TfMSSmall
Résumé
Defines an MSSmall transformation function which is determined from the mean multiplier and standard deviation multiplier shape–controlling parameters as well as the lower and upper threshold that identify the range within which to apply the function.
Learn more about how the parameters affect this transformation function
Discussion
The tool that uses the TfMSSmall object is Rescale by Function.
Where \(x\) is the input value, there are two equations for the MSSmall function, depending on the product of \(a * m\):
If \(x > a * m\):
\(f(x) = (b * s) \space / \space (x - (a * m) + (b * s))\)
where:
\(m\) is the mean
\(s\) is the standard deviation
\(a\) is a multiplier of the mean
\(b\) is a multiplier of the standard deviation
The \(a\) and \(b\) multipliers are input parameters.
If \(x <= a * m\):
\(f(x) = 0\)
The function values range from 0 to 1, which are then transformed to the evaluation scale.
The MSSmall function is useful when the small input values are preferred and they should receive the higher output evaluation values.
The result from the MSSmall transformation function can be similar to that of the Small transformation function, depending on how the multipliers of the mean and standard deviation are defined.
Syntaxe
TfMSSmall({meanMultiplier}, {STDMultiplier}, {lowerThreshold}, {valueBelowThreshold}, {upperThreshold}, {valueAboveThreshold})
| Nom | Explication | Type de données |
meanMultiplier (Facultatif) |
The multiplier for the mean of the input values in the MSSmall function equation. The The default value is 1.0. |
Double |
STDMultiplier (Facultatif) |
The multiplier for the standard deviation of the input values in the MSSmall function equation. The The default value is 1.0. |
Double |
lowerThreshold (Facultatif) |
Defines the starting value at which to begin applying the specified transformation function. The input value corresponding to the The The default value is None. |
Double |
valueBelowThreshold (Facultatif) |
A value to assign output cell locations with input values below the The value for The default value is None. |
Variant |
upperThreshold (Facultatif) |
Defines the ending value at which to stop applying the specified transformation function. The input value corresponding to the The The default value is None. |
Double |
valueAboveThreshold (Facultatif) |
A value to assign output cell locations with input values above the The value for The default value is None. |
Variant |
Propriétés
meanMultiplier (Lecture et écriture) |
The value of the |
Double |
STDMultiplier (Lecture et écriture) |
The value of the |
Double |
lowerThreshold (Lecture et écriture) |
The value of the |
Double |
valueBelowThreshold (Lecture et écriture) |
The value that will be assigned to the output cells whose input values are below the |
Variant |
upperThreshold (Lecture et écriture) |
The value of the |
Double |
valueAboveThreshold (Lecture et écriture) |
The value that will be assigned to the output cells whose input values are above the |
Variant |
Exemple de code
Demonstrates how to create a TfMSSmall class and use it in the RescaleByFunction tool within the Python window.
import arcpy
from arcpy.sa import *
from arcpy import env
env.workspace = "c:/sapyexamples/data"
outRescale = RescaleByFunction("elevation", TfMSSmall(1.5, 1.75, "#", "#", "#", "#"), 1, 10)
outRescale.save("c:/sapyexamples/rescaletfms1")
Demonstrates how to transform the input data with the RescaleByFunction tool using the TfMSSmall class.
# Name: TfMSSmall_Ex_02.py
# Description: Rescales input raster data using a MSSmall function and
# transforms the function values onto a specified evaluation scale.
# Requirements: Spatial Analyst extension
# Import system modules
import arcpy
# Set environment settings
env.workspace = "C:/sapyexamples/data"
# Set local variables
inRaster = "elevation"
# Create the TfMSSmall object
meanmult = 1.5
stdmult = 1.75
lowerthresh = "#"
valbelowthresh = "#"
upperthresh = "#"
valabovethresh = "#"
myTfFunction = TfMSSmall(meanmult, stdmult, lowerthresh, valbelowthresh, upperthresh, valabovethresh)
# Set evaluation scale
fromscale = 1
toscale = 10
# Run RescaleByFunction
outRescale = RescaleByFunction(inRaster, myTfFunction, fromscale, toscale)
# Save the output
outRescale.save("c:/sapyexamples/rescaletfms2")
