MapSeriesExportOptions
Résumé
The MapSeriesExportOptions object represents a collection of optional properties that can be used with the export method on the MapSeries and BookmarkMapSeries objects to configure how a map series is exported.
Discussion
This object is only needed if you want to export a MapSeries or BookmarkMapSeries with properties different than the default values.
The CreateExportOptions function can be used to create a MapSeriesExportOptions object if the class_type parameter is set to MAPSERIES. The returned object contains all the properties needed to configure how map series are exported.
Remarque :
Currently map series objects can only be exported to JPEGFormat, PNGFormat, PDFFormat and TIFFFormat.
Propriétés
| Nom | Explication | Type de données |
customPages (Lecture et écriture) |
A string that identifies the map series pages to be exported if the |
String |
exportFileOptions (Lecture seule) |
A string constant that represents how the pages will be exported. To change this value, use the
String |
exportPages (Lecture seule) |
A string constant that represents the collection of map series pages to be exported. To change this value, use the
String |
showExportCount (Lecture et écriture) |
If set to True, you will see the status of each page being exported displayed in the Python shell. The default value is |
Boolean |
Méthodes
setExportFileOptions(export_file_options)
The default value is PDF_SINGLE_FILE when exporting to PDFFormat. If you are exporting to JPEGFormat, [PNGFormat], or TIFFFormat, and you don't explicitly set this parameter, it will default to MULTIPLE_FILES_PAGE_NAME instead since only PDFFormat supports exporting multiple pages to a single file.
export_file_options |
The default value is PDF_SINGLE_FILE. |
String |
setExportPages(export_pages)
export_pages |
String |
Exemple de code
The following script exports a MapSeries object using default PDFFormat properties but configures the MapSeriesExportOptions to export a custom set of map series pages.
p = arcpy.mp.ArcGISProject('current')
l = p.listLayouts('Layout_MS')[0]
ms = l.mapSeries
pdf = arcpy.mp.CreateExportFormat('PDF', r'c:\temp\MS_PDF.pdf')
msExOpt = arcpy.mp.CreateExportOptions('MAPSERIES')
msExOpt.setExportPages('CUSTOM')
msExOpt.customPages = '1-3'
ms.export(pdf, msExOpt)
