MapTime
サマリー
The MapTime object provides access to time management operations when time-enabled layers are displayed in a MapFrame on a Layout.
ディスカッション
The MapTime class allows you to filter features in a map using a number of available time settings that correspond to controls on the Time tab and the Time Slider on an activated map frame on a layout in ArcGIS Pro. Changing map time properties only applies to a map associated with a MapFrame on a Layout and currently is not applied to a map view.
The currentStartTime and currentEndTime properties are used to specify a time span. The timeInclusion property controls whether features are included within a time span. The property is set using the setTimeInclusion method.
ヒント:
The currentStartTime property cannot be greater than the currentEndTime property. Conversely, the currentEndTime property cannot be less than the currentStartTime property. If you are changing to a new future time span, it is best to set currentEndTime before setting currentStartTime.
The timeStep method can be used to calculate new currentStartTime and currentEndTime values. To create a temporal map series, use the timeStep method to iterate through time values. For a code sample, see example 3 below.
Time can be enabled on newly added layers to a map frame's map, allowing you to perform time analysis, create temporal map books, and so on. For code samples, see examples 2 and 3 below.
プロパティ
| 名前 | 説明 | データ タイプ |
currentTimeEnd (読み取り/書き込み) |
The current end date and time for a map frame's current time span. |
DateTime |
currentTimeSpan (読み取り専用) |
The current time span that represents the difference between start and end times for a map frame's time span. |
Double |
currentTimeSpanUnits (読み取り専用) |
A string representing the units for the
String |
currentTimeStart (読み取り/書き込み) |
The current start date and time for a map frame's time span. |
DateTime |
isTimeEnabled (読み取り/書き込み) |
A Boolean that determines whether time is enabled for a map frame. The |
Boolean |
timeInclusion (読み取り専用) |
A string that controls whether the
String |
timeStepInterval (読み取り専用) |
Indicates the time the start and end times will be offset by on each time step. |
Double |
timeStepIntervalUnits (読み取り専用) |
The units used by
String |
方法
setTimeInclusion(time_inclusion)
The setTimeInclusion method controls how the currentTimeStart and the currentTimeEnd are included in the current time span.
The data displayed based on the currentTimeStart and currentTimeEnd values can be further modified by excluding one or both values in the time span—for example, if you are displaying a time span of one year where the start time is 1/1/2020 and the end time is 1/1/2021. If you do not want data from 1/1/2021 to be included in any analysis, you would set time_inclusion to be INCLUDE_ONLY_START.
| 名前 | 説明 | データ タイプ |
time_inclusion |
A string that specifies a valid time inclusion value.
String |
timeStep(reference_time, interval, interval_units)
The timeStep method returns a new time based on a given reference time and a time interval.
The timeStep method returns a new time based on a given reference time and a time interval. The Python datetime object that is returned from the timeStep method can be used to set the currentTimeEnd and currentTimeStart properties. To create a temporal map series, use the timeStep method to iterate through time values.
| 名前 | 説明 | データ タイプ |
reference_time |
A Python ヒント:The |
DateTime |
interval |
A double that defines a time interval. ヒント:Positive or negative intervals can be used. |
Double |
interval_units |
A string that specifies a valid interval unit.
String |
戻り値
| データ タイプ | 説明 |
DateTime |
The new |
コードのサンプル
The following script sets the initial start and end times for the map frame and then iterates over one-month intervals for a year. Each month is exported to a PDF file.
import arcpy
import os
path = r"C:\Projects\Time\Ships"
#Reference a project, layout, and a map frame
p = arcpy.mp.ArcGISProject(os.path.join(path, "ships.aprx"))
lyt = p.listLayouts('ships')[0]
mf = lyt.listElements('MAPFRAME_ELEMENT', 'ShipsWithTimeMF')[0]
if not mf.time is None:
#Get the map frame time, set the initial time window and inclusion settings
t = mf.time
t.currentTimeStart = datetime.datetime(1776, 1, 1, 0, 0)
t.currentTimeEnd = datetime.datetime(1776, 2, 1, 0, 0)
t.setTimeInclusion('INCLUDE_ONLY_START')
for x in range(1,13):
#Export to PDF
outPDF = os.path.join(path, "Output", f"1776-{x}.pdf")
lyt.exportToPDF(outPDF)
#Change the time window to the next 1 month interval
t.currentTimeStart = t.timeStep(t.currentTimeStart, 1, "months")
t.currentTimeEnd = t.timeStep(t.currentTimeEnd, 1, "months")
The following script adds a time-aware layer from a layer file to a map frame's map. In this workflow, the map frame is not time aware. The script then zooms to the extent of the added layer. Time is enabled on the map frame by setting isTimeEnabled to True. Finally, the script defines an initial time span by setting currentStartTime, currentEndTime, and setTimeInclusion.
import arcpy
import os
lyt = p.listLayouts('Ships')[0]
mf = lyt.listElements('MAPFRAME_ELEMENT', 'NoTimeMF')[0]
#Reference the map frame's map and add a time enabled layer from a layerfile
m = mf.map
m.addDataFromPath(os.path.join(path, "ShipPositions.lyrx"))
#Zoom to the layer
l = m.listLayers()[0]
mf.camera.setExtent(mf.getLayerExtent(l))
#Enable time on the map and set its time window
mt = mf.time
mt.isTimeEnabled = True
mt.currentTimeEnd = datetime.datetime(1900, 1, 1, 0, 0)
mt.currentTimeStart = datetime.datetime(1800, 1, 1, 0, 0)
mt.setTimeInclusion('INCLUDE_ONLY_START')
#Export the layout
lyt.exportToPDF(os.path.join(path, output, "ShipPositions_1800s.pdf"))
The following script adds a time-aware layer from a layer file to a map frame's map. Time is then enabled on the layer and the map. The timeStep method is used to iterate through a series of time spans. Each time span is exported to a PDF file. To create a complete map book experience, the PDFDocument class is used to add a title page and end page to the temporal map book.
import arcpy, os
basedir = r"C:\Project\Time"
# Create the output pdf file
pdfPath = os.path.join(basedir, "output", "HistoricalBoundaries.pdf")
pdfDoc = arcpy.mp.PDFDocumentCreate(pdfPath)
# Reference project, layout, map frame and map
aprx = arcpy.mp.ArcGISProject(os.path.join(basedir, "Tokyo.aprx"))
layout = aprx.listLayouts('Historical Boundaries')[0]
mfTokyo = layout.listElements('MAPFRAME_ELEMENT', 'Tokyo Map Frame')[0]
mTokyo = mfTokyo.map
# Add a layer that contains time values to the map
lyrTokyo = mTokyo.addLayer(arcpy.mp.LayerFile(os.path.join(basedir, 'Tokyo_Historic_Boundaries.lyrx')), 'TOP')[0]
# Enable time on the newly added layer
lyrTokyo.enableTime(startTimeField='Year', endTimeField='YearEnd')
# Enable Map Time
mtTokyo = mfTokyo.time
mtTokyo.isTimeEnabled = True
# Access Map Time properties for use in the MapTime.timeStep() method
interval = mtTokyo.currentTimeSpan
unit = mtTokyo.currentTimeSpanUnits
# Use the MapTime.timeStep() method to get the first time span
start = lyrTokyo.time.startTime
end = mtTokyo.timeStep(start, interval, unit)
# Loop through time spans
while end < lyrTokyo.time.endTime:
# Update the map frame with the time span
mtTokyo.currentTimeStart = start
mtTokyo.currentTimeEnd = end
# Export the time span to pdf
output_pdf_file = os.path.join(basedir, "output", f"HistoricalBoundaries_{start.year}_to_{end.year}.pdf")
layout.exportToPDF(os.path.join(basedir, "output", output_pdf_file))
# Appened the time step pdf to the output pdf
pdfDoc.appendPages(output_pdf_file)
# Use the MapTime.timeStep() method to proceed to the next time span
start = end
end = mtTokyo.timeStep(end, interval, unit)
# Add title and end pages to create a complete map book
pdfDoc.insertPages(os.path.join(basedir, 'Title Page.pdf'), 1)
pdfDoc.appendPages(os.path.join(basedir, 'End Page.pdf'))
# Save the output pdf
pdfDoc.saveAndClose()
