TimeSpecialDays
Résumé
Defines the summer solstice/equinox/winter solstice days as the time period to perform solar calculations.
Discussion
This object can be used in the following tools: Area Solar Radiation, Points Solar Radiation, and Solar Radiation Graphics.
The TimeSpecialDays class has no parameters.
Syntaxe
TimeSpecialDays()
Exemple de code
TimeSpecialDays example 1 (Python window)
Demonstrates how to create a TimeSpecialDays class and use it in the AreaSolarRadiation tool within the Python window.
import arcpy
from arcpy import env
from arcpy.sa import *
env.workspace = "C:/sapyexamples/data"
outAreaSolar = AreaSolarRadiation("solar_dem", "", 200, TimeSpecialDays())
outAreaSolar.save("C:/sapyexamples/output/areasolartsd")
TimeSpecialDays example 2 (stand-alone script)
Calculates the incoming solar radiation with the AreaSolarRadiation tool using the TimeSpecialDays class.
# Name: TimeSpecialDays_Ex_02.py
# Description: Run AreaSolarRadiation using the TimeSpecialDays object
# Requirements: Spatial Analyst extension
# Import system modules
import arcpy
# Set environment settings
# Set local variables
inRaster = "solar_dem"
# Create TimeSpecialDays Object
myTimeSpecialDay = TimeSpecialDays()
# Run AreaSolarRadiation
outAreaSolar = AreaSolarRadiation(inRaster, "", 200, myTimeSpecialDay, 14,
                                  0.5, "NOINTERVAL", 1, "FROM_DEM", 32, 8, 8,
                                  "UNIFORM_SKY", 0.3, 0.5)
# Save the output
outAreaSolar.save("C:/sapyexamples/output/areasolartsd2")
