MapSeries
Résumé
The MapSeries object provides access to properties and methods for managing a spatial map series.
Discussion
The arcpy.mp module supports two types of map series: spatial and bookmark. The mapSeries property on the Layout object will return a MapSeries object if a spatial map series is present, a BookmarkMapSeries object if a bookmark map series is present, or a NoneType value if a map series is not present or enabled. The MapSeries class can be used to customize individual map series pages during export. One example is with facing pages where even pages are shifted differently than odd pages to accommodate for binding space.
A new spatial map series can be created with the createSpatialMapSeries method by passing in a MapFrame object, an index_layer value, a name_field value, and other optional parameters.
The features that are displayed in a spatial map series can be further filtered using page queries where the values in the layer's specified field are matched against the current map series page name. The filter is only applied when a map series is enabled. The Layer class provides access to the pageQuery property and setPageQuery method.
Similar to the application, the map series can be exported to JPEG, PDF, PNG and TIFF file formats using the export method. These formats can also be further configured using the MapSeriesExportOptions object if non-default values are needed. When exporting a map series, all the dynamic elements associated with the map series are supported. For example, dynamic text elements—such as page name, page number, bookmark name, and more—will automatically update. If map surrounds such as legends, table frames, and chart frames are set up to use the map series constraint, those elements will also dynamically update.
Remarque :
A map series export may be limited to the formats listed above and can be further configured using MapSeriesExportOptions, but that doesn't mean you can't simulate map series export to a different format. The procedure is to update the layout with the current map series page and export the layout instead of the map series. The second code example below demonstrates how to do this.
The getDefinition and setDefinition methods provide access to CIM properties that are not exposed to the MapSeries object. For more information and code samples, see the Python CIM access help topic.
Propriétés
Nom Explication Type de données
clipToIndexFeature
(Lecture et écriture)
If set to True, Map clipLayers settings are applied to the current index feature. In order to modify or clear clipLayers on a map, clipToIndexFeature must be set to False.
Boolean
currentPageName
Represents the active or current page name for a layout that has map series enabled.
String
currentPageNumber
Represents the active or current page number for a layout that has map series enabled.
Remarque :
If the page number is set using a string defined field, currentPageNumber can be set to a string, for example, currentPageNumber = 'iv'.
Long
enabled
Represents the enabled state of the map series.
Conseil :
You should check to see if enabled is set to True before changing map series properties.
Boolean
indexLayer
(Lecture seule)
Returns a reference to the index layer in a map series-enabled layout.
Layer
mapFrame
A reference to the MapFrame that contains the index layer used to drive the map series. If you change the map frame, you might also need to reset the index layer and you should also call the refresh method
MapFrame
pageCount
(Lecture seule)
Returns the total page count for a layout that has map series enabled. This corresponds to the number of features in the index layer.
Long
pageNameField
(Lecture seule)
Returns a field object that represents the field used in the index feature class when setting up a map series.
Field
pageRow
(Lecture seule)
Returns a named tuple that provides access to the attributes for the current index feature. To return an attribute value, enter a dot followed by the field name. For example:
fieldValue = lyt.mapSeries.pageRow.Field_Name
NamedTuple
selectedIndexFeatures
(Lecture seule)
Returns a Python list of sorted page numbers that represent selected index layer features in a map series-enabled layout.
List
type
(Lecture seule)
Returns the type of map series. The possible values are:
  • SPATIAL_MAPSERIES—A spatial map series.
  • BOOKMARK_MAPSERIES—A bookmark map series.
String
Méthodes
export(export_format, {mapseries_export_options}, {display_options})
The export method exports a MapSeries using a specified export_format and optionally different mapseries_export_options or display_options.
Refer to the MapSeriesExportOptions and DisplayExportOptions help topics to learn more details and get code samples.
export_format
The supported export format objects are: JPEGFormat, PDFFormat, PNGFormat, and TIFFFormat.
Object
(Facultatif)
The MapSeriesExportOptions object that includes changes to default property values.
Object
display_options
(Facultatif)
The DisplayOptions object that includes changes to the default antialiasing property values.
Object
exportToPDF(out_pdf, {page_range_type}, {page_range_string}, {multiple_files}, {resolution}, {image_quality}, {compress_vector_graphics}, {image_compression}, {embed_fonts}, {layers_attributes}, {georef_info}, {jpeg_compression_quality}, {clip_to_elements}, {show_selection_symbology}, {output_as_image}, {embed_color_profile}, {pdf_accessibility}, {show_export_count}, {keep_layout_background}, {convert_markers}, {simulate_overprint})
Exports a specified set of pages to a Portable Document Format (PDF) file for a layout that has map series enabled.
Héritage :
This method is superseded by export at ArcGIS Pro 3.4 and only remains for use in legacy scripts. All enhancements and future development will only occur on the export method.
PDF files are designed to be consistently viewable and printable across various platforms. They are commonly used for distributing documents on the web and are a standard interchange format for content delivery. PDF files are editable in many graphics applications and retain annotation, labeling, and attribute data for map layers. PDF exports support embedding of fonts and can display symbology correctly even if the user does not have Esri fonts installed.
out_pdf
A string that represents the path and file name of the output export file.
String
page_range_type
(Facultatif)
The string value that designates how the pages will be printed.
  • ALL—All pages are exported.
  • CURRENT—The active or current page is exported.
  • RANGE—Only pages listed in the page_range_string parameter are exported.
  • SELECTED—Selected index layer features/pages are exported.
The default value is ALL.
String
page_range_string
(Facultatif)
A string that identifies the pages to be exported if the RANGE option in the page_range_type parameter is used (for example, 1, 3, 5-12). If any other page_range_type value is used, the page_range_string value will be ignored.
String
multiple_files
(Facultatif)
A string that controls how the output PDF file is created. By default, all pages are exported into a single, multipage document. The default is PDF_SINGLE_FILE.
  • PDF_MULTIPLE_FILES_PAGE_NAME—Export each map series page to an individual file and append the page name to the file name. For example, Output.PDF will become Output_LakeErie.PDF
  • PDF_MULTIPLE_FILES_PAGE_NUMBER—Export each map series page to an individual file and append the page number to the file name. For example, Output.PDF will become Output_1.PDF
  • PDF_SINGLE_FILE—Export into a multipage, single file document.
The default value is PDF_SINGLE_FILE.
String
resolution
(Facultatif)
An integer that defines the resolution of the export file in dots per inch (dpi).
The default value is 96.
Integer
image_quality
(Facultatif)
A string that defines output image quality.
  • BEST—An output image quality resample ratio of 1
  • BETTER—An output image quality resample ratio of 2
  • NORMAL—An output image quality resample ratio of 3
  • FASTER—An output image quality resample ratio of 4
  • FASTEST—An output image quality resample ratio of 5
The default value is BEST.
String
(Facultatif)
A Boolean that controls the compression of vector and text portions of the output file. Image compression is defined separately.
The default value is True.
Boolean
image_compression
(Facultatif)
A string that defines the compression scheme used to compress image or raster data in the output file.
  • ADAPTIVE—Automatically selects the best compression type for each image on the page. JPEG will be used for large images with many unique colors. DEFLATE will be used for all other images.
  • JPEG—A lossy data compression.
  • JPEG2000—Offers higher quality compression with smaller file size than JPEG. This compression is lossless if jpeg_compression_quality is set to 100.
  • DEFLATE—A lossless data compression.
  • LZW—Lempel-Ziv-Welch, a lossless data compression.
  • NONE—Compression is not applied.
  • RLE—Run-length encoded compression.
The default value is ADAPTIVE.
String
embed_fonts
(Facultatif)
A Boolean that controls the embedding of fonts in an export file. Font embedding allows text and character markers to be displayed correctly when the document is viewed on a computer that does not have the necessary fonts installed.
Boolean
layers_attributes
(Facultatif)
A string that controls the inclusion of PDF layers and PDF object data (attributes) in the export file.
  • LAYERS_ONLY—Export PDF layers only.
  • LAYERS_AND_ATTRIBUTES—Export PDF layers and feature attributes.
  • NONE—No setting is applied.
The default value is LAYERS_ONLY.
String
georef_info
(Facultatif)
A Boolean that enables the export of coordinate system information for each map frame into the output PDF file.
Boolean
(Facultatif)
A number that controls the compression quality value when image_compression is set to ADAPTIVE or JPEG. The valid range is 1 through 100. A jpeg_compression_quality of 100 provides the best quality images but creates large export files. The recommended range is 70 through 90.
The default value is 80.
Integer
clip_to_elements
(Facultatif)
If set to True, the layout is clipped to the smallest bounding box that includes all layout elements.
The default value is False.
Boolean
(Facultatif)
A Boolean that controls whether the selection symbology should be displayed in the output.
Boolean
output_as_image
(Facultatif)
If set to True, vector content can be saved as an image. Selecting this option for maps or layouts that contain vector layers with a high density of vertices can reduce the output file size. When exporting to PDF and this option is set to True, you cannot view PDF layers in the output.
Boolean
embed_color_profile
(Facultatif)
If set to True, color profile information is embedded in the image's metadata.
Boolean
pdf_accessibility
(Facultatif)
Output a tagged PDF file where text can be read by screen readers or other assistive technology. A tagged PDF file can include alt text—a text description of a graphic element that a screen reader uses to describe the element—for map frames, pictures, and chart frames.
Boolean
show_export_count
(Facultatif)
If set to True, you will see the status of each page being exported displayed in the Python shell.
Boolean
(Facultatif)
If set to True, the white background will be included in the export.
Boolean
convert_markers
(Facultatif)
A Boolean that controls the conversion of character-based marker symbols to polygons. This allows the symbols to appear correctly if the symbol font is not available or cannot be embedded. However, setting this parameter to True disables font embedding for all character-based marker symbols, which can result in a change in their appearance.
Boolean
simulate_overprint
(Facultatif)
Sometimes called soft proofing, simulating overprinting shows a representation of how overlapping areas of ink will appear when printed on a page. You set up overprinting on symbol layers.
Boolean
getDefinition(cim_version)
Returns a spatial map series' CIM definition.
For more information about working with the CIM and code samples, see Python CIM access.
cim_version
A string that represents the major version of the CIM that will be used.
  • V2—The 2.x version of the CIM will be used.
  • V3—The 3.x version of the CIM will be used.
String
Valeur de retour
Type de données Explication
Object
Returns the CIM definition for a MapSeries.
getPageNumberFromName(page_name)
Returns a Map Series page number based on the name of the page.
Many of the Map Series properties and methods use a page number value rather than the literal names of the pages used to create the index layer. The getPageNumberFromName method provides a mechanism to obtain a page number given a page name.
page_name
A page number in the index layer that corresponds to the Name field that was used to set up the Map Series.
String
ms = layout.mapSeries
pageNumber = ms.getPageNumberFromName("HarborView")
ms.currentPageNumber = pageNumber
refresh()
Refreshes an existing map series.
Use the refresh method if any of the following occurs:Features are added to or deleted from your index layer.Updates are made to the index field values.The map frame extent is changed due to zooming, panning, or change to map scale. The map series will retain the original settings in these cases until the refresh method is executed, or the project is saved and reopened.
setDefinition(definition_object)
Sets a spatial map series' CIM definition.
For more information about working with the CIM and samples, see Python CIM Access.
definition_object
A modified CIM definition object originally retrieved using getDefinition.
Object
Exemple de code
MapSeries example 1
The following script checks for the presence of a spatial map series and exports two individual pages to PDF base on the names of the pages. Because it exports one PDF at a time, the MapSeriesExportOptions class is configured to export the CURRENT page. The PDFFormat object only needs to be created once because the filePath property is changed between exports.
import arcpy, os, sys
relpath = os.path.dirname(sys.argv[0])
p = arcpy.mp.ArcGISProject(os.path.join(relpath, 'GreatLakes', 'GreatLakes.aprx'))
lyt = p.listLayouts('Layout_MS')[0]
sms = lyt.mapSeries
#Create a new PDF format and change the resolution from its default value of 96
pdf = arcpy.mp.CreateExportFormat('PDF')
pdf.resolution = 300
#Modify the map series export options to export only the current page
msOpt = arcpy.mp.CreateExportOptions('MAPSERIES')
msOpt.setExportPages('CURRENT')
if isinstance(sms, arcpy._mp.MapSeries):
  if sms.enabled:
    sms.currentPageNumber = sms.getPageNumberFromName("Lake Superior")
    pdf.filePath = os.path.join(relpath, 'Output', 'Ex1_LakeSuperior.pdf')
    sms.export(pdf, msOpt)
    sms.currentPageNumber = sms.getPageNumberFromName("Lake Huron")
    pdf.filePath = os.path.join(relpath, 'Output', 'Ex1_LakeHuron.pdf')
MapSeries example 2
The following script exports each page of a spatial map series to individual .bmp files and uses the page name of the index feature as part of the output file name.
sms = lyt.mapSeries
#Create a new PNG format that uses only defaults
bmp = arcpy.mp.CreateExportFormat('BMP')
if ((type(sms).__name__ == 'MapSeries')):
  if sms.enabled:
    for pageNum in range(1, sms.pageCount + 1):  #All pages, zero based index
      sms.currentPageNumber = pageNum
      pageName = sms.pageRow.NAME   #NAME = field name in index layer
      print(f"Exporting {pageName}")
      bmp.filePath =os.path.join(relpath,'Output', f'Ex2_{pageName}.bmp')
      lyt.export(bmp)
MapSeries example 3
The following script selects index features, exports the selected pages to one multi-page PDF, and clears the selection when complete.
sms = lyt.mapSeries
#Create a new PDF format using defaults
pdf = arcpy.mp.CreateExportFormat('PDF', os.path.join(relpath, 'Output', 'Ex3_QueriedLakes.pdf'))
#Set up optional mapseries settings to export only the current page
msOpt.setExportPages('SELECTED')
  if sms.enabled:
    indexLyr = sms.indexLayer
    arcpy.SelectLayerByAttribute_management(indexLyr, 'NEW_SELECTION','AREA > 10000')
    arcpy.SelectLayerByAttribute_management(indexLyr, 'CLEAR_SELECTION')
MapSeries example 4
The following script creates a Map object, a Layout object, and a MapFrame object. Next, it creates a spatial map series and enables map clipping by setting clipMapToIndexFeature to True. It uses Python CIM access to modify some CIM properties that are not exposed to the MapSeries object. Examples are setting the starting page number, scale rounding, and clipping the data to the map index feature. Finally, it exports the map series to a single PDF.
#Function used to create a rectangle where the anchor point is lower left corner
def MakeRec_LL(llx, lly, w, h):
    xyRecList = [[llx, lly], [llx, lly+h], [llx+w,lly+h], [llx+w,lly], [llx,lly]]
    array = arcpy.Array([arcpy.Point(*coords) for coords in xyRecList])
    rec = arcpy.Polygon(array)
    return rec
#Create a new map and add index layer
m = p.createMap('New Map', 'MAP')
lyrFile = arcpy.mp.LayerFile(os.path.join(relpath, 'GreatLakes', 'GreatLakes.lyrx'))
lyr = m.addLayer(lyrFile)[0]
#Create a layout and map frame
lyt = p.createLayout(8.5, 11, 'INCH')
mf = lyt.createMapFrame(MakeRec_LL(0.5,5.5,7.5,5), m, "New Map Frame")
#Create and export a spatial map series
sms = lyt.createSpatialMapSeries(mf, lyr, 'NAME')
sms.clipToIndexFeature = true
#Modify CIM properties
sms_cim = sms.getDefinition('V3')
sms_cim.startingPageNumber = 2
sms_cim.scaleRounding = 10000
sms.setDefinition(sms_cim)
#Export to PDF
pdf = arcpy.mp.CreateExportFormat('PDF', os.path.join(relpath, 'Output', 'Ex4_NewSMS.pdf'))
sms.export(pdf)
MapSeries example 5
The following script exports all the pages from a spatial map series to a single PDF, exports all pages from a bookmark map series to another PDF, and combines the two resulting PDFs into a single, newly created PDF.
arcpy.env.overwriteOutput = True
#Export spatial map series
sms_lyt = p.listLayouts('Layout_MS')[0]
sms = sms_lyt.mapSeries
  if sms.enabled:
      pdf = arcpy.mp.CreateExportFormat('PDF', os.path.join(relpath, 'Output', 'Temp_sms.pdf'))
      sms.export(pdf)
#Export bookmark map series
bms_lyt = p.listLayouts('Layout_BMS')[0]
bms = bms_lyt.mapSeries
if ((type(bms).__name__ == 'BookmarkMapSeries')):
  if bms.enabled:
      pdf = arcpy.mp.CreateExportFormat('PDF', os.path.join(relpath, 'Output', 'Temp_bms.pdf'))
      bms.export(pdf)
#Combine PDFs and remove temporary files
comboPDF = arcpy.mp.PDFDocumentCreate(os.path.join(relpath, 'Output', 'Ex5_Combo.pdf'))
comboPDF.appendPages(os.path.join(relpath, 'Output', 'Temp_sms.pdf'))
comboPDF.appendPages(os.path.join(relpath, 'Output', 'Temp_bms.pdf'))
comboPDF.saveAndClose()
os.remove(os.path.join(relpath, 'Output', 'Temp_sms.pdf'))
os.remove(os.path.join(relpath, 'Output', 'Temp_bms.pdf'))
