ICAO Annex 4 (Aviation Tools)
Résumé
Creates obstruction identification surfaces (OIS) based on the ICAO Annex 4 specification for the Precision Approach Terrain chart.
These surfaces are designed to aid in the analysis of the terrain and features within a defined portion of the final approach that is depicted on the Precision Approach Terrain chart type. To generate the surfaces, a runway centerline is needed as a reference for the surfaces. This tool generates the surfaces as polygon or multipatch features.
Héritage :
This is a deprecated tool. This functionality has been replaced by the ICAO Annex 4 Surfaces tool that creates OIS based on the ICAO Annex 4 specification for the Precision Approach Terrain chart with updated requirements and parameters.
Utilisation
The Input Runway Features parameter value must be z-enabled.
The Target OIS Features parameter value must be z-enabled.
If a feature class is specified for the Target OIS Features parameter value, it must have a vertical spatial reference.
OIS tools are flexible and accept a variety of input and output feature class types. For more information, see the OIS Input and Output schemas.
The Input Airport Control Point Feature parameter can be used to provide x-, y-, and z-geometry for displaced threshold features. If displaced thresholds are included, surfaces will be constructed based on their x-, y-, and z-geometry instead of their corresponding runway feature endpoint.
Paramètres
| Etiqueter | Explication | Type de données |
Input Runway Features |
The input runway dataset. The feature class must be z-enabled and contain polylines. |
Feature Layer |
Target OIS Features |
The target feature class that will contain the generated OIS. |
Feature Layer |
Runway Direction (Facultatif) |
Specifies the end of the runway where the approach surface will be created.
String |
Length (Facultatif) |
The length of the surface in meters. The default value is 900. |
Double |
Width (Facultatif) |
The width of the surface in meters. The default value is 120. |
Double |
Slope (Facultatif) |
The slope of the surface in degrees. The default value is 3. |
Double |
Start Height (Facultatif) |
The start height of the surface in meters. The default value is 15.24. |
Double |
Input Airport Control Point Feature (Facultatif) |
Supplies x-, y-, and z-geometry for displaced threshold features. If displaced thresholds are included, surfaces will be constructed based on their x-, y-, and z-geometry instead of their corresponding runway feature endpoint. |
Feature Layer |
Sortie dérivée
Output OIS Features |
The updated feature class containing the generated OIS. |
Feature Layer |
Environnements
Informations de licence
- Basic: No
- Standard: Requires Airports or ArcGIS Aviation Charting
- Advanced: Requires Airports or ArcGIS Aviation Charting
