Unzip MGCP Cell And Import (Topographic Production Tools)
Résumé
Unzips and imports zipped Multinational Geospatial Co-production Program (MGCP) 1-degree-by-1-degree cell packages and MGCP Urban Vector Data (MUVD) resource surface packages (.zip files) into a target geodatabase.
Utilisation
  • This tool recursively searches the Root Folder parameter value for .zip files. The folder must contain an MGCP cell package or MUVD resource surface package with the shapefiles and a metadata file.
  • If no shapefiles are found in the zipped package, this tool will continue to run.
  • The Target Geodatabase parameter value must be an MGCP or MUVD geodatabase and have an MGCP_Metadata or MUVD_Metadata feature dataset. The MGCP_Metadata feature dataset must contain a Cell feature class. The MUVD_Metadata feature dataset must contain a ResourceSrf feature class.
Paramètres
Etiqueter Explication Type de données
Root Folder
The folder that contains the zipped shapefile cell or resource surface package (.zip file). This folder can contain more than one .zip file.
Folder
Target Geodatabase
The geodatabase where the unzipped shapefiles will be imported.
Workspace
Sortie dérivée
Output Geodatabase
The database where shapefiles from the Root Folder parameter value have been loaded.
Workspace
Environnements
Current Workspace
Informations de licence
  • Basic: No
  • Standard: Requires Topographic Mapping
  • Advanced: Requires Topographic Mapping
