TimeWholeYear
Résumé
Defines a year, using monthly intervals, to perform solar calculations.
Discussion
This object can be used in the following tools: Area Solar Radiation, Points Solar Radiation, and Solar Radiation Graphics.
If the {each_interval} option is set in the tool parameter, then output files will be created for each month; otherwise, a single output will be created for the whole year.
Syntaxe
TimeWholeYear({year})
Nom Explication Type de données
year
(Facultatif)
The Julian year.
The default value is the current Julian year.
Long
Propriétés
year
(Lecture et écriture)
The Julian year.
Long
Exemple de code
TimeWholeYear example 1 (Python window)
Demonstrates how to create a TimeWholeYear class and use it in the AreaSolarRadiation tool within the Python window.
import arcpy
from arcpy import env
from arcpy.sa import *
env.workspace = "C:/sapyexamples/data"
outAreaSolar = AreaSolarRadiation("solar_dem", "", "", TimeWholeYear(2008))
outAreaSolar.save("C:/sapyexamples/output/areasolartwy")
TimeWholeYear example 2 (stand-alone script)
Calculates the incoming solar radiation with the AreaSolarRadiation tool using the TimeWholeYear class.
# Name: TimeWholeYear_Ex_02.py
# Description: Run AreaSolarRadiation using the TimeWholeYear object
# Requirements: Spatial Analyst extension
# Import system modules
import arcpy
# Set environment settings
# Set local variables
inRaster = "solar_dem"
# Create a TimeWholeYear Object
year = 2004
myTimeWholeYear = TimeWholeYear(year)
# Run AreaSolarRadiation
outAreaSolar = AreaSolarRadiation(inRaster, "", 200, myTimeWholeYear, 14, 0.5,
                                  "NOINTERVAL", 1, "FROM_DEM", 32, 8, 8,
                                  "UNIFORM_SKY", 0.3, 0.5)
# Save the output
outAreaSolar.save("C:/sapyexamples/output/mysolarout")
