Generate OIS Profile Data (Aviation Tools)
Résumé
Generates a JSON string that is stored in the PROFILEJSON field on the input Obstruction Identification Surface multipatch feature class that contains the data necessary to depict the terrain, runway, and Obstruction Identification Surface (OIS) in the Terrain and Obstacle Profile layout element.
For each runway feature, the tool finds each of the approach surfaces associated with that runway. With each approach surface, the tool uses the sampling distance parameter to extend from the runway and collect the centerline, the highest and lowest values for the terrain along a parallel extending from edge to edge. It also collects the profile information for the runway and the approach surface. The resulting 3D points representing the terrain, runway, and approach surface are stored in JSON format and saved in the corresponding approach OIS feature.
Utilisation
  • The Input Runway Features parameter value must be z-enabled and have projected horizontal and vertical coordinate systems defined. It must include a populated Runway Designator text field, which must be named as one of the following from the ArcGIS Aviation data models:
    • RWYDESG
    • RUNWAYDESIGNATORIDENTIFIER
    • DESIGNATOR_TXT
    Conseil :
    Recommended input features are RunwayCenterline from the Esri Airports data model or ADHPSurfaceLine from the AIS data model. For more information, see the respective schemas for attribute properties.
  • With each approach surface, the tool will use the underlying digital elevation model (DEM) to determine the minimum and maximum elevations between the left and right edges of the approach surface, sampled along the length of the approach.
  • The Target OIS Features parameter value must be a multipatch feature class, with projected horizontal and vertical coordinate systems defined, containing approach features and include the following fields:
    • RWYDESG or LANDINGSTRIPDESIGIDENTIFIER or DESIGNATOR_TXT (populated with a runway designator, for example, '09/27')
    • NAME (populated with the value 'Approach Surface')
    • DESCRIP (18B) (populated by tools from the Obstruction Identification Surfaces toolset)
    • PROFILEJSON (to be populated by the tool)
      Conseil :
      Recommended input features may be ObstructionIdSurface_MP from the Esri Airports data model. The approach features can be generated with one of the tools from the Obstruction Identification Surfaces toolset.
      Remarque :
      The field length must be at least 50,000 characters. A warning appears if the JSON output exceeds the length of the PROFILEJSON field.
  • The tool will use a flight path ID field (PATHID, text, Nullable, or 255) for the Target OIS Features parameter to associate curved approach polylines with specific approach surfaces. This is required if you have an Input Flight Path Features parameter value. Use this value for the Target OIS Features parameter with the OBJECTID field of the corresponding Input Flight Path Features parameter value. This will be populated by the Create Curved Approach tool when creating the curved approach surface or surfaces.
  • The output JSON string in PROFILEJSON will include elements defining the RunwayCenterline, OIS, Terrain, and OIS edges sections. All coordinates are in WGS84, and elevations and distances are in meters.
  • The following table describes the values stored in the element paths data within each element:
    Element path
    Example
    Populated width
    RunwayCenterline [-95.9594, 45.5582, 336.6764, 30.0] RunwayCenterline point coordinates and elevation at input sampling distance interval [Longitude, Latitude, Elevation, Distance from nearest Runway End]
    OIS [-95.9587, 45.5575, 342.1426, 90.0] OIS coordinates and altitude at input sampling distance interval [Longitude, Latitude, Elevation, Distance from nearest Runway End]
    Terrain [-95.9592, 45.5579, 338.3926, 338.3926, 338.3926, 30.0] Terrain coordinates and elevations across OIS extent at input sampling distance interval [Longitude, Latitude, Minimum Elevation, Elevation along extended runway, Maximum Elevation, Distance from nearest Runway End]
    Edges [-95.958, 45.5578, -95.9594, 45.5572, 90.0] Coordinates of OIS edges at opposite sides, outward from runway end at input sampling distance interval [Side 1 Longitude, Side 1 Latitude, Side 2 Longitude, Side 2 Latitude, Distance from nearest Runway End]
Paramètres
Etiqueter Explication Type de données
The input runway dataset. The feature class must be z-enabled and contain polylines.
Feature Layer
Input Elevation Model
The DEMs covering the runways and their approach obstruction identification surfaces.
Raster Layer
Target OIS Features
The multipatch features with defined Airport schema. The feature class must be z-enabled.
Feature Layer
(Facultatif)
The polyline features that define curved approaches to the specified runways. If no value is provided, all input features will be processed as straight approaches.
Feature Layer
Sampling Distance
(Facultatif)
The distance, in meters, between generated points. The default is 30.
Double
Sample OIS Features
(Facultatif)
Specifies whether elevation points for OIS features will be generated.
  • Activé—Elevation points will be generated.
  • Décoché—Elevation points will not be generated. This is default.
Boolean
Sample Runway Features
(Facultatif)
Specifies whether elevation points along the runways will be generated.
  • Activé—Elevation points will be generated along the runways.
  • Décoché—Only the start and end points of the runways will be used. Elevation points will not be generated. This is default.
Boolean
Sortie dérivée
Output OIS Features
The updated feature class containing the generated obstruction identification surfaces.
Feature Layer
Environnements
Current Workspace
Informations de licence
  • Basic: No
  • Standard: Requires Airports or ArcGIS Aviation Charting
  • Advanced: Requires Airports or ArcGIS Aviation Charting
