FuzzyMSSmall
Résumé
Defines a fuzzy membership through a function based on the mean and standard deviation, with the smaller values having a membership closer to 1.
Discussion
The tool that uses the FuzzyMSSmall object: Fuzzy Membership.
There are two equations for this function, depending on the product of \(a * m\).
If \(x > a * m\):
\(u(x) = \Large \frac {(b * s)}{(x - (a * m) + (b * s))}\)
where:
\(m\) is the mean
\(s\) is the standard deviation
\(a\) is a multiplier of the mean
\(b\) is a multiplier of the standard deviation
The \(a\) and \(b\) multipliers are input parameters.
If \(x <= a * m\):
\(u(x) = 0\)
This function is useful when the small input values have a higher membership.
The input values can be either integer or floating point positive values.
The result can be similar to the FuzzySmall membership function, depending on how the multipliers of the mean and standard deviation are defined.
Syntaxe
FuzzyMSSmall(meanMultiplier, STDMultiplier)
| Nom | Explication | Type de données |
meanMultiplier |
The multiplier for the mean of the input values in the function equation. The default value is 1. |
Double |
STDMultiplier |
The multiplier for the standard deviation of the input values in the function equation. The default value is 1. |
Double |
Propriétés
meanMultiplier (Lecture et écriture) |
The multiplier for the mean of the input values in the membership function equation. |
Double |
STDMultiplier (Lecture et écriture) |
The multiplier for the standard deviation of the input values in the membership function equation. |
Double |
Exemple de code
Demonstrates how to create a FuzzyMSSmall class and use it in the FuzzyMembership tool within the Python window.
import arcpy
from arcpy.sa import *
from arcpy import env
env.workspace = "c:/sapyexamples/data"
outFzyMember = FuzzyMembership("as_std", FuzzyMSSmall(1.2, 3.2))
outFzyMember.save("c:/sapyexamples/fzymssml")
Performs a FuzzyMembership using the FuzzyMSSmall class.
# Name: FuzzyMSSmall_Ex_02.py
# Description: Scales input raster data into values ranging from zero to one
# indicating the strength of a membership in a set.
# Requirements: Spatial Analyst extension
# Import system modules
import arcpy
# Set environment settings
env.workspace = "C:/sapyexamples/data"
# Set local variables
inRaster = "as_std"
# Create the FuzzyMSSmall algorithm object
meanMultiply = 1.5
stdMultiply = 1
myFuzzyAlgorithm = FuzzyMSSmall(meanMultiply, stdMultiply)
# Run FuzzyMembership
outFuzzyMember = FuzzyMembership(inRaster, myFuzzyAlgorithm)
# Save the output
outFuzzyMember.save("c:/sapyexamples/fzymssml2")
