TGAFormat
Résumé
The TGAFormat object represents a collection of Truevision Graphics Adaptor (TGA) file properties that can be configured and used with the export method on the Layout, MapFrame, and MapView objects to create an output TGA file.
Discussion
TGA files have historically been used for content that is meant to be used in other applications (for example, image sprites for animated games) and is read and written by many popular graphic arts applications. It supports multiple bit depths including 32 bit with alpha (transparency) support.
The createExportFormat method can be used to create a TGAFormat object if the format parameter is set to TGA. The returned TGAFormat object contains all the properties associated with a generating a TGA file. These properties can be modified accordingly to produce different output results.
Propriétés
| Nom | Explication | Type de données |
clipToElements (Lecture et écriture) |
If set to |
Boolean |
colorMode (Lecture et écriture) |
A string constant that represents the number of bits to describe color in a pixel. The default value is
String |
filePath (Lecture et écriture) |
A string that represents the system path and file name, including the extension, for the exported file. |
String |
height (Lecture et écriture) |
The height, in pixels, of the map area to be exported. This property only applies when exporting a |
Double |
resolution (Lecture et écriture) |
The effective dpi of the output vector data. The default value is 96. Remarque :When exporting a |
Integer |
showSelectionSymbology (Lecture et écriture) |
Show selected features in the map or map frame as selected in the output file. Setting this value to |
Boolean |
transparentBackground (Lecture et écriture) |
If set to Remarque :Transparent backgrounds are only supported when |
Boolean |
width (Lecture et écriture) |
The width, in pixels, of the map area to be exported. This property only applies when exporting a |
Double |
Méthodes
setColorMode(color_mode)
color_mode |
Below is a list of valid strings.
String |
Exemple de code
The following script exports a layout to TGA format using default property values.
p = arcpy.mp.ArcGISProject('current')
lyt = p.listLayouts()[0]
tga = arcpy.mp.CreateExportFormat('TGA', r'C:\Temp\Output.tga')
lyt.export(tga)
