AIXFormat
サマリー
The AIXFormat object represents a collection of Adobe Illustrator Exchange (AIX) file properties that can be configured and used with the export method on the Layout, MapFrame, and MapView objects to create an output AIX file.
ディスカッション
AIX files are used with the ArcGIS Maps for Adobe Creative Cloud extension. With the extension, vector and raster map content is converted into editable, layered artwork for an improved editing experience in Adobe Illustrator . Once opened in Illustrator , the file can be used for high-end graphic design or map finishing workflows and migrated across the other Adobe Creative Cloud applications.
The CreateExportFormat method can be used to create a AIXFormat object if the format parameter is set to AIX. The returned AIXFormat object contains all the properties associated with generating an AIX file. These properties can be modified accordingly to produce different output results.
注意:
For more information about the AIXFormat, refer to the Export to AIX help topic.
プロパティ
| 名前 | 説明 | データ タイプ |
clipToElements (読み取り/書き込み) |
If set to |
Boolean |
convertMarkers (読み取り/書き込み) |
Controls whether marker symbols based on font characters are exported as font characters or as polygons. Set this option to |
Boolean |
embedColorProfile (読み取り/書き込み) |
Include the color profile set for the map or layout in the exported file. This helps create consistency in colors when the file is viewed on different devices. If the profile is not embedded, or a non-color-managed viewer is used, the colors may be significantly different than what is seen on-screen. The default value is 注意:This option is only available when color management is enabled. If color management is not enabled and the colorspace is set to CMYK, the CMYK colorspace is still included in the export. This may cause some colors to appear differently when viewing the exported file. |
Boolean |
embedFonts (読み取り/書き込み) |
Include embeddable fonts in the exported file to maintain font consistency across different platforms. Fonts that do not support embedding are not included, regardless of this setting. The default value is 注意:To correctly edit text as graphics, Illustrator requires fonts to be installed and accessible. Check the sharing permissions before embedding and sharing fonts. For high-range characters or ligatures, font embedding should be used to ensure proper addressing of these high-range characters. In the case where a font with high-range characters or ligatures cannot be embedded, check the Draw glyphs as geometry property on the text symbol. |
Boolean |
filePath (読み取り/書き込み) |
A string that represents the system path and file name, including the extension, for the exported file. |
String |
height (読み取り/書き込み) |
The height, in pixels, of the map area to be exported. This property only applies when exporting a |
Double |
imageCompression (読み取り/書き込み) |
A string constant that represents the compression scheme used to compress image or raster data in the output file. The default value is
String |
imageCompressionQuality (読み取り/書き込み) |
The amount of image compression applied to the export. Low quality has a smaller file size but less clear data; max quality has a larger file size but crisper data. This only applies when certain compression types are used. The default value is |
Integer |
imageQuality (読み取り/書き込み) |
The amount of image resampling. The property determines the effective resolution of raster content on output. For instance, if
String |
removeLayoutBackground (読み取り/書き込み) |
Remove the page background as a graphic when exporting. This property only applies when exporting a |
Boolean |
resolution (読み取り/書き込み) |
The effective dpi of the output vector data. The default value is 96. 注意:When exporting a |
Integer |
showSelectionSymbology (読み取り/書き込み) |
Show selected features in the map or map frame as selected in the output file. Setting this value to |
Boolean |
width (読み取り/書き込み) |
The width, in pixels, of the map area to be exported. This property only applies when exporting a |
Double |
方法
setImageCompression(image_compression)
| 名前 | 説明 | データ タイプ |
image_compression |
Below is a list of valid strings.
String |
setImageQuality(image_quality)
A string constant that sets the amount of image resampling.
The value determines the effective resolution of raster content on output. For instance, if the output image quality ratio is set to 1:2, an image_quality value of BETTER, and the output resolution is set to 300 dpi, the raster content is output at approximately 150 dpi. In many cases, the raster data can be included at a lower dpi than the vector data without visibly affecting quality, reducing the output file size.
| 名前 | 説明 | データ タイプ |
image_quality |
String |
コードのサンプル
The following script exports a layout to AIX format using default property values.
p = arcpy.mp.ArcGISProject('current')
lyt = p.listLayouts()[0]
aix = arcpy.mp.CreateExportFormat('AIX', r'C:\Temp\Output.aix')
lyt.export(aix)
