LayerTime
サマリー
The LayerTime object provides information about how time is stored and configured in time-enabled layers or tables.
ディスカッション
Fields containing the time values—such as start and end time, the time-step interval, and so on—can be used for not only gaining knowledge about the time properties on a time-enabled layer or table but also for performing further data management and analysis tasks. You can also use the time information to ensure that the time specified for selecting features or rows in a table is within the start and end time range.
The enableTime method on the Layer or Table classes allows you to enable time on that object if it has time information. You should test to see if the isTimeEnabled property returns True before attempting to access LayerTime properties.
ヒント:
You can use the MapTime class to access map time settings if a MapFrame on a Layout contains time-enabled layers or tables.
プロパティ
| 名前 | 説明 | データ タイプ |
daylightSavings (読み取り/書き込み) |
Indicates whether the time values in the time field of the time-enabled layer or table were collected while observing daylight saving time rules in the input time zone. |
Boolean |
endTime (読み取り/書き込み) |
The end date and time for a time-enabled layer or table. |
DateTime |
endTimeField (読み取り/書き込み) |
The name of the field containing the end time values. Not all layers or tables use an end time field. If each feature or row has a single time field, only the |
String |
startTime (読み取り/書き込み) |
The start date and time for a time-enabled layer or table. |
DateTime |
startTimeField (読み取り/書き込み) |
The name of the field containing the start time values. If each feature or row has a single time field, only the |
String |
timeDimension (読み取り/書き込み) |
The name of the dimension containing time values when using netCDF data. |
String |
timeFormat (読み取り/書き込み) |
The format in which the time values were stored in the |
String |
timeOffset (読み取り/書き込み) |
The time offset applied to the time values in your data. |
Double |
timeOffsetUnits (読み取り/書き込み) |
The time offset unit that describes the
String |
timeStepInterval (読み取り/書き込み) |
The time-step interval defines the granularity of the temporal data. The time-step interval can be thought of as how often the time values were recorded in your data. |
Double |
timeStepIntervalUnits (読み取り/書き込み) |
The time-step interval unit that describes the
String |
timeZone (読み取り/書き込み) |
The time zone for the time-enabled layer or table. ヒント:For a list of valid time zone strings, see |
String |
timeZoneIANA (読み取り/書き込み) |
The IANA time zone for the time-enabled layer or table. ヒント:For a list of valid time IANA zone strings, see |
String |
コードのサンプル
The following script tests whether layers in a layer file support time and whether time properties have been set. It then uses time information (start time and end time) to calculate the time extent of a time-enabled layer.
import arcpy
lyrFile = arcpy.mp.LayerFile(r'C:\Projects\Time\ShipPositions.lyrx')
for lyr in lyrFile.listLayers():
if lyr.supports('TIME'):
if lyr.isTimeEnabled:
lyrTime = lyr.time
startTime = lyrTime.startTime
endTime = lyrTime.endTime
timeDelta = endTime - startTime
print(f"Layer: {lyr.name}")
print(f" Start Time: {str(startTime.strftime('%m-%d-%Y'))}")
print(f" End Time: {str(endTime.strftime('%m-%d-%Y'))}")
print(f" Time Extent: {str(timeDelta.days)} days")
else:
print("No time properties have been set on the layer")
else:
print("Time is not supported on this layer")
The following script creates a feature class from input features valid at a certain time, while ensuring that the selection time is within the time extent (start time and end time) of the time-enabled layer.
import arcpy, os
# Setup output location and overwrite status
arcpy.env.overwriteOutput = True
path = r"C:\Projects\Time\Ships"
output_GDB = os.path.join(path, "Ships.gdb")
# Get time information from a layer in a layer file
lyrFile = arcpy.mp.LayerFile(os.path.join(path, "ShipPositions.lyrx"))
lyr = lyrFile.listLayers()[0]
lyrTime = lyr.time
# Set the time for which you want to select features in the time-enabled layer
fromTimeSelection = datetime.datetime(1776, 1, 1)
toTimeSelection = datetime.datetime(1777, 1, 1)
# Get the start and end time of the time enabled layer and its time field
timeField = lyrTime.startTimeField
# Check to see if the time for which you want to select features lies within the start and end time of the time enabled layer
if (fromTimeSelection < startTime or toTimeSelection > endTime):
print("The time specified for selecting features is not within the time extent of the layer")
else:
# Formulate the time query
timeQuery = f"{timeField} >= timestamp '{fromTimeSelection}' And \
{timeField} < timestamp '{toTimeSelection}'"
# Process: Feature Class to Feature Class
arcpy.conversion.FeatureClassToFeatureClass(lyr, output_GDB, "Ships_1776", timeQuery, "", "")
# Add the new layer to a map and enable time
p = arcpy.mp.ArcGISProject(os.path.join(path, "ships.aprx"))
lyt = p.listLayouts('Ships')[0]
mf = lyt.listElements('MAPFRAME_ELEMENT', 'NoTimeMF')[0]
m = mf.map
m.addDataFromPath(os.path.join(output_GDB, "Ships_1776"))
l = m.listLayers("Ships_1776")[0]
l.enableTime()
mt = mf.time
mt.isTimeEnabled = True
# Save a copy of the project
p.saveACopy(os.path.join(path, "ships2.aprx"))
