LastMileDelivery output data types
The output data types containing the results from a last mile delivery analysis are described below.
Orders
The output is a copy of the input Orders table with additional information about which route served each order, the arrival and departure times, and the order sequence.
The output Orders table includes all fields from the input Orders table. Fields that are updated or added to the output are listed in the following table:
Field
Data type
ObjectID
The object ID of the feature.
ObjectID
RouteName
The name of the route to which the order is assigned.
This field corresponds to the Name field in the output Routes table.
Text
Sequence
This indicates the sequence of the order on its assigned route.
Output sequence values for a route are shared across depot visits and orders. The sequences start from 0 at the starting depot and are consecutive. The smallest possible output sequence value for a routed order is 1. This is the case even if the route begins at a virtual depot.
Long
  • ViolatedConstraint_1
  • ViolatedConstraint_2
  • ViolatedConstraint_3
  • ViolatedConstraint_4
These fields contain a summary of violated constraints and are set after a solve operation. Each field will contain one violation. If an order has more than one violation, the next ViolatedConstraint_* field will be used.
  • MaxOrderCount exceeded (0)—The preassigned orders cannot be assigned to the route since assigning the orders will exceed the maximum number of orders that can be assigned to the route as specified by the route's MaxOrderCount field value.
  • Capacities exceeded (1)—The preassigned orders cannot be assigned to the route since assigning the orders will exceed the total route capacity as specified by the route's Capacities field value.
  • MaxTotalTime exceeded (2)—The travel time from the start depot to the end depot plus the service and wait times at both depots exceeds the total time for the route as specified by the route's MaxTotalTime field value.
  • MaxTotalTravelTime exceeded (3)—The travel time from the start depot to the end depot exceeds the total travel time for the route as specified by the route's MaxTotalTravelTime field value.
  • MaxTotalDistance exceeded (4)—The travel distance from the start depot to the end depot exceeds the total travel distance for the route as specified by the route's MaxTotalDistance field value.
  • Hard time window (5)—There is a hard time window violation on the start depot, end depot, or break associated with the route.
  • Unmatched specialty (6)—The specialties required by an order are not found on the target route.
  • Hard route zone (7)—An order that was preassigned to the route does not fall within a hard route zone.
  • Unreachable (10)—A preassigned order is located on a network element that cannot be reached by the route.
  • InboundArriveTime or OutboundDepartTime order violation (15)—The order couldn't be serviced within the inbound arrive time or outbound depart time constraints. This violation occurs when all the routes' LatestStartTime field values precede the InboundArriveTime field values or none of the routes can reach a depot before the order's OutboundDepartTime field value.
  • Cannot anchor first/last (16)—The order has an Anchor first or Anchor last assignment rule, but the solver could not honor this constraint. This violation occurs when the number of Anchor first orders or Anchor last orders is greater than the number of available routes.
Learn more about troubleshooting network analyses
注意:
The violated constraint field value of an unrouted order may or may not describe all its violations. If the violation is severe enough to immediately exclude the order from further consideration, the solver does so, which prevents any other violations from being discovered for that order. If a violation is encountered that doesn't automatically stop a solution from being generated, the violation is noted in violated constraint fields, and the solver continues to consider the order. Any further violations such as these are added to the violated constraint fields until either the solver finds a violation that prematurely stops the solve process for that particular order, or the solver finds an overall solution to the problem.
Long
FromPrevTravelTime
The elapsed travel time from the previous stop to the current stop.
The value is in the units specified by the timeUnits property of the analysis object.
Double
FromPrevDistance
The distance along the route from the previous stop to the current stop.
The value is in the units specified by the distanceUnits property of the analysis object.
Double
ArriveCurbApproach
The side of the vehicle the curb is on when arriving at the stop. A value of 1 means the right side of the vehicle; a value of 2 means the left side.
Long
DepartCurbApproach
The side of the vehicle the curb is on when departing from the stop. A value of 1 means the right side of the vehicle; a value of 2 means the left side.
Long
ArriveTime
The time of day the route arrives at the order.
The route may arrive at the order before the beginning of the order's time window, in which case there is a wait time at the order. For an order with a soft time window, the route may also arrive at the order after the end of the time window, in which case there is a violation time at the order.
This arrival time reflects the travel times that were used during the optimization by the solver. For a network with traffic data, traffic conditions for specific times of day are not used; rather, the solver uses the time neutral average travel times for this optimization phase.
The time zone for the ArriveTime field value is derived from the network element on which the order is located.
Timestamp Offset
DepartTime
The time of day the route departs from the order. The route departs from the order upon completion of service.
This departure time reflects the travel times that were used during the optimization by the solver. For a network with traffic data, traffic conditions for specific times of day are not used; rather, the solver uses the time neutral average travel times for this optimization phase.
The time zone for the DepartTime field value is derived from the network element on which the order is located.
Timestamp Offset
WaitTime
The wait time or layover at the order. For example, a wait time is incurred when a route must wait at an order for a time window to open.
Double
ViolationTime
The amount of time elapsed from the end of the order's time window to the arrival of the route vehicle.
Double
Status
Specifies the status of the point with respect to its location on the network and the outcome of the analysis. The possible values are the following:
  • 0 (OK)—The point was located on the network.
  • 1 (Not Located)—The point was not located on the network and was not included in the analysis.
  • 2 (Network element not located)—The network element identified by the point's network location fields can't be found. This can occur when a network element where the point should be was deleted, and the network location was not recalculated.
  • 3 (Element not traversable)—The network element that the point is located on is not traversable. This can occur when the element is restricted by a restriction attribute.
  • 4 (Invalid Field Values)—Field values fall outside a range or coded-value domain. For example, a negative number exists where positive numbers are required.
  • 5 (Not Reached)—The point can't be reached by the solver. The point may be on a separate, disconnected area of the network from the other inputs, or barriers or restrictions prevent travel to or from the point.
  • 6 (Time window violation)—The point could not be reached within the designated time windows. This status only applies to network analysis types that support time windows.
  • 7 (Not located on closest)—The closest network location to the point is not traversable because of a restriction or barrier, so the point has been located on the closest traversable network feature instead.
Long
Network location fields
  • SourceID
  • SourceOID
  • PosAlong
  • SideOfEdge
  • SnapX
  • SnapY
  • SnapZ
  • DistanceToNetworkInMeters
Together, these properties describe the point on the network where the object is located.
Learn more about locating inputs on a network
Depots
The output is a copy of the input Depots table with additional information about how the depots were located on the network.
The output Depots table includes all fields from the input Depots table. Only fields that are added to the output are listed in the following table:
Field
Data type
ObjectID
ObjectID
Status
Long
  • SourceID
  • SourceOID
  • PosAlong
  • SideOfEdge
  • SnapX
  • SnapY
  • SnapZ
DepotVisits
When a route starts or ends at a depot, a depot visit is created. Depot visits provide information regarding why a route visited a depot and what happened there. The quantity of goods loaded on or unloaded from a vehicle at the depot is recorded in the properties of a depot visit. Additional information that is useful in interpreting the analysis solution is also included.
The data type supports the following fields:
Field
Data type
ObjectID
ObjectID
DepotName
The name of the visited depot. This field is a foreign key to the Name field in the Depots table.
If the route uses a virtual depot, which means the route starts or ends at an order instead of a depot, DepotName is null.
Text
VisitType
The reason the depot was visited. This field is constrained by a domain of values:
  • 1—Start depot
  • 2—End depot
Long
RouteName
The name of the route containing this visit. This field is a foreign key to the Name field in the Routes table.
Text
Sequence
The sequence of the visited depot on the route.
Long
ServiceTime
The service time (such as loading or unloading) at the depot.
Double
FromPrevTravelTime
The travel time from the preceding visit on the route to the depot.
Double
FromPrevDistance
The travel distance from the preceding visit on the route to the depot.
Double
ArriveTime
The arrival time at the depot.
The arrival time reflects the travel times that were used during the optimization by the solver. For a network with traffic data, traffic conditions for specific times of day are not used; rather, the solver uses the time neutral average travel times for this optimization phase.
The time zone for the ArriveTime field value is derived from the network element on which the depot is located.
Timestamp Offset
DepartTime
The departure time from the depot.
The departure time reflects the travel times that were used during the optimization by the solver. For a network with traffic data, traffic conditions for specific times of day are not used; rather, the solver uses the time neutral average travel times for this optimization phase.
The time zone for the DepartTime field value is derived from the network element on which the depot is located.
Timestamp Offset
  • LoadedQuantity_1
  • LoadedQuantity_2
  • LoadedQuantity_3
  • LoadedQuantity_4
  • LoadedQuantity_5
  • LoadedQuantity_6
  • LoadedQuantity_7
  • LoadedQuantity_8
  • LoadedQuantity_9
The amount (for example, volume, weight, quantity) being loaded at the depot. If there are multiple capacities, the amounts in the LoadedQuantity_1 through LoadedQuantity_9 fields correspond to the matching Capacity_1 through Capacity_9 fields in the Routes input table.
Double
  • UnloadedQuantity_1
  • UnloadedQuantity_2
  • UnloadedQuantity_3
  • UnloadedQuantity_4
  • UnloadedQuantity_5
  • UnloadedQuantity_6
  • UnloadedQuantity_7
  • UnloadedQuantity_8
  • UnloadedQuantity_9
The amount (for example, volume, weight, quantity) being unloaded at the depot. If there are multiple capacities, the amounts in the UnloadedQuantity_1 through UnloadedQuantity_9 fields correspond to the matching Capacity_1 through Capacity_9 fields in the Routes input table.
Double
Routes
This provides access to the drivers, vehicles, and route paths of the last mile delivery analysis.
The output Routes table includes all fields from the input Routes table as well as additional fields describing how each route serviced the orders. Only fields that are added to the output are listed below.
Field name
Data type
ObjectID
ObjectID
Describes constraints violated by the route. The constraints are given as integers as described in the following list:
Long
OrderCount
The number of orders assigned to the route.
Long
TotalCost
The total operating cost of the route, which is the sum of the following field values: FixedCost, RegularTimeCost, OvertimeCost, and DistanceCost.
Double
RegularTimeCost
The cost of regular work time.
Double
OvertimeCost
The cost of overtime work.
Double
DistanceCost
The distance cost component obtained by multiplying the TotalDistance and CostPerUnitDistance field values.
Double
TotalTime
The total route duration. This includes travel times as well as service and wait times at orders and depots. The TotalTime value is the sum of the following attribute fields:
  • StartDepotServiceTime
  • EndDepotServiceTime
  • TotalOrderServiceTime
  • TotalWaitTime
  • TotalTravelTime
Double
The total service time spent at all orders on the route.
Double
TotalTravelTime
The total travel time for the route.
Double
TotalDistance
The total travel distance for the route.
Double
StartTime
The starting time of the route.
The time zone for the StartTime field value is derived from the network element on which the starting depot is located or the first order if the route starts at a virtual depot.
Timestamp Offset
EndTime
The ending time of the route. The route ends upon completion of service at the ending depot.
The time zone for the EndTime field value is derived from the network element on which the ending depot or final order is located.
Timestamp Offset
TotalWaitTime
The total wait time at all orders and depots on the route.
Double
TotalViolationTime
The total violation time at all orders on the route.
Double
DirectionPoints
This is the output turn-by-turn directions for the routes calculated in the analysis, represented as point locations along the routes where specific direction events or maneuvers occur.
Field name
Data type
ObjectID
ObjectID
RouteID
The ObjectID value of the output Routes feature with which this direction point is associated.
Long
Sequence
The sequence of the direction points for the route, starting with 1.
Long
DirectionPointType
Specifies the type of direction event or maneuver described by the point, designated by one of the values below.
  • Header (1)
  • Arrive (50)
  • Depart (51)
  • Straight (52)
  • On Ferry (100)
  • Off Ferry (101)
  • Central Fork (102)
  • Roundabout (103)
  • U-Turn (104)
  • Door (150)
  • Stairs (151)
  • Elevator (152)
  • Escalator (153)
  • Pedestrian Ramp (154)
  • Left Fork (200)
  • Left Ramp (201)
  • Clockwise Roundabout (202)
  • Left-handed U-turn (203)
  • Bear left (204)
  • Left Turn (205)
  • Sharp Left (206)
  • Left Turn and immediate Left Turn (207)
  • Left Turn and immediate Right Turn (208)
  • Right Fork (300)
  • Right Ramp (301)
  • Counter-Clockwise Roundabout (302)
  • Right-handed U-turn (303)
  • Bear right (304)
  • Right Turn (305)
  • Sharp Right (306)
  • Right Turn and immediate Left Turn (307)
  • Right Turn and immediate Right Turn (308)
  • Up Elevator (400)
  • Up Escalator (401)
  • Up Stairs (402)
  • Down Elevator (500)
  • Down Escalator (501)
  • Down stairs (502)
  • General Event (1000)
  • Landmark (1001)
  • Time Zone Change (1002)
  • Traffic Event (1003)
  • Scaled Cost Barrier Event (1004)
  • Boundary Crossing (1005)
  • Restriction Violation (1006)
  • Lane (1007)
Long
OrderID
The ObjectID field value of the output Orders feature with which this direction point is associated.
Long
DepotVisitID
The ObjectID field value of the output DepotVisits feature with which this direction point is associated.
Long
BreakID
注意:
This field is not used for last mile delivery analyses.
Long
DisplayText
The directions text that will be displayed in the consuming application.
Text
ArrivalTime
The time the direction event occurs in coordinated universal time (UTC).
Date
ArrivalUTCOffset
The difference in minutes between the local time at the maneuver location and UTC time shown in the ArrivalTime field.
Double
Name
The name of the direction point.
Text
ExitName
The highway exit name that appears in the directions instruction.
Text
AlternateName
The alternate source name that appears in the directions instruction.
Text
IntersectingName
The name of the intersecting or cross street that appears in the directions instruction.
Text
BranchName
The signpost branch name that appears in the directions instruction.
Text
TowardName
The signpost toward destination name that appears in the directions instruction.
Text
Level
The building level at which this direction event occurs. This value corresponds to the Level property defined in the network dataset used for the analysis.
Long
ShortVoiceInstruction
The short text that will be used as voice guidance text in the consuming application.
Text
VoiceInstruction
The additional text, including expanded abbreviations and plurals, that will be used as voice guidance text in the consuming application.
Text
Azimuth
The bearing in degrees of the vehicle departing this point. Zero indicates north.
Double
DirectionLines
This is the output route lines calculated in the analysis sliced to represent each route segment between DirectionPoints events or maneuver locations.
Field name
Data type
ObjectID
ObjectID
DirectionPointID
The ObjectID value of the feature in the DirectionPoints table with which this line is associated.
Long
RouteID
The ObjectID value of the output Routes feature with which this direction line is associated.
Long
DirectionLineType
Specifies the type of direction situation described by this line, designated by one of the following values:
  • Unknown (0)
  • Segment (1)
  • Maneuver Segment (2)
  • Restriction violation (3)
  • Scaled Cost Barrier (4)
  • Heavy Traffic (5)
  • Slow Traffic (6)
  • Moderate Traffic (7)
Long
Meters
The length of the line segment measured in meters.
Double
Minutes
The travel time along the line segment in minutes.
Double
FromLevel
The building level at which this direction event begins. This value corresponds to the Level property defined in the network dataset used for the analysis.
Learn more about the directions configuration of a network dataset
Long
ToLevel
The building level at which this direction event ends. This value corresponds to the Level property defined in the network dataset used for the analysis.
Long
