ContingentFieldValue
サマリー
The ContingentFieldValue object contains properties that describe the properties of the field used for a contingent value.
ディスカッション
ContingentFieldValue objects cannot be created directly. ContingentFieldValue properties can be accessed through the values object that is returned by the arcpy.da.ListContingentValues function.
プロパティ
名前 説明 データ タイプ
code
(読み取り専用)
If the contingent value uses a coded value domain, this property returns the code that is used for the contingent value.
Long
name
(読み取り専用)
The name of the field that participates in the field group.
String
range
(読み取り専用)
If the contingent value uses a range domain, this property returns the minimum and maximum values of the range for the contingent value.
Long
type
(読み取り専用)
Specifies the type of field value used for the contingent value.
  • ANY—The field value can be any value.
  • CODED_VALUE—The field value is a code used in a coded value domain that has been assigned to the field.
  • NULL—The field value is null.
  • RANGE—The field value is a subset range of a range domain that has been assigned to the field.
String
