Analyze Runway Obstacles (Aviation Tools)
Résumé
Analyzes obstacle data and obstruction identification surfaces (OIS) to determine if obstacles are penetrating.
To learn more about the tool, refer to the ArcGIS Pro Shorts video, Analyze Runway Obstacles in ArcGIS.
Utilisation
  • The Input OIS Features parameter value must be a multipatch feature class that contains the OIS.
  • The Input Obstacle Features parameter value must be a point, line, or polygon feature class and must be z-enabled with a projected horizontal and vertical coordinate system.
  • The Obstacle Height parameter default value is Feature Geometry. This value means that the height of the obstacle is captured as the z-value. Alternatively, you can specify a field in the feature class that contains the height values as the value for Obstacle Height.
  • If Absolute height is specified as the Obstacle Features parameter value, the z-value will be calculated from the mean sea level. If Relative height is specified, the z-value will be calculated from the ground level.
  • A point feature will be generated for each obstacle feature that is within the area covered by the OIS. The x- and y-point coordinates are the same as the obstacle point feature with which the output point is associated. The z-value of the geometry is the altitude of the OIS at the obstacle location.
  • Multipoint features will be generated when the input obstacle data is a polyline or a polygon.
  • The output point features will contain the following fields:
    • Obs_OID—The object ID of the input obstacle.
    • Z—The Absolute height or the Relative height value of the input obstacle.
    • GROUND_ELEV—If Relative height is specified, this is the value of the elevation source of the obstacle. This will be zero if Absolute height is specified.
    • OIS_Z—The altitude of the OIS at the obstacle location.
    • Delta_Z—The difference in elevation between the top of the obstacle and the OIS.
      Remarque :
      Positive values indicate obstacle penetration of the OIS.
    • OBSTACLETY—The field value from the input obstacle.
    Delta Z
  • All calculations and analyses are performed using values in the horizontal and vertical coordinate systems of the input OIS feature class. The output feature class will be created with those same input OIS feature class coordinate systems.
Paramètres
Etiqueter Explication Type de données
Input OIS Features
The multipatch features with defined Airport schema. The feature class must be z-enabled.
Feature Layer
The input obstacle features that will be analyzed. The feature class must be z-enabled.
Feature Layer
Output Obstacle Feature Class
A feature class containing one point for each obstacle feature that is within the area covered by the input OIS. If the geometry type of the input obstacle feature is a polyline or polygon, a multipoint feature class will be created.
Feature Class
Obstacle Height
(Facultatif)
The field containing the height of the obstacle features. The default value is Feature Geometry.
  • Feature Geometry—The field containing the height of the obstacle features.
String
Unit
(Facultatif)
Specifies the linear unit that will be used for the obstacle height. This parameter is active if the Obstacle Features parameter is set to Relative height.
  • Kilometers—The linear unit will be kilometers.
  • Meters—The linear unit will be meters.
  • Decimeters—The linear unit will be decimeters.
  • Centimeters—The linear unit will be centimeters.
  • Millimeters—The linear unit will be millimeters.
  • Nautical miles—The linear unit will be nautical miles.
  • Miles—The linear unit will be miles.
  • Yards—The linear unit will be yards.
  • Feet—The linear unit will be feet.
  • Inches—The linear unit will be inches.
  • Decimal degrees—The linear unit will be decimal degrees.
  • Points—The linear unit will be points.
  • Unknown—The linear unit will be unknown.
String
Obstacle Features
(Facultatif)
Specifies how obstacle height values will be interpreted.
  • Absolute height—Obstacle heights will be measured from sea level. This is the default.
  • Relative height—Obstacle heights will be measured from ground level.
String
Elevations
(Facultatif)
Specifies how obstacle base elevation heights will be identified. This parameter is active if the Obstacle Features parameter is set to Relative height.
  • Elevation field—Base elevation heights will be derived from a numeric field of the obstacle feature class. This is the default.
  • Elevation DEM—Base elevation heights will be derived from one or more digital elevation models (DEMs).
String
Elevation Field
(Facultatif)
The field containing base elevation heights of the obstacle features.
This parameter is active if the Obstacle Features parameter is set to Relative height and the Elevations parameter is set to Elevation field. The default is the first numeric field in the obstacle feature class.
String
Elevation Field Units
(Facultatif)
Specifies the linear unit that will be used for the base elevation values. This parameter is active if the Obstacle Features parameter is set to Relative height and the Elevations parameter is set to Elevation field.
  • Meters—The linear unit will be meters. This is the default.
String
Input Elevation Model
(Facultatif)
The DEMs covering the obstacles that will be used to derive base elevation values. This parameter is active if the Obstacle Features parameter is set to Relative height and the Elevations parameter is set to Elevation DEM.
Raster Layer
Environnements
Current Workspace
Informations de licence
  • Basic: No
  • Standard: Requires Airports
  • Advanced: Requires Airports
