Conditional geoprocessing functions
Disponible avec une licence Spatial Analyst.
Disponible avec une licence Image Analyst.
The Conditional geoprocessing functions allow you to control the output values based on the conditions placed on the input values. The conditions that can be applied are of two types, those being either queries on the attributes or a condition based on the position of the conditional statement in a list.
The attribute query geoprocessing functions explicitly identify all cells that are evaluated as True. These cells can retain their original value, be set to another value, or be set to NoData. The cells that are evaluated as False can be set to a set of values different from the True condition. For example, if the value in the input raster is greater than ten, return one; otherwise, return 100.
  • The Con and Set Null geoprocessing functions can use a where clause as a logical expression to define the attribute query.
The positional condition requires an input parameter (either a raster or constant) specifying the position of the conditional statement (either a raster or constant) that should be used for the output. For example, if the value for a specified cell of the input raster is 1, return the value specified by the first input in the list; if a cell in the input raster is two, return the value specified by the second raster in the list, and so on.
  • The Pick geoprocessing function allows you to specify a list of inputs to provide the output value from, based on the value of the position input.
The following table lists the available geoprocessing functions and provides a brief description of each.
Geoprocessing Function
Con
Performs a conditional if/else evaluation on each of the input cells of an input raster.
Pick
The value from a position raster is used to determine from which raster in a list of input rasters the output cell value will be obtained.
Set Null
Set Null sets identified cell locations to NoData based on a specified criteria. It returns NoData if a conditional evaluation is true, and returns the value specified by another raster if it is false.
Geoprocessing functions in the Conditional category
