Export Topology (Topographic Production Tools)
Résumé
Exports a topology from a geodatabase to an .xml file.
The .xml file contains a definition of a topology, including feature class names, topology ranks, topology rules, and cluster tolerance, and can be used by the Import Topology tool to recreate a topology in a new feature dataset.
Utilisation
  • This tool supports all data models and can be used on any geodatabase topology.
Paramètres
Etiqueter Explication Type de données
Input Topology
An existing topology in a geodatabase. All feature classes that participate in this topology will be listed in the output .xml file.
Topology; Topology Layer
Topology XML Document Location
The folder in which the .xml file will be written.
Folder
Topology XML Document Name
The name of the topology .xml file that will be created by the tool.
String
Sortie dérivée
Output Topology XML Document
Output topology XML file created by exporting topology rules.
File
Environnements
Cet outil n’utilise pas d’environnement de géotraitement.
Informations de licence
  • Basic: No
  • Standard: Requires Topographic Mapping
  • Advanced: Requires Topographic Mapping
