InsertCursor
サマリー
The InsertCursor object establishes a write cursor on a feature class or table. InsertCursor can be used to add new rows.
Learn more about data access using cursors
ディスカッション
When using InsertCursor on a point feature class, creating a PointGeometry object and setting it to the SHAPE@ token is a computationally intensive operation. Instead, define the point feature using tokens such as SHAPE@XY, SHAPE@Z, and SHAPE@M for faster, more efficient access.
Insert cursors support with statements to aid in the removal of locks.
Opening simultaneous insert or update operations on the same workspace using different cursors requires the start of an edit session.
The following includes some dataset types that can only be edited within an edit session:
  • Feature classes participating in a topology
  • Feature classes participating in a geometric network
  • Feature classes participating in a network dataset
  • Versioned datasets in enterprise geodatabases
  • Some object and feature classes with class extensions
注意:
Using InsertCursor on a layer with a joined table is not supported.
When a field has a default value, a cursor applies the default value when the field is not specified or is set to None.
構文
InsertCursor(in_table, field_names, {datum_transformation}, {explicit}, {load_only})
名前 説明 データ タイプ
in_table
The feature class, layer, table, or table view.
String
field_names
A list (or tuple) of field names. For a single field, you can use a string instead of a list of strings.
Use an asterisk (*) instead of a list of fields to access all fields from the input table (BLOB fields are excluded). However, for faster performance and reliable field order, it is recommended that the list of fields be narrowed to only those that are actually needed.
Raster fields are not supported.
Additional information can be accessed using tokens (such as OID@) in place of field names:
  • ANNO@—An Annotation object for the feature. This option is only valid for ArcGIS Pro annotation feature classes.
  • SHAPE@XY—A tuple of the feature's centroid x,y coordinates.
  • SHAPE@XYZ—A tuple of the feature's centroid x,y,z coordinates.
  • SHAPE@TRUECENTROID—A tuple of the feature's centroid x,y coordinates. This returns the same value as SHAPE@XY.
  • SHAPE@X—A double of the feature's x-coordinate.
  • SHAPE@Y—A double of the feature's y-coordinate.
  • SHAPE@Z—A double of the feature's z-coordinate.
  • SHAPE@M—A double of the feature's m-value.
  • SHAPE@GEOJSON—The GeoJSON representation of the feature's geometry.
  • SHAPE@JSON—The Esri JSON string representing the geometry.
  • SHAPE@WKB—The well-known binary (WKB) representation for OGC geometry. It provides a portable representation of a geometry value as a contiguous stream of bytes. Values are returned as a bytearray object.
  • SHAPE@WKT—The well-known text (WKT) representation for OGC geometry. It provides a portable representation of a geometry value as a text string.
  • SHAPE@—A geometry object for the feature.
  • SUBTYPE@—An integer of the subtype code.
Polygon, polyline, or multipoint features can only be created using the SHAPE@ token.
String
(オプション)
When features to be inserted have a different spatial reference than the target feature class, a projection will be performed automatically. If the two spatial references have a different datum, specify an appropriate transformation.
The ListTransformations function can be used to provide a list of valid datum transformations between two spatial references.
Learn more about datum transformations
String
explicit
(オプション)
If a field has a default value and the field is nullable, using a value of True will explicitly override the default value and insert null values into the record. When using a value of False, the default value will be inserted instead of null.
Apply the explicit rule to all fields:
with arcpy.da.InsertCursor(table, [field1, field2, field3], explicit=True) as cursor:
    print('Additional code')
The explicit rule can also be applied to individual fields using a list of Boolean values. The list of values must be the same length as the list of fields.
Apply the explicit rule to only the first two fields specified:
with arcpy.da.InsertCursor(table, [field1, field2, field3], explicit=[True, True, False]) as cursor:
The default value is False.
Boolean
load_only
(オプション)
Specifies whether the spatial index will be maintained.
When set to True, the spatial index will be dropped and only the records will be loaded. When the cursor is completed, the spatial index will be recalculated and re-created.
When set to False, the spatial index will be maintained during the loading of the records.
The default value is True.
Boolean
プロパティ
名前 説明 データ タイプ
fields
(読み取り専用)
A tuple of field names used by the cursor.
The tuple will include all fields and tokens specified by the field_names argument.
The order of the field names on the fields property will be the same as passed in with the field_names argument.
If the field_names argument is set to *, the fields property will include all fields used by the cursor. A value of * will return geometry in a tuple of x,y coordinates (equivalent to the SHAPE@XY token).
tuple
方法
insertRow(row[row,...])
Inserts a row into a table.
名前 説明 データ タイプ
row[row,...]
A list or tuple of values. The order of values must be in the same order as specified when creating the cursor.
When updating fields, if the incoming values match the type of field, the values will be cast as necessary. For example, a value of 1.0 to a string field will be added as "1.0", and a value of "25" added to a float field will be added as 25.0.
tuple
戻り値
データ タイプ 説明
Integer
insertRow returns the object ID of the new row.
コードのサンプル
InsertCursor example 1
Use InsertCursor to insert new rows into a table.
import arcpy
import datetime
# Create an insert cursor for a table specifying the fields that will
# have values provided
fields = ['rowid', 'distance', 'CFCC', 'DateInsp']
with arcpy.da.InsertCursor('D:/data/base.gdb/roads_maint', fields) as cursor:
    # Create 25 new rows. Set default values on distance and CFCC code
    for x in range(0, 25):
        cursor.insertRow((x, 100, 'A10', datetime.datetime.now()))
InsertCursor example 2
Use InsertCursor with the SHAPE@XY token to add point features to a point feature class.
import arcpy
# A list of values that will be used to construct new rows
row_values = [('Anderson', (1409934.4442000017, 1076766.8192000017)),
              ('Andrews', (752000.2489000037, 1128929.8114))]
# Open an InsertCursor using a context manager
with arcpy.da.InsertCursor('C:/data/texas.gdb/counties', ['NAME', 'SHAPE@XY']) as cursor:
    # Insert new rows that include the county name and a x,y coordinate
    # pair that represents the county center
    for row in row_values:
        cursor.insertRow(row)
InsertCursor example 3
Use InsertCursor with the SHAPE@ token to add a new feature using a geometry object.
import arcpy
# Create a polyline geometry
array = arcpy.Array([arcpy.Point(459111.6681, 5010433.1285),
                     arcpy.Point(472516.3818, 5001431.0808),
                     arcpy.Point(477710.8185, 4986587.1063)])
spatial_ref = arcpy.SpatialReference(26911)  # NAD 1983 UTM Zone 11N
polyline = arcpy.Polyline(array, spatial_ref)
# Open an InsertCursor using a context manager and insert the new geometry
with arcpy.da.InsertCursor('C:/data/gdb.gdb/lines', ['SHAPE@']) as cursor:
    cursor.insertRow([polyline])
