FuzzyLarge
Résumé
Defines a fuzzy membership function where the larger input values have membership closer to 1. The function is defined by a midpoint (which is assigned a membership of 0.5) with a defined spread.
Discussion
The tool that uses the FuzzyLarge object: FuzzyMembership.
The equation for this function is:
Fuzzy large function equation
The inputs to the equation are \(f1\), the spread, and \(f2\), the midpoint. Increasing the spread causes the fuzzy membership curve to become steeper.
This function is useful when the large input values have a higher membership.
The input values can be either integer or floating point positive values.
FuzzyLarge graph
Variations of the FuzzyLarge membership function.
Syntaxe
FuzzyLarge(midpoint, spread)
Nom Explication Type de données
midpoint
The value with a fuzzy membership of 0.5.
The default is the midpoint of the range of values of the input raster.
Double
spread
Defines the spread of the function.
The spread generally ranges from 1 to 10, with the larger the value results in a steeper distribution from the midpoint. The default value is 5.
Double
Propriétés
midpoint
(Lecture et écriture)
Defines the midpoint for the membership function.
Double
spread
Defines the spread of the membership function.
The larger the value results in a steeper distribution from the midpoint.
Double
Exemple de code
FuzzyLarge example 1 (Python window)
Demonstrates how to create a FuzzyLarge class and use it in the FuzzyMembership tool within the Python window.
import arcpy
from arcpy.sa import *
from arcpy import env
env.workspace = "c:/sapyexamples/data"
outFzyMember = FuzzyMembership("as_std", FuzzyLarge(12, 5))
outFzyMember.save("c:/sapyexamples/fzymemb")
FuzzyLarge example 2 (stand-alone script)
Performs a FuzzyMembership using the FuzzyLarge class.
# Name: FuzzyLarge_Ex_02.py
# Description: Scales input raster data into values ranging from zero to one
#     indicating the strength of a membership in a set.
# Requirements: Spatial Analyst extension
# Import system modules
import arcpy
# Set environment settings
env.workspace = "C:/sapyexamples/data"
# Set local variables
inRaster = "as_std"
# Create the FuzzyLarge algorithm object
midpoint = 15
spread = 5
myFuzzyAlgorithm = FuzzyLarge(midpoint, spread)
# Run FuzzyMembership
outFuzzyMember = FuzzyMembership(inRaster, myFuzzyAlgorithm)
# Save the output
outFuzzyMember.save("c:/sapyexamples/fzylarge")
