TfSymmetricLinear
Résumé
Defines a Symmetric Linear transformation function which is determined from the minimum and maximum shape–controlling parameters as well as the lower and upper threshold that identify the range within which to apply the function.
Learn more about how the parameters affect this transformation function
Discussion
The tool that uses the TfSymmetricLinear object is Rescale by Function.
A linear function is applied between the specified minimum and maximum values which is mirrored around the midpoint of the minimum and maximum. The corresponding input value to the mirrored point receives the highest preference value (the highest output evaluation value), with the preferences decreasing linearly as the input values move away from the mirrored point value.
To create a positive slope for the transformation function, set the minimum value to be less than the maximum value. To create a negative slope for the function, set the minimum value to be larger than the maximum value.
The following relationships between the minimum and maximum parameters and the thresholds are important to understand:
If the
minimumparameter is set less than themaximumparameter and theminimumis greater than thelowerThreshold, any input value less than theminimumand greater than thelowerThresholdwill receive thefromScalevalue on the output raster.If the
maximumparameter is set greater than theminimumparameter and themaximumis less than theupperThreshold, any input value greater than themaximumand less than theupperThresholdwill receive thetoScalevalue on the output raster.If the
minimumparameter is set less than thelowerThreshold, the function will be defined by the specifiedminimum. If thelowerThresholdremains equal to the lowest input value and theupperThresholdremains equal to the largest input value (which is by default equal to themaximumparameter), the lowest input value will be assigned to an evaluation value defined by where the function intercepts the y-axis (thelowerThreshold). As a result, the output evaluation value for input cell locations assigned thelowerThresholdwill be greater than thefromScalevalue. Similar logic occurs for the highest input value if the definedmaximumis greater than theupperThreshold.
The function values range from 0 to 1, which are then transformed to the evaluation scale.
Syntaxe
TfSymmetricLinear({minimum}, {maximum}, {lowerThreshold}, {valueBelowThreshold}, {upperThreshold}, {valueAboveThreshold})
| Nom | Explication | Type de données |
minimum (Facultatif) |
The starting point for the Symmetric Linear transformation function. The point of inflection to mirror the function is determined by the midpoint of the The minimum cannot equal the maximum. The default value is None. |
Double |
maximum (Facultatif) |
The ending point for the Symmetric Linear transformation function. The point of inflection to mirror the function is determined by the midpoint of the The minimum cannot equal the maximum. The default value is None. |
Double |
lowerThreshold (Facultatif) |
Defines the starting value at which to begin applying the specified transformation function. The input value corresponding to the The The default value is None. |
Double |
valueBelowThreshold (Facultatif) |
A user-specified value to assign output cell locations with input values below the The value for The default value is None. |
Variant |
upperThreshold (Facultatif) |
Defines the ending value at which to stop applying the specified transformation function. The input value corresponding to the The The default value is None. |
Double |
valueAboveThreshold (Facultatif) |
A user-specified value to assign output cell locations with input values above the The value for The default value is None. |
Variant |
Propriétés
minimum (Lecture et écriture) |
The value of the minimum for the transformation function which defines the starting point for the Symmetric Linear function. |
Double |
maximum (Lecture et écriture) |
The value of the maximum for the transformation function which defines the ending point for the Symmetric Linear function. |
Double |
lowerThreshold (Lecture et écriture) |
The value of the |
Double |
valueBelowThreshold (Lecture et écriture) |
The value that will be assigned to the output cells whose input values are below the |
Variant |
upperThreshold (Lecture et écriture) |
The value of the |
Double |
valueAboveThreshold (Lecture et écriture) |
The value that will be assigned to the output cells whose input values are above the |
Variant |
Exemple de code
Demonstrates how to create a TfSymmetricLinear class and use it in the RescaleByFunction tool within the Python window.
import arcpy
from arcpy.sa import *
from arcpy import env
env.workspace = "c:/sapyexamples/data"
outRescale = RescaleByFunction("distroads", TfSymmetricLinear(30, 8500, "#", "#", "#", "#"), 1, 10)
outRescale.save("c:/sapyexamples/rescaletfli1")
Demonstrates how to transform the input data with the RescaleByFunction tool using the TfSymmetricLinear class.
# Name: TfSymmetricLinear_Ex_02.py
# Description: Rescales input raster data using a SymmetricLinear function and
# transforms the function values onto a specified evaluation scale.
# Requirements: Spatial Analyst extension
# Import system modules
import arcpy
# Set environment settings
env.workspace = "C:/sapyexamples/data"
# Set local variables
inRaster = "distroads"
# Create the TfSymmetricLinear object
minimum = 30
maximum = 8500
lowerthresh = "#"
valbelowthresh = "#"
upperthresh = "#"
valabovethresh = "#"
myTfFunction = TfSymmetricLinear(minimum, maximum, lowerthresh, valbelowthresh, upperthresh, valabovethresh)
# Set evaluation scale
fromscale = 1
toscale = 10
# Run RescaleByFunction
outRescale = RescaleByFunction(inRaster, myTfFunction, fromscale, toscale)
# Save the output
outRescale.save("c:/sapyexamples/rescaletfsl2")
