ListContingentValues
サマリー
The ListContingentValues function lists the contingent values on a table. Search conditions can be specified for the field group name and subtype to limit the list that is returned.
構文
ListContingentValues(table, {field_group_name}, {subtype_code})
| パラメーター | 説明 | データ タイプ |
table |
A table that has contingent values. |
String |
field_group_name |
The field group name to limit the results returned. Only contingent values for the field group specified will be returned. The default value is All. |
String |
subtype_code |
The subtype code to limit the results returned. Only contingent values for the subtype specified will be returned. The default value is All. |
Long |
戻り値
| データ タイプ | 説明 |
Object |
A list of |
コードのサンプル
List and describe the contingent value properties for a field group named MyFieldGroup.
import arcpy
CVs = arcpy.da.ListContingentValues("C:\\MyProject\\myConn.sde\\mygdb.USER1.myFC", "MyFieldGroup")
for cv in CVs:
print("Subtype: {}\nIs retired: {}\nContingent Value Id: {}\nValues: \n".format(cv.subtype, cv.isRetired, cv.id))
for v in cv.values:
print(" Field Name: {}\n Field Value Type: {}""".format(v.name, v.type))
if v.type == "CODED_VALUE":
print(" Field Value Code: {}\n".format(v.code))
if v.type == "RANGE":
print(" Field Range: {}\n".format(v.range))
