TimeWithinDay
Résumé
Defines a time period within one day to perform solar calculations. A Julian Day, start time, and end time are specified.
Discussion
This object can be used in the following tools: Area Solar Radiation, Points Solar Radiation, and Solar Radiation Graphics.
When the startTime and the endTime are the same, instantaneous insolation will be calculated. When the startTime is before sunrise and the endTime is after sunset, insolation will be calculated for the whole day.
For within-day time configurations, the maximum range of time is one day (24 hours). Calculations will not be performed across days (for instance, from 12:00 p.m. to 12:00 p.m. the next day). The startTime must be less than the endTime.
For within-day time configurations, the start and end times are displayed as solar time (units: decimal hours). When converting local standard time to solar time, the program accounts for equation of time.
Syntaxe
TimeWithinDay({day}, {startTime}, {endTime})
| Nom | Explication | Type de données |
day (Facultatif) |
The The default value is 183. |
Long |
startTime (Facultatif) |
The The default value is 0. |
Double |
endTime (Facultatif) |
The The default value is 24. |
Double |
Propriétés
day (Lecture et écriture) |
The |
Long |
startTime (Lecture et écriture) |
The |
Double |
endTime (Lecture et écriture) |
The |
Double |
Exemple de code
Demonstrates how to create a TimeWithinDay class and use it in the AreaSolarRadiation tool within the Python window.
import arcpy
from arcpy import env
from arcpy.sa import *
env.workspace = "C:/sapyexamples/data"
myTimeWithinDay = TimeWithinDay(264, 11, 14)
outAreaSolar = AreaSolarRadiation("solar_dem", "", "", myTimeWithinDay)
outAreaSolar.save("C:/sapyexamples/output/areasolartwd")
Calculates the incoming solar radiation with the AreaSolarRadiation tool using the TimeWithinDay class.
# Name: TimeWithinDay_Ex_02.py
# Description: Run AreaSolarRadiation using the TimeWithinDay object
# Requirements: Spatial Analyst extension
# Import system modules
import arcpy
# Set environment settings
# Set local variables
inRaster = "solar_dem"
# Create TimeWithinDay Object
day = 100
startTime = 0
endTime = 24
myTimeWithinDay = TimeWithinDay(day, startTime, endTime)
# Run AreaSolarRadiation
outAreaSolar = AreaSolarRadiation(inRaster, "", 200, myTimeWithinDay, 14, 0.5,
"NOINTERVAL", 1, "FROM_DEM", 32, 8, 8,
"UNIFORM_SKY", 0.3, 0.5)
# Save the output
outAreaSolar.save("C:/sapyexamples/output/areasolartwd2")
