will be returned.
layer
A reference to a Layer object.
Layer
selection_only
(Facultatif)
If True, it returns the extent for selected features; if False, it returns the extent for all features.
Boolean
symbolized_extent
(Facultatif)
A value of True will return the layer's symbolized extent; otherwise, it will return the geometric extent. The symbolized extent takes into account the area the symbology covers so that it does not get cut off by the data frame's boundary.
Boolean
Valeur de retour
Extent
A geoprocessing Extent object.
panToExtent(extent)
Pans and centers the MapFrame using a new Extent object without changing the map frame's scale.
This method is perfect for situations where the MapFrame scale should not change but the location should. Rather than setting the extent and then having to reset the scale each time, panToExtent maintains the scale and centers the current map frame on the new extent.
extent
Extent
removeGrids({wildcard})
The removeGrids method removes one or more grids or graticules from a map frame.
If no wildcard value is specified, all grids and graticules will be removed from the map frame. If a wildcard value is specified, all grids or graticules that meet its condition will be removed.
wildcard
(Facultatif)
A wildcard is based on the grid or graticule name in the Contents pane and is not case sensitive. A combination of asterisks (*) and characters can be used to limit the resulting list.
The default value is None.
String
setAnchor(anchor)
The setAnchor method controls the anchor position for a MapFrame element.
Setting the anchor position is helpful because you can control how the element might expand when resized. For example, the default anchor position for a map frame element is BOTTOM_LEFT_CORNER. If you change the anchor location to TOP_RIGHT_CORNER, changing elementHeight will expand the element downward instead of upward (the default), and changing elementWidth will expand the element to the left.
anchor
A string that specifies the location of the anchor position.
  • BOTTOM_LEFT_CORNER—The anchor will be set at the bottom left corner position.
  • BOTTOM_MID_POINT—The anchor will be set at the bottom center position.
  • BOTTOM_RIGHT_CORNER—The anchor will be set at the bottom right corner position.
  • CENTER_POINT—The anchor will be set at the center position.
  • LEFT_MID_POINT—The anchor will be set at the left center position.
  • RIGHT_MID_POINT—The anchor will be set at the right center position.
  • TOP_LEFT_CORNER—The anchor will be set at the top left corner position.
  • TOP_MID_POINT—The anchor will be set at the top center position.
  • TOP_RIGHT_CORNER—The anchor will be set at the top right corner position.
String
setDefinition(definition_object)
Sets a map frame element's CIM definition.
definition_object
A modified CIM definition object originally retrieved using getDefinition.
Object
zoomToAllLayers({selection_only}, {symbolized_extent})
Modifies the MapFrame view to match the extent of all layers or selected layers in a map.
If zoomToAllLayers is used on a MapFrame with a global or local scene, the result will be a planimetric view.
selection_only
(Facultatif)
If True, it sets the extent based on the selected features; if False, it sets the extent for all features in a map.
Boolean
symbolized_extent
(Facultatif)
A value of True will return the layer's symbolized extent; otherwise, it will return the geometric extent. The symbolized extent takes into account the area the symbology covers so that it does not get cut off by the map frame's boundary.
Boolean
zoomToBookmark(bookmark)
Modifies the MapFrame view to match the view information stored with a spatial bookmark.
If a 3D bookmark is used for a MapFrame referencing a 2D Map, or the other way around, the result will be a planimetric view.
bookmark
A reference to a Bookmark object.
Bookmark
Exemple de code
MapFrame example 1
The following script sets the map frame extent in a variety of ways and exports each result to PDF. It first sets the extent using feature selection. Next it zooms to a single layer's extent and applies a slight buffer. Finally, it does the same but zooms to the extent of each feature.
import arcpy, os
aprx = arcpy.mp.ArcGISProject(r'C:\Projects\GreatLakes\GreatLakes.aprx')
m = aprx.listMaps('Map')[0]
lyr = m.listLayers('GreatLakes')[0]
lyt = aprx.listLayouts('Layout')[0]
mf = lyt.listElements('mapframe_element', 'Map Frame')[0]
#Zoom to ALL selected features and export to PDF
arcpy.SelectLayerByAttribute_management(lyr, 'NEW_SELECTION', "NAME = 'Lake Superior'")
mf.zoomToAllLayers(True)
pdf = arcpy.mp.CreateExportFormat('PDF', r'C:\Projects\GreatLakes\Selection.pdf')
mf.export(pdf)
arcpy.SelectLayerByAttribute_management(lyr, 'CLEAR_SELECTION')
#Set the map frame extent to the extent of a layer and export to PDF
mf.camera.setExtent(mf.getLayerExtent(lyr, False, True))
mf.camera.scale = mf.camera.scale * 1.1 #add a slight buffer
pdf.filePath = r'C:\Projects\GreatLakes\GreatLakesExtent.pdf'
mf.export(pdf)
#Set the map frame extent based on each feature in a layer and export to PDF
for row in arcpy.da.SearchCursor(lyr, ['SHAPE@', 'NAME']):
    mf.camera.setExtent(row[0].extent)
    pdf.filePath = os.path.join(r'C:\Projects\GreatLakes', f'{row[1]}.pdf')
    mf.export(pdf)
MapFrame example 2
The following script imports an MXD and 3DD document into a blank project. After referencing the appropriate elements, it changes each of the 2D inset maps to 3D scenes and applies the appropriate bookmarks to each map frame. Finally, the entire layout is exported to PDF.
import arcpy
p = arcpy.mp.ArcGISProject(r'C:\Projects\Blank.aprx')
#Import documents into project
p.importDocument(r'C:\Projects\YosemiteNP\Documents\Yosemite.mxd')
p.importDocument(r'C:\Projects\YosemiteNP\Documents\Yosemite_3DViews.3dd')
#Reference maps
scene = p.listMaps('Globe layers')[0]
#Reference Layout and map frames
lyt = p.listLayouts()[0]
mainMF = lyt.listElements('MapFrame_Element', 'Yosemite National Park*')[0]
inset1MF = lyt.listElements('MapFrame_Element', 'Inset1*')[0]
inset2MF = lyt.listElements('MapFrame_Element', 'Inset2*')[0]
#Convert imported 2D insets into 3D views and zoom to bookmarks
mainMF.zoomToBookmark(mainMF.map.listBookmarks('Yosemite Valley')[0])
inset1MF.map = scene
inset1MF.zoomToBookmark(inset1MF.map.listBookmarks('Yosemite Yalley (looking East)')[0])
inset2MF.map = scene
inset2MF.zoomToBookmark(inset2MF.map.listBookmarks('Yosemite Yalley (looking West)')[0])
#Export the resulting imported layout and changes to PDF
pdf = arcpy.mp.CreateExportFormat('PDF', r'C:\Projects\YosemiteNP\Example2_Export.pdf')
lyt.export(pdf)
MapFrame example 3
The following script demonstrates how to create a map frame using a Polygon geometry and a Point geometry.
p = arcpy.mp.ArcGISProject("CURRENT")
#Create a new map, layout
m = p.createMap('New Map', 'MAP')
lyt = p.createLayout(8.5, 11, 'INCH', 'New Layout')
lyt.openView()
#Create a new map frame using a polygon geometry
envCoordList = [[0.5, 5.75], [0.5, 10.5], [8, 10.5], [8, 5.75], [0.5, 5.75]]
envArray = arcpy.Array([arcpy.Point(*coords) for coords in envCoordList])
mf1 = lyt.createMapFrame(arcpy.Polygon(envArray), m, 'New MF - Poly')
#Create a new bookmark set to the map frame's default extent
bkmk = mf1.createBookmark('Default Extent', "The map's default extent")
bkmk.updateThumbnail()
#Create a new map frame using a point geometry
mf2 = lyt.createMapFrame(arcpy.Point(0.5,0.5), m, 'New MF - Point')
mf2.elementWidth = 7.5
mf2.elementHeight = 4.75
MapFrame example 4
The following script demonstrates how to use Python CIM Access to modify the border symbology of each map frame in a layout.
p = arcpy.mp.ArcGISProject('CURRENT')
lyt = p.listLayouts('Layout')[0]
lyt_cim = lyt.getDefinition('V3')
for elm in lyt_cim.elements:
    if type(elm).__name__ == 'CIMMapFrame':
        if elm.graphicFrame.borderSymbol.symbol.symbolLayers:
            sym = elm.graphicFrame.borderSymbol.symbol.symbolLayers[0]
            sym.width = 5
            sym.color.values = [255, 0, 0, 100]
        else:
            print(elm.name + ' has NO symbol layers')
lyt.setDefinition(lyt_cim)
